Question about Sharp SD-AT1000H System
Sharp SD-AT1000H We recently got this system, but we didn't get the remote. When we try to power up the unit, it will power up and shut off right away. Any idea what the problem might be?
  • geokass5555 Jul 09, 2008
    y have the same problems what can i do
I had this problem with mine and found it was very sensitive to anything being placed on top of it. Even dust on the top surface would set it off, so cleaing off the top sometimes helped. Eventually I took the top off and there is a piece of metal that contacts with the case. I bent that back slightly and it seemed to do the trick.
Posted on Oct 18, 2008
I am having the same problem...the manual says to un-plug the unit for five minutes and then plug it back in to re-set, but that is not working either...
Posted on Jun 30, 2008
I need a remote control for my sharp SD-AT1000H, I don't mind either new or used one.
go e-bay and type in the remote brand and model in the search bar
Aug 13, 2016 | Sharp Televison & Video
Turns off
Based on your post description, a short was introduced to the output of your system (wires touched). Since you were playing at a high level and the touching wires represents a 0 ohms load, there is a strong possibility that the power amplifier burned (too low a load at too high an output). The burnt component then represents a failure. When you try and power on the unit, it will go to its built-in diagnostics/initialization stage where it will sense the fault and thereafter go to auto-protect (shutdown).
Corrective measure would involve opening the unit and performing diagnosis of the circuitry and components check. Since these call for familiarity with electronics, use of a DVM and a soldering iron, perhaps your best course of action would be to seek the services of a qualified audio technician. Should you venture a do-it-yourself, you would need to concentrate on the audio amp, specifically the finals or outputs which could be a large power IC or a MOSFET pair. Determining which is at fault would simply be removing suspected component and verify that the unit will power on albeit any sound output. Of course the usual precautionary safety measures apply when working with live units.
Hope that this be of some help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Nov 05, 2007 | Sharp SD-AT1000H System
How do i turn off the demo mode, the radio shuts off automatically after about 10 min
try this:
If you have the remote, press the "demo" button.
If you don't have the remote, press and hold the power button for 10 seconds while the unit is on.
http://files.sharpusa.com/Downloads/ForHome/HomeEntertainment/Audio/Manuals/aud_man_CDDH950P.pdf
Oct 13, 2014 | Sharp CD-DH950 5-Disc Compact Stereo...
Stereo turns on shuts off after few seconds
This is a bad power supply. You have to do some serious work at the component level of the unit to fix it.
Jan 22, 2014 | Sharp Electronics - Xldk257n - Xl-Dk257n...
Sharp,Aquos, LC-37D64U,Power & Sound, No picture?
try replaced main board
Manufacturer Sharp Part Number DUNTKE373FM03S Description P.W.B.UNIT
Jun 03, 2010 | Sharp LC37D64U 37 in. LCD HDTV
Toshiba home theater SD-KT50SU shuts off "PROTECTION"
Ok what this means is that some wires are touching in the back of unit causing a short (your system is protecting itself) look for wires touching and make sure its hooked up right
This should fix ya!
Dec 13, 2008 | Sharp XLDV60H Shelf System
SCHEMATIC
You can find the service manual in the link below.
SD-AT1000H Service Manual
Mar 13, 2008 | Sharp SD-AT1000H System
Sd-at1000h surround system
I have the same problem. Powers on for 1 sec displaying "hello" and powers off.
Oct 25, 2007 | Sharp SD-AT1000H System
Sharp SD-AT1000H System Logo
539 people viewed this question
Top Sharp Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sharp Audio Player and Recorder Expert? Answer questions, earn points and help others
