Question about Garden
Poulan 2150 put new fuel lines on geting gas trew line put the primer buld will not prime and somtimes gets stuck but will release win i pull it of carb
  • dontbother10
    dontbother10 May 11, 2010
    try swapping the lines on the carb, no better did you replace the fuel filter?
    Brigadier General:
  • 4,088 Answers
Check the condition of the primer bulb for hardness or cracking. If ok, remove the line that goes from the bulb back into the tank and try to pump fuel from the carburetor. If nothing, switch the position of the other line at the back of the primer and try to draw fuel again. If hooked correctly, the primer will pull fuel through the carburetor body filling all cavities and into the primer bulb. If still nothing, try switching the lines at the carburetor (it should not pump backwards through the check valves in the pumper chamber). If still nothing, switch the primer connection again. Some combination of line connections should allow fuel to be pumped through. When correct, reconnect the loose primer line to allow fuel to return to the tank. This is a good reason for replacing only one line at a time. Hope this helps!
Posted on Apr 29, 2010
Poulan 2150 chain saw starts after priming and dies after a few seconds
Take the exhaust off so you can see the side of the piston, if it is scored or damaged it means it has probably been run without oil added to the petrol.
That can cause the problems you are having, if it is throw it away, its not worth repairing
Dec 14, 2012 | Poulan 2050 2055 2975 2150 2155 2175 Air...
Diagram for fuel line routing for a poulan 2150 chainsaw?
The 2150 has a remote primer, so there will be three pipes, the pipe coming from the fuel tank with the fuel filter on the end is the main fuel tube, this fits to the connection on the carb nearest to the pump cover on the carb ( alluminium cover held with a single screw ) the other connection on the carb has a pipe to the shorter of the two connections on the back of the primer ( suction side ) the longer connection on the back of the primer ( pressure side ) has a pipe back to the fuel tank, so the primer pulls fuel from the tank, into the bulb, and dumps it back to the tank, it does not push fuel into the carb, this way you can depress the bulb as many times as you like without flooding the engine.
Jul 05, 2012 | Poulan Pro Chain Saw 46cc 20"
Poulan chain saw model #2025 - fuel lines dry rotted and disintegrated. There are 3 fuel lines: l from gas tank and 2 from primer button but only 2 fuel ports on the carb. What goes where and how?
You should have 2 to the tank, the one with filter coming from tank goes to nipple on right side of carb, the nipple on left side by primer bulb goes to primer bulb and other from primer bulb back to tank as return line, how it should work is when you push primer bulb it pulls fuel from tank through carb and back to tank on return line so watch in tank orleave one line out that you think is return line and see if gas comes out when you prime, but remember it goes through the carb first before it goes back to tank, had a pic but too big to put on site sorry, 2StrokeJim
Oct 11, 2011 | Poulan Wild Thing 2375 18" Gas Chain Saw...
31cc Poulan Pro Weedeater
Sounds as though the fuel filter may be plugged. The filter is in the tank. Take a look, see if it is visible. Remove and replace. Good luck...Lee
Jul 26, 2010 | Poulan 25cc 2-Cycle Gas Powered String...
There are 3 fuel lines on my Poulan 2150, 2 - 1/8"...
The 'vent looking device' should be the fuel filter--remove it and make sure it is not plugged. The other end of that line should go to the carburetor inlet port near the top. When you get the line connected, pump the primer several times (tank is filled with fuel mix and the small line returning to the tank is pulled loose from the primer port) to see if it pumps fuel through the carburetor into the primer bulb. If it does not, swap the line from the carburetor to the other primer port and retry pumping again. If fuel fills the bulb, then plug the line from the tank to the vacated port on the primer. This will pump excess fuel back into the tank. Hope this helps!
May 17, 2010 | Garden
Poulan 2150 gas chain saw. How do I connect new primer bulb to carb and gas tank?
Make sure the tank is filled with fresh fuel mix.Try hooking the line that goes to the tank to one of the two primer ports and operate the bulb. If it does not pull fuel in, reverse the connection to the primer and try the bulb again. Once you get fuel into the bulb, move the tank line to the other port. Install a line from the open port on the primer to the open port on the carburetor. Try the primer bulb again, it should pull new fuel from the carburetor if the two connections at the carburetor have not been reversed. This is a kind of 'hit or miss' business when connecting fuel lines that involve the primer bulb. Nothing seems to be marked on the involved parts. Hope this helps
May 15, 2010 | Garden
Poulan 2150 type3 / a show me diagran of fuel line hook up from primer bulb to carburator
I have a McCulloch 3200 chainsaw with a cracked primer bulb and all the fuel lines were gone. I cannot locate any information on routing these lines to the carb. I have a new primer bulb and 3/32x3/16" fuel line. Please help me solve this problem.
Aug 16, 2009 | Poulan Garden
Can't start my Poulan Woodshark Model 1950
Replace the fuel filter. Sounds like you have the primer lines hooked up backwards.
Part list have mod & ser #
http://www.ordertree.com/cms/Illustrated-Parts-List/64.html
Mar 25, 2009 | Garden
I may have lines on Backwards??
filtered line from tank goes into top inlet at carb. bottom inlet receives line that goes to carb side of primer {draw side} 3rd line goes from push side of bulb bach to fuel tank.
Mar 25, 2009 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
Poulan 2150 w/ walbro wt324 carb fuel line reassembly
the fule line that comes from the filter/ pick up will go straight to the nipple usualy the one closest to the middle of the carby.
the other hose comes from the carby to the in or **** side( punp it you can feel it)of the primer and then goes to the tank that is the return/ prime, nothing is conected to it in the tank. if you have the carby one the wrong way around it will not prime. just swap them over..
Nov 24, 2008 | Garden
Garden Logo
180 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
