Question about Jura Capresso C3000 Espresso & Coffee Maker
Capresso C3000 Mega-weak coffee
Have had my Capresso C3000 for about 3 years or so now. Has been a great machine. Lately, the coffee keeps getting weaker and weaker and weaker. The puck is not really a puck anymore either, it's just sorta loose coffee grounds that dumps into the tray.
Is there a way to adjust or does anyone know what the problem might be????
  • Nexsen Jul 27, 2008
    I have the same problem and have been using two shots per cup with reduced water amount to compensate but it is still too weak. The pucks are about half the size they should be.
    After HOURS of emails back and forth with Capresso - even their foreign division's top tech guru - I discovered they have no quantitative test for coffee grinder output. Not even initially and not when machines go back for repair (which mine has been twice to no avail on this problem).
    They agreed to replace the grinder if I send it again for the flat fee repair (about $250 I think) but they could still not guarantee any specific grinder output as they have no way to measure it. (I suggested a relatively simple way to measure it with detailed calculations as to why it would work as I am a mechanical engineer and got no response from their worldwide service manager.)
    I think 7 grams of ground coffee is considered a shot and it is supposed to be able to do a double or actually 17 grams they say but mine isn't half that.
    I sent them photos of the puck made on max settings alongside one made with their ground coffee spoon but this seems a major oversight.
    In fact the design in my opinion is flawed as the coffee output is assumed to be a function of grinding TIME but that does not consider the coarseness setting. the finer you set the grinder the longer it takes to grind a gram of coffee so in my case with the max grinding time set I still have to use a coarser grinder setting to even get the inadequate half size pucks. Finer should be stronger but with Capresso the finer grinder setting may reduce the coffee quantity enough to make it weaker rather than stronger.
    Maybe a new grinder will do the trick but I will soon have more in repairs than a rebuilt machine would cost. This one was purchased new at Williams Sonoma and given to us by our daughter.
  • 4 Answers
I have a Capresso fo 7 years now, had few problems, but always solve them.
If youe machine does all the functions properly, but doesn't give you coffee, you should check if everytnhig goes into the grounds tray. If that's the case you may only have a broken "O ring" inside the pressing element. It makes the coffe, but throws it away instead of filling the cup. I had that problem, and it was the "O ring".
If the grounds dunped on the tray are dry, you're looosing the water in the back, probably on the relief valve.
Hope this helps!
Posted on Mar 27, 2010
  • Jura Capresso Master
  • 19,396 Answers
Basing on personal experience (you can find more on Google probably), solutions are:
On percolated (filter) coffee machines:
Check water temp, if water temp is insufficient , most common is scale heating element , faulty element, faulty thermostat.
Check if water is dripping right at the center of the filter, if it is dripping on one side because the orifice is clogged, that can result in weak coffee.
Coffee blend not well distributed on filter basket.
On Espresso machines:
Check water temp, same as filter coffee machines (thermostat element, scale on heating chamber).
Ensure that coffee is filled correctly in the filter cup (fill at level), and well pressed.
Ensure that the coffee mixture that you are using is not too coarse, buy the apposite one for espresso.
Ensure that you are not leaving the machine brewing for a time that is too long, and Italian coffee cup is very small, approximately one regular shot.
On the hob moka pots (espresso, Moka and Bialetti type):
This are the trickiest ones, you need art and practice to get a good espresso with a Moka, but when you learn, the result is better than what you may get with an home electrical espresso maker.
The frame on the hob must be not too strong, and the mixture coarse but well pressed, with water at level tag, or you will get a weak coffee.
On Mokas a good strategy is keeping hob at minimum, and turning up the flame at top when coffee starts coming out.
French and turkish cafetieres:
Ensure that you put enough coffee, water hot enough, and that you left the infusion enough time to get a strong coffee.
Note: insufficient pressure and clogged lines on electric machines never give you a weak coffee, exactly the opposite.
Not pressed mixture always gives weak coffee, but too much pressed mixture may give you coffee with bad taste.
Posted on Apr 01, 2009
  • Odette
    Odette Jan 21, 2014
    I had a similar issue, the problems was with the grinder. It was grinding too little coffee because some parts of the grinder had moved
Machine beps showes Clean New
Cleaning instructions for that machine can be found in the user guide at the link below:
http://www.capresso.com/pdf/super_c3000.pdf
Sep 03, 2013 | Jura Capresso C3000 Espresso & Coffee...
How to clean the coffee machin
User guide found at the below link has cleaning instructions:
Jura capresso c3000 yellow clip
I found out where it goes, thanks to Juergen, who pointed me toward his excellent page on Jura cleaning: see figure 7d, copied here
which shows the yellow clip helping to hold on the tea pipe. I'm guessing that if you don't use the tea pipe, you will be okay. Otherwise you can just put that clip back on next time you clean the machine.
Nov 08, 2012 | Jura Capresso C3000 Espresso & Coffee...
Our DGB-700 has stopped grinding the beans. The motor sounds very weak. I have taken it apart and cleaned thoroughly with no good results. Can it be repaired or is it just time to "move on"...
I use Capresso CoffeeTeam model #454 10 cup 50 oz digital coffeemaker burr grinder combination with four grind settings. Now it is more than 5 years old, works every single day without any problem. Capresso has the great customer support. Its price for the refurbished item is compatible with the price of your Cuisinart. I am not sure it is the solution for you but I am very happy with my coffeemaker.
Jan 04, 2011 | Cuisinart Grind Brew DGB700 12Cup Coffee...
How to remove the back panel of a c3000
No, your damn right, theres no tool on the market for tohse screws.
I did it with a fine end point pliers, it cause litle damage to the screws head, but worked.
Feb 28, 2010 | Jura Capresso C3000 Espresso & Coffee...
Service 8 on Capresso 1300
The gears inside are clogged with coffee grounds. The machine will need to be taken apart carefully, and the gears cleaned of the coffee. I just did mine a C3000, and you will have to be careful to remember how all the parts go back together. This takes a T15 hex key for the screws. Good luck.
Aug 30, 2009 | Jura Capresso C1300 Coffee Maker, Espresso...
Jura Capresso C3000 keeps saying clean unit
We have the S8 here at our office. Ran the cleaning cycle and "Clean Now" message was still on and beeping afterwards. Read the Feb 28 comment and carefully cleaned everything that had grounds stuck to it. Ran the cycle again and it worked. Thanks all.
Feb 28, 2009 | Jura Capresso Impressa S8 Coffee Maker,...
I have a capresso c3000 and one day it just wont turn on anymore. any suggestions?
We had the same problem. We unplugged the unit from the wall and then plugged it back in again. For us, it was as simple as that.
Jan 08, 2009 | Jura Capresso C3000 Espresso & Coffee...
Jura Capresso C3000 Espresso & Coffee Maker Logo
986 people viewed this question
Top Jura Capresso Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Ken Macumber
Ken Macumber
Level 1 Expert
Are you a Jura Capresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
