TV Remote control stopped working. I changed the
TV Remote control stoped working. I changed the batteries and it still doesn't work. What should I do?
  • Televison & ... Master
  • 5,166 Answers
It depends. If this is a remote for a satellite receiver, you may need to resynch the remote (see your manual - I know the Dish instructions).
If this is a TV only remote, you might try opening it and cleaning the contacts with an can of compressed air, electronic contact cleaner and a clean pencil eraser. However, recent remotes are like keyboards (membrane contacts) and this doesn't always work. In that case consider a universal remote to replace the bad one or look to see if remotes.com has a duplicate of your remote.
I hope this helps.
(for Dish, it is turn on the TV and the receiver, hit the Sys Info button on the receiver, then hit record on the remote. Then hit Select on the remote.)
Posted on Apr 24, 2010
My remote does not work
Remote Code for LCD Coby TV model TFTV2425 - Comcast Help and ...
forums.xfinity.com/t5/XfinityTV.../Remote...LCD-Coby-TV.../916553
Apr 14, 2011 - Remote Code for LCD Coby TV model TFTV2425 ... If your home entertainment device does not respond to the remote control after trying all of the codes listed for your ... I just changed to an hd box andcodes given by comcast did not work. Looked at my old remote notes and that is what I found and it works. Comcast DVR remote won't "select" an input from th...
May 26, 2011
Remote code for coby tvs
Feb 7, 2011
Comcast remote code for Coby tv/dvd
Mar 20, 2010
More results from forums.xfinity.com
Coby tv remote doesn t work Questions & Answers - Fixya
www.fixya.com > Forum > Tags > tv remote doesn t work
Dec 15, 2015 | Coby TFDVD2274 22 in. LCD TV
How to fix a tv remote for samsung tv
Check the batteries sometimes they are good but not fitted properly.
Roll the batteries that sometimes works or check the batery terminals are not corroded?
Feb 09, 2014 | Televison & Video
Samsung LE32C450E1W TV remote control stopped working, changed batteries no luck, turned off at power source for 30 min which fixed prob temp but has happened again and now turn off doesn't help....
Check the remote control for its infrared emission. Check it with fresh batteries. Clean the battery contacts inside its battery compartment. If these do not help you, you remote control need cleaning. If you wish to know more about how to clean and repair a remote control check this site. Pull up older posts. One among it has details.
Mar 24, 2013 | Samsung TV Remote Control
Magic eye light is on, but the remote control doesn't work anymore
open the remote control, and clean the keypads from oxide, corrosion, dirty.
change the batteries and put a new ones.clena the contacts batteries with pencil erase.
retight the springs contacts batteries, for better contacts. and try again.
Otherwise you must go to the repair shop TV for fix it.
God bless you
Sep 23, 2012 | Televison & Video
The TV stopped responding to the remote control
tried with reset doesn't work, ok it could be the IR sensor at the front panel of the tv doesn't work. but before you replace it you need to ensure if your remote controller is working. have you tried to check the remote with camera trick just to know if the remote controller is sending light to the IR sensor of the tv.
Sep 23, 2012 | Advent LC-20H15A 20 in. EDTV-Ready LCD TV
My TV remote control has stopped working. I've tried changing the batteries but it still doesn't work. Any tips or do I have to get a new one?
Check for rusted battery contacts due to leaked batteries. Clean them with polish paper or blade. Due to leaked batteries it is quite likely that the wires connecting remote control pcb & battery contacts are cut off.
sonsunny
Jul 02, 2011 | Televison & Video
Problem With Operating the Remote
Check to see that the batteries are installed correct,,may need to reprogram...hope this was helpful...
Apr 23, 2010 | Philips SRU3003 Remote Control
Remote stoped working
Have the remote IR Sensor on the television replaced.
Part is very inexpensive.
Oct 12, 2009 | JVC AV-36D303 36" TV
Problem with Remote Control
try adding codes one by one can find them in the remotes manual
May 17, 2008 | Akai LCT2721AD 27 in. LCD Television
Tv does nit respond to remote
The problem is inside the TV, caused by a cold soldering on the circuit board where the infrared receiver cables are connected. Needs to be resoldered.
Dec 16, 2007 | Zenith E44W46LCD 44" Rear Projection...
Televison & Video Logo
94 people viewed this question
Top Televison & Video Experts
Electro Med Services...
