Question about Xerox Office Equipment & Supplies
I am getting : drum error code 091-916 in xerox workcenter pro 128
3 Suggested Answers
  • 2072 Answers
SOURCE: I bought Xerox Workcenter Pro 123 a year ago. One month later had a stroke and cannot remeber admin user ID or password. How can I reset?
Go to Xerox.com. Click on the Support and driver section.
Type in 123 in the search box. Then when it comes up, select Drivers and Downloads, then on that site you can click on Documentation and download the User and Admin Guides. That way you can have that info at your fingertip.
The default code is 1111, or 11111. 4 or 5 ones.
Posted on May 04, 2009
SOURCE: Xerox 7232 and As400
016-799 is a printer paper conflict error. All you have to do for the AS/400 to print, is to make suree that tray 2 in the printer is set up to do landscape printing. There has to be at least one tray for portrait, and one for landscape in order for the AS/400 to print.
Posted on Sep 17, 2009
Xerox workcenter 7345 erore code 009-383 ?
Your is an "ATC error" indicating that the density test has failed for Black. There are many possibilities, but here are the top 5:
1) Dirty or defective ATC sensor (130K63000) (difficult to reach..recommended to be done by technician)
2) Defective Developer (802k60194) (also difficult) You also need Developer Charge Powder (604K22550)
3) Defective ATC Clutch (121K23270) (also difficult to reach)
4) Drum (013R00624) not turning, or bad drum
5) Drum motor (007K88604) not turning
xerox and tektronix dell canon konica minolta qms samsung lexmark okidata...
Feb 07, 2016 | Xerox Office Equipment & Supplies
HOW TO RESET ERROR CODE 04-562
Not a copier guy here BUT came up with this
1) From here
http://www.copytechnet.com/forums/xerox/43094-error-04-562-workcenter-pro-c3545-print.html
It sounds like 'Image Belt Transfer' whatever that is.
'you can enter in serice mode on this model only with laptop and xerox wcp diagnostic navigator'
2) from Zerox here. http://www.support.xerox.com/support/workcentre-pro-c2128-c2636-c3545/support/enus.html click on fault code search , put in code.and......
'Needs further customer support.'
Sounds like a 'belt' inside the machine broken or faulty.
Hope this assists you.
Sep 16, 2014 | Xerox Copier Toner, C2128, 2636, 3545...
Xerox 7120 error code 093-320 reset
bonjour j'ai un code erreur sur ma xerox workcenter 7125 je trouve pas de solution si qlq px m'aide merci d'avance code 093-320
Feb 05, 2014 | Xerox DocuColor 240 All-In-One Laser...
Buna ziua, Am o mica problema. Am un echipament Xerox Workcentre 128 Pro, am instalat un sistem de operare Windows 7 pe x64. Problema este ca nu reusesc sa setez imprimanta sa imi scoata fata verso....
In Windows 7 - Duplex printing in Xerox Workcenter 128:
Go to the printer in your printer folder in control panel. Double-click on it then select menu option named "Printer" and click "Properties". Hope it helps you. It worked for me.
Sep 06, 2011 | Xerox WorkCentre Pro 123/128 Printer
FAULT CODE 124-373 ON WORKCENTER 5225 WILL NOT CLEAR
Xerox 5225 keeps showing error 124-373 and cant one to enter into set-up or status mode.How to correct this error?.I have jobs to copy for urgent meeting soon.your email is needed
Aug 28, 2010 | Xerox Workcentre 5225 / Copier, With...
Xerox workcenter transfer belt error
Yes, if you can get the unit out and replace the bealt. With the right tool and parts....... Just kidding you may be better calling a service person.... you may cause more problems and it will cost even more. I would let them do it and get a warrenty with it.
Aug 22, 2008 | Xerox WorkCentre PRO 128 Copier
Xerox workcenter pro 765 error 22
That is a fuser not reachine tremperature fault.
Most likely the fuser will need replaced.
Go to google and type in "the parts drop".
Call Britt and he should be able to fix you up with that part for a fair price.Just tell him the model number and code.
Aug 18, 2008 | Xerox Office Equipment & Supplies
212 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
