Agit dogs How do I change the dogs?
  • 64 Answers
Take top of agitator off reach inside and pull plastic cover out take out 7/16 screw and lift whole agitator off . turn upside down and take dogs and holder out. Watch how dogs come out and put the new ones in the same way. Reverse procedure to put back.
Good luck
Posted on Apr 24, 2010
Tip
This is very helpful, accurate information. It helped me to replace Agit-dogs on...
The following advice is for replacing the “Agitator Dogs” on Kenmore and Whirlpool TOP LOADER style washing machines. This simple repair can save you a fortune in repair costs as the replacement parts are very inexpensive at a cost of less than $10. The replacement kit part number is 80040. You can order on line at various appliance parts websites, or use this part number and go to your nearest appliance parts retailer.
What are “Agitator Dogs”? These are small plastic pieces (usually 4) that are located under the agitator center cap that grip the agitator and turn it during the wash cycle. They can (and do) wear out dependent upon the use of the washer. If you are in the habit of doing large load sizes frequently, or wash large items such blankets or afghans, this can wear the teeth off and reduce the life of the agitator dogs.
SYMPTOMS REQURING REPLACEMENT: The agitator fails to turn during the wash cycle, or will not turn with a heavy load. The timer will run normally through all cycles, and you will be able to hear the gearcase (transmission) engage and run. The washer will also drain normally. The only indication that something is wrong will be the agitator slipping or not turning at all. The result will be clothes that do not wash properly and will sit on the bottom of the wash tub.
To replace the Agitator Dogs, follow these steps:
  1. Remove the agitator center cap by either pulling straight up or gently placing a flat blade screwdriver into a slot located in the cap.
  2. If the agitator is equipped with an inner cap with a handle, remove this as well by pulling straight up.
  3. Remove the center bolt of the agitator. You will have either a 7/16” hex bolt or a recessed square plastic nut. If you have the square recessed type, use a 3/8” to ½” ratchet adapter to remove.
  4. Remove the agitator by grasping the bottom flange and carefully pulling straight up. Try to keep all the parts assembled while doing this, so do not pull too hard. This will make this repair much easier.
  5. Place your hand over the top of the agitator and separate the upper portion of the agitator from the lower portion and turn the top half over in your hand. The agitator dog assembly will come out in your hand.
  6. With the agitator dog assembly in your hand, lay the rest of the agitator aside. Pay careful attention to how the dogs are installed. Remove the worn dogs and reinstall new ones. It’s that simple.
  7. With all the dogs replaced and the assembly still in your hand, place the upper part of the agitator over the top of it, upside down, ensuring the inner assembly tabs align correctly.
  8. Now keep your hand over the agitator top to hold all the pieces together and turn the entire assembly over (upright position).
  9. Carefully align and reinsert the upper portion of the agitator to the lower portion. Again, making sure the two pieces align correctly.
  10. Place the entire agitator assembly back on the gearcase shaft and reinstall center nut. NOTE: DO NOT over tighten the nut, or the agitator will not spin correctly. Just make the nut snug. Reinstall center cap and inner cap (if equipped).
These instructions should give you the basics on how to perform this repair. Since there are various agitator types in use by Whirlpool and Kenmore, assembly can vary. If you get confused and require further assistance, please refer to my profile at http://www.fixya.com/users/jsrock516 and use the “Ask Me” feature. For excellent diagrams to assist in reassembly you can also refer to the searspartsdirect.com website. Just type in your COMPLETE washer model number and look under the Agitator Parts heading. I hope this information is found to be helpful.
on Dec 16, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Hello. We have a Whirlpool Ultimate Care Heavy
yes you r. lol
the agit. dogs need replaced look in your phone book 4 a dealer near you to get this part you need. remove softner despenser and inner cap then you will need to remove bolt 7/16th or 3/8th after removing bolt pull up on agit.it is 2 pc if it all comes out as one pc. ok you need to stand on lower 1/2 and pull up you now have the top pc in your hands. you will see some type of cup that holds in the dogs remove by flipping up side down install new parts and put back togther a small tip use the bolt
to put cup back in when you are ready to put back together put top pc of agit. over cup up side down you will need to line up with 2 or 4 ears on bottom pc. it should click now reinstalle sound hard but very easy just keep preassur on dog cup at all time with bolt and socket have fun
Feb 10, 2010 | Whirlpool Washing Machines
Agitator is loose, won't spin
replacce the agit dogs part number 80040
Jan 27, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
How do I replace the CAM-AGIT on a Whirlpool Washer Model #395165
you have to remove the cover inside the upper agitator first, then you will see a plastic cover inside the top. it has 2 raised handle type tabs to pull on, then remove the cover and under it you will find a 7/16 bolt to remove and that will allow you to pull the tophalf of the agitator and change the agitate" dogs "
Dec 31, 2009 | Washing Machines
Top of agitator does not turn but the bottom does
If this is a Whirlpool manufactured washer, the problem is very simple, inexpensive and easy to repair.
Whirlpool has a split agitator design. The upper portion is called the auger, while the bottom is called the agitator. Between these components is a agitator cam assembly. This problem is commonly caused by worn agitator dogs or the agitator cam assembly. The following link explains what the dogs are and how to replace them:
http://www.fixya.com/support/r3608577-replacing_agitator_dogs
The part number is included in the link provided. You can purchase replacements at pcappliancerepair.com for about $5. For a little more you can purchase the entire cam replacement kit, which includes the cam, the thrust bearing, and the dogs for about $11 or $12.
NOTE: You can refer to the excellent exploded view parts diagrams the web site has to offer for assistance. Whirlpool also recommends the application of a little grease on the thrust washer. The part number for their recommended grease is AP3098553.
If you have any questions about this repair, please post back with your complete model number (located on a nameplate along the wash tub opening under the lid) and let me know. I hope this helps you.
NOTE: DO NOT overtighten the agitator bolt. This can cause damage to the plastic, or restrict the agitator movement. Tighten until snug only.
Dec 23, 2009 | Washing Machines
Not agitating
does it have the dual agitator
Aug 06, 2009 | Amana NTW5205TQ Top Load Washer
Dog Agit replacement on a Kenmore washing machine?
Take the top cap off the agitator.
Remove the plastic cover inside.(use pliers to pull it off).
Remove the bolt.
Pull the top half of the agitator off.
Replace the dogs.
Re-install the agitator.
Mar 08, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Agitator disassembly
take the disp out, remove the inter cover, take out the 7/16 screw, pull agit up from bottom to take out of washer, set on floor, put feet on bottom of agit and hold top fins and pull up hard and quick, will come apart, after putting new dogs hold agit upside down to put back together or dogs will keep falling out and put back together / please remember to leave a rating / have a good day.
Nov 27, 2008 | Washing Machines
I have a Roper RAX7245BWO that the top of the agitator is loose and doesn't agitate. I know I need to replace the cam dogs. What I can't figure out is how to get the inner cover (part #20 on the agitator...
Washing Machines Logo
56 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
