Question about LG Televison & Video
Ota upgrading software not progressing
Ota showing on dvd recorder. upgrading software displayed on tv. its been showing this all day (8 Hours). with no progress shown on the download progress display bar on tv screen. any ideas as to how to rectify? So we can watch a dvd. Thank you
See "Software update and system information" inthe user manual. For the RHT497H this is on page 27.
Posted on Nov 07, 2011
I need to connect my vcr/dvd combo unit to an Emerson HD TV so that I can record shows. Can you help me?
Most TVs only have audio out and several audio/video in connections. Unless you have an unusual tv, there is no option for a coax connection from the TV to a recorder.
Since this DVD recorder only has an analog tuner, you need to connect it to a set top box to record signals unless you are looking only at analog channel sources. If you are getting OTA, then a OTA digital-to-analog tuner is needed for most channels. (Only low power stations are still broadcasting in analog.) The cheaper ones that were available with the government coupon were SD tuners. HD content will need a separate tuner. If you have cable or satellite, check the signal (QAM is digital cable).
Next connect the coax from your analog source to the DVD recorder coax in and another coax cable to the coax out and the TVs coax in (if you want to - the pass through doesn't work with a set-top box for non-analog signals). Set the channel to the appropriate one (3 or 4 for the OTA d-t-a boxes; desired channel to watch for analog OTA or cable). Set the TV to channel 2, 3 or 4. Alternatively, use composite A/V cables from the set top box to the A/V Input of the DVD recorder and set the recording channel to Input 1.
Next connect A/V cables (composite or S-video) to the recorder's matching out to the TV A/V or S-video In. Set the TV to A/V 1 or Video 1 depending on the Emerson TV. You can watch tapes or DVDs. For better video quality on DVD playback, also connect component video cables from the DVD recorder Out to the TV's component in (if it is available). Then set the TV to the appropriate component video input when watching DVDs.
I hope this helps.
Dec 05, 2010 | RCA DRC8300N DVD Recorder/VCR
Vip622 doesn't lock in all of the channels on the over the air antenna .Receiver locks in 8 of 10 Channels. Three days ago, the receiver locked in all 10.
Hello! Daniel Busa with Dish Network's customer service. When you run the scan you must select ok to save the changes. I f you're still having trouble check your ota setup, and perform a hard reset by unplugging it for ten seconds.
Nov 29, 2010 | DISH Network ViP622 DVR DTV Receiver /...
Im trying to connect my unit to my tv to record shows and i having trouble doing so please help i am hooking it up wrong
For OTA or CATV signals, you need to daisy chain the coax from the source (antenna for OTA) to the coax input on DVD recorder and then the coax out to the coax input of the TV. If you have a set-top cable box with an incoming CATV signal, it should be connected between the DVD recorder and the TV.
The unit can tune in and record 480i (SD) ATSC (OTA digital), NTSC (OTA analog), analog CATV and digital CATV channels.
A satellite receiver or a non-CATV cable box should get the incoming signal first and then have their composite video output (A/V) connected to the DVD recorder composite video input and then their coax (RF) output (if present) gets connected to the TV. For these, you would record from the IN1 or IN2 (press Select Input) instead of selecting a channel. Then connect the composite video out on the recorder to the TV's composite video in.
Digital signals are either enough to tune in or give no signal. So check that your antenna is correctly oriented for OTA.
Separately, you can connect the video signal when playing DVDs via composite (good signal) out and component out (better signal) out to the TV's matching input. For the component video, the sound is carried on a separate cable. Then set the TV to the input source.
In the case of wanting to watch a VHS tape while taping to a DVD, do not use the Component video source, set the TV to Input 1 (composite).
I hope this helps.
(you can get a copy of the manual here: http://tv.manualsonline.com/manuals/mfg/panasonic/dmrez47v_dmrez475v.html )
Nov 25, 2010 | Panasonic DMR-EZ47V DVD Recorder/VCR
OTA HDTV ONLY
just do these connect AV output from your dvd player to AV input in your TV.
Jun 09, 2009 | RCA 27F650T 27" TV
Recording with closed caption
Carl,
Better late than.. I think that the Polo can record the encoded closed captioning onto the HDD, but you have to have a CC equipped television to display the captioning.
The newer Magnavox and Philips recorders sold at Walmart record the captioning, and have the capability to display it even on sets without the built in CC decoder depending upon your recording settings. If you get a digital converter box and connect that as the source to your Polo, you can record CC displayed on the screen if you want.
tom
Nov 20, 2008 | Polaroid DRM-2001G DVD Recorder/HDD...
OTA Mode
any storms around? sounds like a power spike may have tanked it
Aug 01, 2017 | LG Televison & Video
Problem Recording HDD to DVD-R
I had a few problems with my philips 3450 - I downloaded the latest software upgrade at www.philips.com/support , and my issues were resolved. Worth a shot...
Only other thing I can think of is you may have a faulty batch of DVD-Rs?
Best of luck!
Jan 16, 2008 | Philips DVDR3450H DVD Recorder/HDD...
DVD recorder: Changed the settings, now
we could go through the setting like, you can see the monitor. using the remote do the following steps:
Step 1. press set up button.
Step 2. press down arrow once. ( playback)
Step 3. press OK.
Step 4. press down arrow once. (video (selection))
Step 5. press OK. (progressive scan)
Step 6. press OK, again.
Step 7. press down arrow once. (progressive scan off)
Step 8. press OK
you have now turned progressive scan off.
Dec 19, 2007 | Philips Magnavox MWR10D6 DVD Recorder
Video failure...
Check the interlace/progressive switch on the back.
Sep 21, 2007 | Toshiba SD-H400
Televison & Video Logo
837 people viewed this question
Computer Repairing
Computer Repairing
