Question about Price Pfister Savannah Two-Handle Kitchen Faucet with Matching Spray ....
Leaking at the base of the riser spiggot and tends to have air/water mixture when turning on hot or cold water. The faucets are not leaking and the leak is at the base where the spiggot attaches.
  • 349 Answers
Some have washers at base of spout.
Posted on May 05, 2010
Fixed leaking faucet, now handles leak at the base & the water pressure is low
No, air can't get trapped in there. I don't think you did anything wrong. It sounds like the valve or internal parts are worn more than new washers take up for. Tightening down the valve just reduced travel for valve to open fully. Can't think of a fix; where's that joe da plumber?
Nov 23, 2011 | Plumbing
Solaris Model #06544860 leaking under the sink. How do I remove and how do I figure out exactly what is leaking?
The first thing I would do is to locate source of the leak. Look carefully at faucet when it is on and see if you have any water leaking from areator and running back down the underside of spout and leaking around base of faucet, also see if you have any leaks around handle. If the leak is from the areator you can just replace it and not have to remove the faucet. when you check under sink on faucet supply lines make sure they aren't leaking at that point. I would use paper towels or rags to wipe everything dry under faucet and let it set for 1/2 hour then check again. If it.s still dry run some water and use both hot and cold water seperatly,checking underside in between. If you determine that leak is coming from top side and leaking thru. Shut off water supply valves if available if not shut off supply to house, make sure water is off before proceeding. Disconnect supply lines from faucet,Remove retaing nuts on either side of base,and remove washers. Remove faucet and check for any obvious faults. If you think it was leaking around base get a small tub of plumbers putty. Most hardware stores stock it. Remove a golf ball sized portion or larger and knead in your hands until it is warm and pliable. Press into place in faucet base. Continue doing this until it's full. Reinstall plastic or rubber base gasket and put faucet back in place Put washers and retaing nuts back on a tighten till snug. Center faucet where you want it and tighten securely. Scrape off excess putty with knife point and wipe with paper towels till clean. Hook up supply lines and turn water back on. Check for leaks and good luck. Thank you
Nov 27, 2010 | Hansgrohe 06649860 Solaris Single Hole...
Constant slow leak
more than likely hot side that is leaking as hot water tends to soften washer...try shutting off hot water angle stop under faucet...if drip stops it the hot water.. try pulling handle off and tightning nut that hold stem in place..
Nov 21, 2010 | Hansgrohe - Lavatory Faucet - Centerset -...
Turned off the hot water to fix a leaking tap. now the tap has no hot or cold water and the hot water tank valve is leaking?
It sounds like two problems.
Problem 1) Clog inside faucet or clog inside pipes at faucet
Remove supply tubes leading to faucet and see if problem is inside pipes or inside faucet.
My bet is clog inside faucet.
If you have galvanized pipe that meets copper pipe, this can be trouble spot.
Article on clogged water pipes at Inspectapedia:
http://www.inspectapedia.com/water/Water_Pipe_Clog_Repair_Guide.htm
Article on clogged pipes:
http://www.waterheaterrescue.com/pages/WHRpages/English/Troubleshooting/Tanklets/backflushing.html
Problem 2) Water heater leak ... you say tank valve is leaking? Is that cold-water shut-off valve? Or tank drain valve? Or TP valve?
If cold water shut-off is leaking, then replace shut off.
If tank drain valve is leaking, then check if plastic valve is cracked. If drain valve is cracked, then replace with a brass valve from Home Depot. If plastic valve breaks off, then use hammer and screwdriver to gently chip out the broken plastic valve. New valve threads need teflon tape to seal pipe. If valve is just dripping, then put garden-hose cap over end of valve and screw down tight.
If TP valve is leaking, then replace with same temperature and pressure rating.
New TP valve threads need teflon tape to seal pipe.
Problem 3) If pressure is low all over house:
Buy pressure gauge at hardware store that screws onto hose connection.
Test pressure on outdoor spigot.
Open faucet and check if pressure drops. This says if problem is inside pipes that enter house.
Test pressure on water heater drain valve.
This says if pressure problem is before -or- after water heater.
If problem is before the water heater, then shut-off valve located on cold water line is suspect.
If problem is after water heater, it could be in hot water outflow pipe on top of water heater, or a nearby elbow.
Remove hot water line leading from water heater and check pressure. This says if problem is where hot water leaves tank.
Read articles above about clogs inside water lines.
Nov 16, 2010 | Rheem Water Heater Pressure Relief Valve
My grohe faucet leaks when turned on from around the base of the device where it goes through the counter top. Wiggling the spiggot makes it leak worse. It is 4 years old The cartridge looks clean. It is...
There are two O rings in the spout body that need to be replace with new and lube the
new O rings with vaseline. If your water is too hot, this will dry out the O rings. Normally
your hot water shouldn't be more than 120 degrees F. You can check this by holding a
thermometer in the stream of water with the hot on only.
Grohe has a lifetime warranty on them. I have taken many Grohe's back to the wholesaler
and they just give me a new one, no questions asked.
Nov 02, 2010 | Grohe Plumbing
Mixer tap makes a noise like a fog horn when cold water turned on
Usually happens when the stops and not ballanced(hot and cold pressures going to the faucet). Try ajusting the stops; open more on the hot or close more on the cold.
Feb 04, 2009 | American Standard Plumbing
Leaking Kitchen Tap
I am assuming that your kitchen tap is leaking through the spout
if it is single lever you will need to remove the crown and spout by removing a small erasure size cap on the housing right under the spout or up near the back of the ever then use a hex wrench to remove the set screw( plug the drain holes do it does not go down the drain)
turn the water off (hot and cold ) under the sink
remove the set screw and lift off the lever
at his point you can take an adjustible wrench(channel lock and tighten the big ring nut that holds the cartridge in place
temorairly put the handle back on and put the handle in the off position turn the water on under the sink and see if it stopped leaking
if it still leaks you have to turn the water back off and remove the lock nut then the cartridge and go to big box store with old cartridge and name of mfg and get a new one and install
If you have seperate hot and cold valves on top of sink deermne which is leaking by turning one off with oher on undr the sink
once you have determined which it is (hot or cold)
take a phillips head screw driver( remove plastic clear cap on top of faucet handle with sharp crewdriver of knife blade) and remove the screw holdin the handle on to the stem(turn counter clock wise
be sure to turn water of under snk on both faucet risers after removing acrylic handle you then take an adjustible wrench and remove the crown nut turn counter clockwise until it comes off over stem
remove stem( looks like size of a pretzel about six inches long with washers on side and one on end
take the stem to local hardware(ace) or big box store and go to lumbing section ask clerk to inspect and recommend replacement washers or replacement stem (if needed)
go back reinstall and tighten crown nut snug( open (turn counter clockwise) tem valve before you snug it down with crown nut
install acrykic or chrome handle with brass phillips screw then ut cap on and turn on water and check for leaks
good luck
Dec 30, 2008 | Home
Price Pfister Savannah Two-Handle Kitchen Faucet with Matching Spray .... Logo
554 people viewed this question
Top Price Pfister Plumbing Experts
bwbconstruct
Level 1 Expert
john h
Are you a Price Pfister Plumbing Expert? Answer questions, earn points and help others
