Question about McCulloch Garden
Chainsaw only runs when i take off the air filter and keep it at high revs,as soon as i take finger of the trigger it cuts out and wont idle.ive already cleaned out the carb,checked fuel,cleaned filter and spark plug
  • Juston May 11, 2010
    Have you adjusted your jets?
    President:
  • 2,220 Answers
It sounds rich to me try turning the "L" needle CW a little. CAUTION CW is leaner, to lean will destroy your saw. Adding the air cleaner leans out the mixture. Adjusting it with the air filter off can cause a run lean condition when installed.
Carburetor Adjustment by Madsens.com
http://www.madsens1.com/saw%20carb%20tune.htm
  • CW is leaner; to lean will destroy the saw. If over tightened closed (CW) the adjustment screw faces are easily marred; marred adjustments are difficult to impossible to set properly.
  • Clean the air filter; adjusting with a dirty filter can cause a run lean condition once cleaned and the saw run.
  • Clean the spark arrestor and muffler; if the saw cannot exhale it cannot inhale.
  • There are 2 wav (sound - idle & full - may not be highlighted) files that I find most helpful, I think you will too.
If you have more questions or need additional help please reply below and I will get back to you. Good Luck. HTH
Lou
Thank You for using FixYa.
Posted on Apr 24, 2010
Chainsaw want idle why?
Try adjusting the idle 5crew on the carb. Its usually marked with an [ I ]
To get it just right, make sure your chain brake is off, screw in the idle 5crew, the saw will rev and the chain will start to turn. Now back the idle off until the chain stops moving and the engine is ticking over nicely.
May 04, 2016 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Poulan chainsaw, I rebuilt the carb with all new everything. Now it will start with choke all the way out. Idles really high. If I push choke in, it dies instantly. The hi-lo and Idle is off I know for...
get it running on idle,adjust the idle down till it runs hairy,then adjust low speed mixture screw till you get it highest revs,then keep repeating that till you get it idling normal.rev saw up max revs,adjust high speed jet, in or out till you get max revs,then screw out one quater of a turn.That lets enough fuel thru to cool the sparkplug tip..If thats no good,redo the carbi.Check the tiny filter under the needlevalve hole.Check the needlevalve diaphragm height.recheck gaskets are right way round
Nov 03, 2013 | Husqvarna Chain Saw 20" Bar
My chainsaw will run only full throttle and when you let of of the trigger it wont idle it will die
Hey on the carburetor there is 2 mixture screws 1 is for idle up to 1/4 throttle the other is for 1/4 to full throttle the one for idle is closest to the engine. screw it all the way in then unwind it 1 turn. The screw the furthest from the engine screw it all the way in then unscrew it 1 1/4 turns Try to start the saw with just a little throttle. this setting is pretty standard. When you get it to idle then rev the saw and it cuts out as it returns to idle it's running to rich. Just adjust the screw in a little say 1/8 at a time. When it's to lean as soon as you throttle on it will stall. If you have no luck with this...you have a air leak from the carby gasket or the bolts are loose or a blocked exhaust
Oct 14, 2013 | Earthquake Gas Chainsaw, 14 inch CS3814...
Wont stay running. it idles kinda high. stays running with the choke on. pull the trigger 2 giv it gas it dies.
Check the fuel filter, air cleaner, and muffler for plugging. Check the fuel lines for decay or other problems. The idle speed screw (turned CCW) will slow the engine down. Hope this helps!
Nov 08, 2010 | Poulan Pro Chain Saw 46cc 20"
Engine dies upon acceleration after starting and idling
turn the high speed and low speed mixture screws right in[gently]then out 2.5 turns.start it up,screw the idle screw up till it will idle,then adjust low speed mixture screw in or out so you get the highest idle.keep lowering the idle so as you adjust the screw,it wont get it any higher in revs.so by now it should idle.next,open the throttle wide,and adjust the high speed screw until you get maximum revs..then,turn screw 1/4 turn out.that makes it slightly richer,cooling the plug with droplets of petrol.you dont want it lean.if it wont rev fully,check the fuel filter.they get dirty quite often
Jul 02, 2010 | Echo 30.1CC Chainsaw With a 14 In.bar and...
My Poulan will start and run fine, but when i give it gas it revs up and dies every time. Ive messed with it some, and ive noticed if i close the choke right before it dies, it keeps cutting, but i have to...
Afternoon Jacob;
If you must choke it for it to run it is to lean. Have you cleaned the air filter? Might be good idea. An air leak can also cause this inspect the intake for a loose or defective connection at the engine or carburetor.
If these are good try to adjust the "H" needle valve CCW (richer) a little.
You can find a very good description of adjustment here:
There are 2 wav (sound - idle & full – may not be highlighted) files that I find most helpful, I think you will too. Good Luck
Lou
Jan 16, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
High / low speed jets both turned into base completely, how many rotations out before fine tuning for performabce.
Hello:
>>The Following is the Instruction File for Setting the Air Mixture Screws. Any Input is Appreciated. The Procedure is the Same for 1 or 2 Mixture Screws, Just Use the Instruction File and Skip Over the Section with the Missing Mixture Screw ( Usually the H Mixture Screw).
>>Now Setting the Air Mixture Screws:
>>****Turn the Idle Air (L) and Main Air (H) Mixture Screws In Until SNUG **Do Not Jam** Then Reverse Both Screws 1 1/2 Turns. Set the Throttle Full Open, Start the Engine.
>>Turn the Main Air (H) Mixture Screw Clockwise Until Proper Revs are Obtained. **Carefully Use your Finger and Move the Governor Arm to Rev the Engine (on Chainsaws and Trimmers Use the Trigger to Rev the Engine) Until you Reach Max RPMs (on Chainsaws and Trimmers, the RPMs are Not Set to MAX. Set to Max and then Reverse the Setting Screw 1/4 or 1/2 Turn. If the H Mixture Screw is Set too High; the Engine will be Starved for the Oil in the Gas and Damage the Piston and Jug/Cylinder) and the Engine is Running Proper at Full Throttle Up a Grade and for Chainsaws and Trimmers they Do Not Bog DOwn Under a Load. Occasionally you May have to Turn this Counter Clockwise to Achieve the Proper Revs.**
>>Now Allow the Engine to Idle. Set the Engine Idle Screw (Not Idle Air) so the Engine will Stay Running if Required.
>>Now Set the Idle Air (L) Mixture Screw so there is No Hesitation when Rapidly Throttling from Idle to Full Throttle. Reset the Engine Idle if Required.****
Please, Do Not Hesitate, If I Missed Something or you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
May 15, 2009 | Garden
Echo CS440 wont idle when warmed up
Check for air leaking at cylinder to block.gasket.
Mar 18, 2009 | Echo 30.1CC Chainsaw With a 14 In.bar and...
My 345 chainsaw bogs down when it hits wood
There are two idle screws one high, and one low. Your high adjustment idle screw needs to be adjusted.
Jan 18, 2009 | Husqvarna Forest & Garden No.967012396 345...
Idle is off??
hi leobowdy
disassembly the carb and carefully clean it.Check the air filter,the fuel line and fuel filter,check the needle,lever,small spring and the screen filter from the carb.Check the sparkplug.
high speed H=2 turns,low speed L=2 1/2 turns,adjust T
When chain saw starts adjust H,L and T accordingly.
cheers savumihai71.
Nov 22, 2008 | Ryobi Factory Reconditioned 18" 40cc...
Garden Logo
138 people viewed this question
Top McCulloch Garden Experts
Roland W VanLue
Roland W VanLue
roeb
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
