Question about Jandy Lite 2 Natural Gas Pilot Light Heater
Opened pool, filter and pump working fine, flow is good. Pilot light is on and can not fire up heater when switch is on and themostat up.(Jandy Lite 2 heater usuing natural gas)
  • leddzepp1 Apr 26, 2010
    Air in gas line was the problem. You got it. Thanks alot!
    Followed your suggestion about air in gas line and it fired right up. Thanks!
  • 155 Answers
Good Day To You,
I have a few possibilities, since the pilot light is on that i will list and their fixes keep in mind that the first one is simple, it makes me laugh when people ask me is it plugged in. Here it goes.
  1. Is Gas Valve in the "ON" position. The fix is to turn it to the on position. Easy I know, but I've made that kinda mind lapse before.
  2. Possible Air in gas line. The fix is to Cycle the ignition sequence (turn on/off) until air is out of the Gas line. Listen closely there should be an audible click if not. Then move on to the next possible scenario.
  3. Gas valve failed. If the Gas valve has power to it and you cannot hear an audible clicking noise then you have a failure in the gas valve. The fix is to replace the gas valve part# R0317100 for NAT Gas.
It is at this point that depending on your abilities and proper testing equipment, volt meter, you may need to call a service technician. Beyond the Gas valve you have control boards, circuits, etc. I hope this helps get you going. Thanks for using FixYa, please comment back if you have any further questions. Have a great weekend. Jeff
Posted on Apr 24, 2010
  • Jeff Drake
    Jeff Drake Apr 26, 2010
    I am Glad it fired up and once again thank you for using FixYa. Jeff
Pilot stays lite but burner won't ignite
you have either an open safety, poor wiring connection, or problem with tstat controls
Apr 15, 2014 | Zodiac Jandy Legacy LRZ 175K Commercial...
Jandy lite 2 pool heater will not stay lit.
I'm having the same issue as the above user with Jandy Lite 2 (which from what I can tell stands for the number of times that you can get this POS to work annually)!
The unit LIGHTS OFF, but WON'T STAY LIT! Igniter engages, gas valve opens, unit lights, burns for 10 seconds, and flames out. Error code FL 2, after third attempt, already replaced the flame sensor....
May 12, 2013 | Pool & Spa
I have a lite 2 the pilot is lit but the bruners wont lite up
pump must be running. or filter is plugged. or pad pressure switch it's located on the plumbing inside of the heater and has 2 wires going to it., you might lightly tap it with a screwdriver LIGHTLY ! or just replace it there a fairly cheap item around $20
Jay the pool pump motor repair guy longwood fl
Jan 14, 2013 | Jandy Lite 2 Natural Gas Pilot Light...
Getting FL0 error message. heater is coming on, then off with error message. my heater is a jandy lite 2 400K propane unit
Thank you for posting your question here on Fixya.com.
Page 34 and 35 of your manual, found here, describe FL0 as a flow issue most likely caused by dirty filters. Depending on the type of filter you have a good cleaning/backwash will usually remedy that. It is also possible the unit's pressure switch, which senses water flow and therefore reacts to dirty filters when present, may have failed, especially if you winterize the heater in a cold climate and leave water in the switch which can burst the diaphragm inside.
Start with cleaning the filter. If the heater still won't fire jump out the pressure switch while the pump is running to confirm the part is the problem. Assuming it is replacing it with a new pressure switch which should be under $75. The part number can be found in the rear of the manual.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. You may also contact me thru our website at www.arrowpools.net. Positive feedback is appreciated once your problem is solved!
John
Jul 22, 2011 | Jandy Laars Lite 2 Pool Heater 400000 BTU ...
Fl0 and fl3 service lights come on have flow to unit just will not fire up
The flo code indicates the the water pressure switch is open. If you know that you have more than the minimum amount of flow going through the heater, then the problem is a clogged or defective pressure switch. The pressure switch is located on top of the inlet/outlet header and can be found at an online store or a local pool and spa company. A generic may be used in place of the manufaturer part.
Feb 07, 2011 | Jandy Lite 2 Natural Gas Pilot Light...
Looking to buy pvc pipes to fit Jandy pool heater in and out flow pipes live in slough uk
jandy in and out pipes are 2" schedule 80 cpcv and should beavailable at any plumbing supply house. buy on 16" nipple and cut in half.Thread into headers then pvc cement the unthreaded end to tie into pump/filter system
Aug 21, 2009 | Jandy Lite 2 Natural Gas Pilot Light...
Can't re-light the pilot light
THIS HEATER DO NOT HAVE A PILOT YOU MUST HAVE A DIFFERENT MODEL. DO YOU GAS? TURN KNOB TO PILOT PRESS. LIGTH PILOT WAIT FOR 60 SEC AND RELEASE IF STAY ON TURN KNOB TO ON. IF TURN OFF PILOT MUST BE REPLACE
Jun 20, 2009 | Jandy Lite 2 Natural Gas Pilot Light...
Jandy Lite 2 Natural Gas Pilot Light Heater Logo
123 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Pj Kiley
Pj Kiley
Level 1 Expert
Bill Jordan
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
