Question about Psi Blue Max 2200 High Pressure Gas Power Washer
The pull cord on my pressurewasher just broke How do I fix it?
  • 57 Answers
Usually you have to take the shroud that contains the recoil starter assembly off to get to it. You may have to take it apart to fix the rope. If it broke on the end nearest the starter, you probably have enough rope left to reuse it. Usually they break right at the starter, due the the constant bending and rubbing. Pay attention to how it comes apart, and make sure to rewind your spring before putting the rope back on the pulley, otherwise it will not wind back up.
Posted on Apr 24, 2010
You can order a new assembly from the manufacturer, Homier. 260-356-9477
Fix recoil when pull cord on sanli lawnmower broke
Take the starter assembly off the mower. Unwind the spool using whatever method works (2 screwdrivers?) until you capture the remaining. cord. Pull it all the way out. Pin the spool so that it can't retract. Remove and replace the cord. Re-assemble. Back to cutting grass!
Mar 15, 2015 | Garden
The pull cord on my Cub Cadet OHV 173cc self propelled mower broke.. I'm somewhat handy and should be able to fix it myself, however I've never done this before. I have the engine housing...
Yeah I got the same problem. My pull cord broke in the first season. On my own once the plastic cover is removed, 4 phillips screws, the cord housing is secured by 3 10mm nuts. Remove them and lift out the housing. On my own unit the spring had also slipped out of the mount on the shaft securing the assembly (another 10mm socket nut will loosen that). I used a Briggs and Stratton cord from another (truly dead) mower and have had no problems since then. I am not sure why folks are giving you spark plug settings when you are asking about the cord. :)
Aug 14, 2011 | Mtd 19 In. 173 CC OHV 3-In-1
We broke the pull cord and after pulling the cord won't recoil to proper position.
remove the cord assembly ,, either the cord is off track and needs to be rewound or it broke and needs replacement
Jul 16, 2011 | Toro Super Recycler Super Bagger Lawn...
I have a craftsman push weedeater and the pull cord broke and I want to know how to reinstall so the cord so it will work. I have taken the cover off and fixed the cord and put everything back together but...
you will need to pull the shroud back off, turn shroud upside down, wind it up and with a screwdriver or another pair of hands thread the cord back through, tie a knot and burn it, let go of the it, it will wind the cord back in, pull on it a few times and make sure it is working, then reinstall. Hope this helped Tim
Mar 12, 2011 | Garden
I have a yard machines 31cc y28 17'' how do I fix the pull string it is pulled out fully
Take the top cover off, You should then see 4 bolts around the engine cover, take these out and the cord head will come of,Depending on where the cord broke is the question of using the same cord, But if you're getting a new cord you will need to thread the cord into the eye for the cord, Tie a knot to prevent it pulling apart. then tie your handle on. After this you will wind the cord up tight on the pulley and a screw driver holding the pulley from moving while you put the cord and cap back on the engine, You can then start back installing the bolts and the other cover..
Aug 28, 2010 | Yard Machines 21A240M000 Garden Tiller
The rope does not retract when the cord is pulle... how do I fix it
Has the cord been replaced? If so, when the old one broke, the spring will completely unwind. The trick is to rewind the spring first, attach the new cord and wind it around the spool while holding the spring tension. After the cord is wound, feed the end out through the cord port and test for good return (don't let go!!), then clamp the cord with locking pliers and affix the handle to the cord. Melting the cord ends helps keep the knots from pulling out. Hope this helps!
Jun 07, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Pull cord stays out, won't retract. I took apart
the end of the spring may be broking you can fix it by taking it out and heat it with a small fire until it is red hot and bend it
Jun 26, 2009 | Homelite Mighty Lite Lawn Trimmer
The pull cord on my toro powerlite snowblower wont retract
YES YOU CAN JOE,Your recoil has come undone or the spring broke. but it can be fixed.richardm69
Jan 01, 2009 | Toro Blowers Rake and Vac - Electric...
Pull Cord Broke
the pull cord is same as the regulare pull cord lights.(real cheap one).
bring the fixture to any home center ot hareware store, they should be able to get you what you need.
Nov 12, 2008 | Electrical Supplies
My modeal 580.752000 pressurewasher runs great but as soon as there is a load on motor [pull triger on spray head] motor stalls
Dear tenpointx2,
ngfam at you service!
This sounds like it will only fixed by service
Yes sounds like you need service!
Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
Happy to assist you,
Neil
PS.Before you sign off!
PLEASE GIVE ME A GOOD RATING HERE ON FIXYA.COM
Aug 25, 2008 | Washing Machines
Psi Blue Max 2200 High Pressure Gas Power Washer Logo
546 people viewed this question
Top Psi Garden Experts
John Trevino
fordexpert
Jay Finke
Jay Finke
Are you a Psi Garden Expert? Answer questions, earn points and help others
