Question about Poulan/Weed Eater No. 5000p 952711612 Pole Pruner Attachment
It will start and run but backfires thur the carb.
My weedeater will start and run but backfires thur the carb. You can only get to about half throttle before you get a backfire that will kill it. I pulled the flywheel to check keyway no damage. No lose carb to jug or head bolts. Whats wrong? Thanks Bill
  • 71 Answers
SOURCE: Poulan weedeater will only run with choke half way on
this could one or a combination of a few things
1 check inside the tank for dirt 2check that the filter screen inside the tank is not plugged3 make sure the gas feed tube is not restricted pinched in the case or kinked also you can try a simple carb adjustment.also check to make sure the plug is gapped to the right specs good luck and i hope one of these suggestions do the trick
Posted on May 02, 2009
  • 77 Answers
SOURCE: Head Bolts torque
On the trimmers when torqing head bolts down,I dont bother looking for torque specs (theres some people that will shoot me for saying this). I just snug them up and then give each one a one quarter turn tighten up. Its always worked for me.
Posted on Aug 11, 2009
wilsodfarm
  • 986 Answers
SOURCE: whats wrong with my weedeater when the motor will
The cable has either broke or has slip back
Posted on Apr 12, 2010
agent91
  • 2100 Answers
SOURCE: i have a briggs and stratton 14 hp ohv engine on
It sounds like you are putting it into choke mode. The choke is usually all the way up on tractors. And it will make it backfire and flood out. Just rev it high enough to work and don't go into the choke mode. hope this helps.
Posted on Apr 21, 2010
MOTORWIZJ
  • 1363 Answers
SOURCE: One year old Poulan weedeater starts right up but
CHECK THE SCREEN ON OUTPUT OF THE MUFFLER. ITS CALLED A SPARK ARRESTOR, THESE GET OIL FOULED AND MAKE EM A BEAR TO RUN . CLEAN IT UP AND SHE WILL RUN LIKE A CHAMP, THE CARB MIGHT NEED REBUILDING ,FUEL FILTER AND A SPARK PLUG IS THE FIRST THING TO REPLACE .. IF'N I WAS ANY HELP VOTE FOR ME ...THANKS.. JAY
Posted on May 26, 2010
Testimonial: "good advice "
Won stay running
Needs a carb adjustment, cleaning, or possible rebuilt. Try adding a little seafoam and running at half choke for about 5 mins or longer this may clean it up nicely. also check the spark plug.
Nov 09, 2013 | Poulan WEEDEATER FEATHER LITE 1500 GAS...
Weedeater FB25 5months old only used once and was hard to start right from the box. Can't get it to run now. What steps should I take on troubleshooting
This sounds much like poor car settings ( set too lean ) you need to richen up the L and H screw on the carb, unfortunatley there will be anti tamper sleeves on the carb or a special tool reqired to adjust them, turning the screws anti clockwise will richen the mixture if you manage to remove the caps or get hold of the apropriate tool.
Dec 14, 2012 | Weedeater 25cc Gas Blower ()
WeedEater FL 1500
if the choke needs to stay on to run it then there is a plugged jet in the carb
Aug 11, 2012 | Weedeater Garden
Engine backfire
try fresh fuel then take apart the carb and clean it
Mar 24, 2012 | Weedeater Excalibur Gas Hedge 22" Trimmer...
It just quit running and not when i try to crank it it trys to fire but backfires thur the carb
Sounds like a float problem but do a complete carb overhaul and if OHV engine do a rocker clearance check. Watch video at smalleng.com Good Luck...
Aug 16, 2011 | Cub Cadet Op's Manual Model Lt1042 Lt1045...
Weed eater starts and idles after it warms. When I accelerate it sounds like it is choking itself out or it is starved for gas then stalls.restart and it does it all over. Sometimes it stalls when i go to...
Take out carb and spray with carb cleaner through and into all portals. Blow out with air compressor.and reassemble.
Adjust idle and low and high mixture screws according for proper operation.
Aug 31, 2017 | Weedeater Set (Weedeater)
I have a Weedeater fl 1500 le leaf blower that won't run wide open. It will start, but it has to remain at one half to three quarter choke to remain running. Changing the throttle opening seems to make no...
Simple solution your weed-eater has a Walbro carb buy a rebuild kit and rebuild the carb and it will run like new, don't touch any screw settings on the carb. You can purchase from your local repair center just give them the number on your carb and they will give you the correct kit. Go to smalleng.com they have a video on just this issue. Good Luck.. Don't forget thumbs and feedback.
Apr 02, 2011 | Weedeater 2 Speed Gas Blower FL1500LE ()
Craftsman weedeater will not start
The most probable problem is no fuel delivery to the engine.
1. Check/replace the fuel in-tank filter, you should be able to easily blow through it once removed. The primer bulb will sink down and not return quickly if the filter is bad. Fuel will not return to the tank via the return line if the fuel filter doesn't allow fuel to be pulled in.
2. If fuel is returning to the fuel tank when the primer is pushed then your problem is inside the carb.
3. To verify this put a small quantity of gas in the lid of a water bottle (half full). And pour it into the carb throat. Replace the air filter to prevent a backfire from shooting flames out. Try to start the weedwacker. If it runs and then dies the problem is inside the carb.
4. If you are really good at working on things with small parts you can clean out the carb and replace all of the gaskets to solve the problem. If this isn't for you then you should take it to a lawn shop and have them clean the carb and replace the gaskets.
NOTE: Replacing the gaskets is very important because the gaskets get stiff and the fuel pump action of one of the gaskets is reduced or stopped.
Hope this helps, Karl
May 20, 2009 | Craftsman 25cc Gas Line Trimmer
May 02, 2009 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
My featherlite weedeater will only turn up on half choke?
you have to adjust the h or highend carb screw. start up your engine on full choke adjust the screw up or down untill u can run it without choke
Apr 21, 2009 | Garden
Poulan/Weed Eater No. 5000p 952711612 Pole Pruner Attachment Logo
476 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
