Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Whirlpool washer makes whinning noise during spin and rinse cycle
    President:
  • 949 Answers
The whining during spin is typically from the drain pump. The drain pump is located near the floor in the front center of the machine.
What can happen is small articles like baby socks or even excess lint can get caught in that pump and make noise while it is draining and spinning.
The noise could indicate the pump bearing/seal is worn due to something getting caught.
To remove the pump and clean out or replace it (part number 3363394) you will need to drain all the water from the machine by moving the timer to spin and run the unit for a minute or two.
Unplug the washer and tip up enough to get under the front, support the machine so it does not fall.
You will see the pump right up front in the center, you can use a flat blade screwdriver to pop off the clips that hold the pump on and a pliers to remove the two hoses.
Reverse this procedure to reassemble after cleaning it out or replacing it
Posted on Apr 24, 2010
I have a top load fridgidaire washer model fwsc445rfs0. During the wash cycle it makes a high pitched scraping noise.... Struggles also while it winds down before rinse. Bearing maybe?
How To Fix A Washing Machine Making Noise During The ...
removeandreplace.com/.../washing-machine-making-noise-during-the-sp...
Jul 27, 2015 - Agitator directional cogs aka "agitator dogs" (top load washers) ... If you hear a rubbing sound or the drum spins uneven, then the ... A washer making a loud noise during spin cycle can also be caused ... The clutch in a washing machine connects the inner wash tub to the ..... May 8, 2015; High Water Bill?
Dishwasher Making Loud Grinding Noise During Wash Cycle
removeandreplace.com/.../dishwasher-making-loud-grinding-noise-durin...
Apr 11, 2014 - Dishwasher Making Loud Grinding Noise During Wash Cycle ... GE, Whirlpool, Frigidaire, KitchenAid, Maytag, Kenmore, and LG) this is a .... Our Amana dishwasher is making a loud, high-pitched squealing noise throughout the wash ....Out Of A Washing Machine - Top Load & Front Load September 30, ...
All comments on Loud dishwasher Frigidaire Gallery mode ...
https://www.youtube.com/all_comments?v=v-arYb20kOk
Dec 03, 2015 | Washing Machines
Loud banging noise during rinse
Most noises from a washing machine occur during the rinse or spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.This will solve your problem.
Apr 08, 2010 | Whirlpool GHW9100L Front Load Washer
My Whirlpool GHW9250ML is having problems spinning
My Whirlpool Front Load Wasehr Model# GHW9250ML is having problems spinning on the final rinse cycle. The machine shuts down and the letter F appears on the digital read out.
Mar 06, 2010 | Whirlpool GHW9250M Front Load Washer
Washer makes a loud, pulsing, screeching noise with no spinning
With a manufacturing date of 7/15/97, your washing machine is clearly worn out.
Nov 07, 2017 | Whirlpool Washing Machines
Washer makes a lot of noise during spinning
we need the brand and the model
but for starters, please check on the links below.
http://forum.appliancepartspros.com/washer-repair/4501-washer-makes-extremely-loud-noise-during-spin.html
http://www.thestuccocompany.com/maintenance/Washing-Machine-noise-during-spin-cycle-169980-.htm
http://www.askmehelpdesk.com/appliances/washing-machine-noise-during-spin-cycle-167960.html
Sep 10, 2009 | Whirlpool Washing Machines
No spin cycle on Whirlpool duet model ghw9100
If front loader, take top off (dissconnect plug) check the beltmay be broken- the motor may be spinning on its own
Also spin the drum round to make it has'nt seized
Jul 22, 2009 | Whirlpool GHW9100L Front Load Washer
I have a Whirlpool Washer Model LXR6232EQ0. Yesterday something happened after it drained during the rinse cycle. It wouldn't spin. It makes a noise like the moter is trying to spin but there is a slight...
I have a Whirlpool Washer Model LXR6232EQ0. Yesterday something happened after it drained during the rinse cycle. It wouldn't spin. It makes a noise like the moter is trying to spin but there is a slight tinkle once in a while. Could it be the motor coupling or do you think it is the clutch. The agitator doesn't spin at all. does it have a belt?
Mar 17, 2009 | Whirlpool Washing Machines
My whirlpool duet washer is making a funny noise
try removing the top cover to the unit, 3 screws across the back. after ermoving check to see exactly wehre noise is coming from. some times a solid "smack " witha screwdriver will quiet teh dispensor motor if needed
Mar 07, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirpool Duet Sport Front Loading Washer is making a funny noise
open top cover (two or three screws on rear and slide back) and look at rear of tub checking clearance to rear panel and nothing touching belt or pulley. whirlpools tend to have a high pitch low volume whine anytime motor operates.
you really dont want to replace that bearing. part of tub assm. $400 part plus labor
Whirlpool Ultimate Care Model LSR8233EQO - Loud noise during final rinse/spin
Sounds like the clutch, mi9ne works fine but is noisey when spinning, repair guy said it was the clutch.
Feb 05, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
54 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
