Question about Insignia IS-LCDTV32 32 in. Television
Volume goes to mute and will come back after a while. Times vary.
    President:
  • Insignia Master
  • 749 Answers
Last time I had a problem like that I ended up having to replace the audio amplifier IC on the main board. It was the same TV model.
It is not sure, however, that the same would hold in your case.
Could also be the power that supplies the amplifier - this is rather common problem too.
Look for puffed caps on the power board, they are a hint for problems there.
Posted on Apr 24, 2010
Testimonial: "this gives me a great place to start. thank you."
Onkyo mute channels. When turned on, one or more channels remain mute. Acts like a contact problem; when switched on-off-on multiple times, mute channels may vary
follow this steps and fix it. God bless you
The speakers are not connected properly. Check the speaker connections. The Mute function is activated. Turn off the Mute function. The volume is turned all the way down. Turn up the volume. Neither set of speakers is selected (if unit has A/B buttons to select sets of speakers). Press either A or B to select a set of speakers. Both sets of speakers are selected, but only one set is connected (if unit has A/B buttons to select sets of speakers). Press the appropriate button to deselect the speaker outputs which are not connected. The receiver is set to TAPE MONITOR (if applicable). Turn off TAPE MONITOR mode. Headphones are plugged into the main unit. Unplug the headphones. The source selector is set to the wrong source. Select the proper source. The impedance of the speakers is less than the rating for the system. Use speakers with the correct impedance rating.
Oct 11, 2013 | Onkyo TX-SR500 Receiver
How to get my unidendect60 off silent mode
Uniden offers a variety of electronics products including corded and cordless telephones. Each of these phones features the ability to mute the phone whenever you desire. Muting the phone can be done as often as you like and canceled as you desire. The steps to muting your phone will vary depending on the type of phone you are using.
b> Locate the "Mute" button on the phone. The button will be on the keypad near the number keys. Press the "Mute" button to mute the phone. Look for the "Mute" indicator on the phone's display to ensure that the phone is muted. Speakerphone Volume Use the VOL (+ or -) buttons to adjust the speakerphone listening volume while it is in use.
http://www.uniden.com/pdf/1380BKom.pdf users guide
Jan 20, 2013 | Lands Phones
Trying to synch my remote to the new tvee model 25 sound bar and can't get the orange lights.
I had this same problem and it was due to their instructions which do not adequately explain the setup procedure.
On my own, I was successful in programming volume up but that was all. I assumed that for volume down I would hold the power button and the VOLUME DOWN button and wait for the flashing light just as I had for volume up. Problem is, you never get a flashing light.
Today, I spoke with a rep from Boston Acoustics who patiently explained that step one of the instructions has to be done the same way each time as it is the step that puts the soundbar into programming mode.
It is only at step 2 that things change.
The solution is to hold the power button and the Volume Up button every time in order to get the system into programming mode. Once the light is flashing, in order to program Volume Down, you then hold the Volume Down button until the light goes solid. Once the light goes solid, then press the volume down button on your remote 4 times slowly. Works like a charm.
Works the same way to program the mute button. Follow step one to get the unit in programming mode. Once the light is flashing, hold down only the mute button until the light goes solid. When the light goes solid, press the mute button slowly 4 times.
OBTW, this was programmed with a Logitech Harmony 650 remote unit.
Sep 05, 2011 | Boston Acoustics Audio Players & Recorders
Have a BA TVee 25 Soundbar. Only able to program Volume Up on my remote. Cannot program Volume Down or Mute. Nothing happens except to turn the Soundbar off and on. Don't tell me to follow...
Jul 26, 2011 | Boston Acoustics TVee Model Two TV...
Got the Boston Tvee 25 and was able to program the volume up ok, but not able to program the volume down or mute functions. The process is the same but ive tried 100 times with no luck! Any help?
Jun 05, 2011 | Boston Acoustics TVee Model Two TV...
Can program up volume but not down or mute
To program the down button, after step 1 of the programing sequence, you must press the down button of the speaker system and then press the down button on the remote four times. This goes for the other buttons (i.e. after step 1 of the programing sequence, press the mute button on the speaker system and then press the mute button on the remote four times).This is a weak point in the programing instructions.
May 25, 2011 | Boston Acoustics TVee Model Two TV...
Phone won't ring - I've gone through the handbook...
on the left side of the screen there is a volume button,,,there r to sets of buttons on the left side and one on the right ,the lower left side is volume and mute.it goes up and down...try that
May 21, 2010 | Motorola Mobility RAZR V3
I updated my nuvi 265T, now no sound, long load times and extremely short battery life. Can I go back and un-update?
same here, I talked to tech support and they said I will have to send it to their kansas office and they will give me a new one.
Oct 15, 2009 | Garmin nuvi 265 Car GPS Receiver
Verizon phone mute button
Talk about silly. This is the 3rd time typing the solution. (The Terms of Use link wiped it out too.) I had same problem by accidentally setting mute from bluetooth headset. If you have same situation, just turn volume up or down on headset. (Turning volume up or down on cellphone did not help me.) Good Luck,
BeenThere
Mar 26, 2008 | Cell Phones
Volume and mute buttons suddenly stopped working
Try changing the batteries. Most times the "tivo" buttons will work but the "tv" buttons will stop working when the batteries are low.
If you have done that, go back into settings and program the remote again for your tv, then give it a shot.
Nov 05, 2007 | Tivo DirectTV Remote Remote Control
Insignia IS-LCDTV32 32 in. Television Logo
283 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
