Question about Garden
My weed eater wont start. i had it for 5 years and it got spark the other day but not anymore. how do i fix it??
  • 54 Answers
Are you checking at the plug or wire. After 5 years you may have fouled the plug in your attempt to start. In that case it won't fire.
Posted on Apr 26, 2010
Weed eater fb25 25cc gas blower wont start
change the spark plug--put fresh fuel in gas tank 89 octane mix
Sep 04, 2014 | Weedeater Weed Eater Fb25 25cc 2 Stroke...
Why weed eater wont stay started
  • #1 - Change Fuel Filter
  • #2 - change or clean Spark Arrestor
  • #3 - Change or clean Spark Plug
  • #4 - Clean carburetor
Order of importance, Start at #1 and work forward.
Look here...
Jul 22, 2014 | Echo Garden
Toro weed eater starts but then stalls out
A few things to check, clean or replace:
  • fuel filter - located inside the fuel tank
  • Spark arrestor - located at muffler
  • Spark plug
  • Carburetor
Mar 08, 2014 | Garden
Poulan prolink pp335 wont start
In case anyone else hits this question, I had this weed eater and all of the attachments. I had it in my garage for a good 7 years, and it had gas in it 7 years ago.. I've known for some time that it now had no gas in it & that it wouldn't be easy to start if it worked at all.. I put some normal gas in it and dripped a bit of oil into the gas because i didn't have a can properly mixed and didn't want to oil up my lawn mower gas.. I had a guy cutting my lawn for the past 7 years but he recently disappeared..
I primed the weed eater and attempted to start it for a good 20 minutes yesterday to no joy.. I put it away and figured i'd try it again and more in depth today when I had more time. I wanted to take the spark plug out and make sure it was clean, etc.
On attempting to remove the spark plug, I couldn't find a wrench or socket that would work to do so, so I just reconnected spark plug cable and figured I'd give the pull start method another try.. I pumped more gas into the primer and attempted to start it normally a few times.. It wouldn't even attempt to fire. Just for fun since I was going to have to throw this and tons of never-been-opened attachments away, i decided to try something goofy (in my opinion) and squeezed the trigger as far as it would go (which disengages the choke feature..) and gave it a few pulls on the cord.. It attempted to fire a few times, then it fired! It worked very well although it was a little bit thick on the smoke for a bit..
Maybe this answer will help someone else who hits the problem of leaving gas in a weed eater for years.. don't use the choke feature to start it.. start it at full throttle with the primer perhaps flooded a little bit..
Apr 01, 2012 | Garden
My weed eater starts but won't stay running. what
Try a new spark plug.Thanks for asking and I hope it helps
Jul 19, 2010 | Poulan/Weed Eater #Wt200 711724 24cc Gas...
Having a problem starting my Shindaiwa T22 Weed Eater.
take the spark plug out and pull the engine over with the spark plug in the wire and ground the plug to the trimmer and see if it sparks. if not flip the switch the other way and see if it sparks then you shall know.
May 02, 2010 | Poulan Weedeater/Electric Trimmer 4.1 Amp
Chaged gas and spark plug. Get no combustion
Make sure your getting a spark at the plug. Not much to these machines but verify good spark before anything else.
Nov 07, 2009 | Poulan/Weed Eater #Wt200 711724 24cc Gas...
I have a snapper S31SST weed eater. It is 4-5
Remove spark plug and check for fire with a spark tester. (some inline models are also available and safer since the spark plug stays in place using those types)
If no spark:
Remove covers and unplug small kill-circuit wire(s) from ignition coil...Test for spark.
If you have spark the switch needs replacing.
If you have no spark the coil needs replacing.
Hope this helps.
Sep 26, 2009 | Garden
My te 475 weed eater wont start
Check the on-off switch? Try disconnecting the switch and see if it starts. If it does, replace the switch.
May 18, 2009 | Poulan/Weed Eater No. Te475 952711797 17"...
Garden Logo
81 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
