Question about Philips Magnavox 51MP392H Rear Projection Television
Word Component1 shows up when changing local channels
Each time I try to change one of my local channels, the word "Component1" will show up in the upper right hand corner of the tv, this causes a delay in the channel starting. I have called Direct TV and the number they gave me has indicated that no "live agents" were available. What can I do to correct this problem?
thank you
Virginia Foster
    Guru:
  • 416 Answers
Your Direct TV box is switching between a Standard Definition channel and a High Definition channel. When this happens, the TV has to switch the display format. As the format is changing, you will briefly loss picture, the TV detects the new format, and then displays it. What you are seeing is the normal operation of the TV. It the TV did not blank the picture, you would see a broken chopped up picture during the transition. If you are familiar with the setup menu of the Direct TV box, you could change the video format settings so than it locks to the High Definition format. If you are not familiar with the Setup menu, you should contact Direct TV and ask then to walk you though this procedure. Specifically, ask them to "Help me set my Direct TV box so that it always displays in 1080i format." You pay for them for the service, they should be able to provide you with some phone support at no charge. I hope this was helpful, best wishes.
Posted on Apr 24, 2010
Stuck on one channel
Is it the tv's remote? Change the batteries
are you on a cable box? You need to use the providers channel changer. Tv is made to stay on one channel like channel 3 and the cable box runs the different channels.
Dec 01, 2015 | Vizio L32 32 in. LCD HDTV
Why can I not find an input to accept an antenna for local? When i change channels it shows cable and then the channel #. Do I need to change that? If so how? TY TONS
I asume that, depending on the model of TV, there could be some models that doesn't have the standard aerial input. You should post exact model of your TV, so we could try to find user manual and check the supported input types.
Feb 03, 2015 | Sharp Televison & Video
Clock on harley davidson doesn't work while riding unless we change channels on radio
Hi Weride05, take a ride over to your local dealers service department, I'm sure they will be happy to offer advice and assistance concerning your issue. Have a nice day.
Jul 14, 2012 | 2005 Harley Davidson FLHTCUI Electra Glide...
The description for setting up the LG RC897T VCR/DVD recorder says to "tune the TV to the recorder output channel (3 or 4) and set the recorder channel selector to the cable output channel" - so where do...
it means that your tv has to be on channel 3 or 4 to use device. once your tv is on one of those channels, you should be able to program your dvd/vcr to record and check to see if there is a menu button on your controller. if it is a newer tv, try setting menu on component1, aux 1 or anything but tv..if there is a menu button on controller for dvd/vcr player select that once you see the home screen on tv...
Oct 17, 2010 | LG RC897T DVD Recorder/VCR Combo
Can not stop scheduled TV recording to DVD by pessing the STOP button
This happens if you are watching the show live and recording at the same time.
Option 1
Try changing the channel. It will ask you if you want to stop recording and go to the other channel.
Option 2
Go to the list of recorded shows. You can delete the show you wanted to press stop during (it will still be recording). The show will be deleted and, therefore, recording will be stopped.
Mar 17, 2010 | Panasonic DMR-ES35VS
Cannot get a wireless signal show on Brother
Try to change the Channel in your router , try changing it to Channel 10 , normally that works to sync with printers.
Mar 13, 2010 | Brother MFC-640CW All-In-One InkJet...
The tv will not let me access all channels.
Turn off the text box with the TV/CAP/TEXT button. Go into the menu and change from TV to CABLE. Run the AUTO CH MEMORY.
Dec 11, 2008 | Durabrand DU1901 TV
Channel stuck and can't record shows the same night
Your two problems are related - the DVD player lost contact with the local PBS channel, which altered its internal clock.
Add a red, white and yellow cable from one of the outs on the back of the cable box to the slot marked AV1 IN on the back of the Philips. Then redo the channel programming - press the System Menu button and change Tuning Band to CATV - it will then ask you if you want to do an Auto Channel Set - say Yes.
Once it is done with the channel programming, turn the DVD player to whatever channel PBS is on in your area's cable service. Then go back to System Menu - select Clock Set and go to Auto. Alternatively, you can select Manual under Clock Set and change the date by hand).
-Tha Mp3 Doctor
Sep 24, 2008 | Philips DVDR3320 DVD Recorder/VCR
Guide listings are incomplete
1. Manually scan all channels on your TV with your TV remote and write down the channels and network shown:
(sample: 119.2 C-SPAN2 digital channel).
2. Go to Edit Channels and find the icon for C-SPAN2 (about icon 261 in my zip code). Manually change the channel from Off to On, Insert the frequency, and optionally insert the number you want the channel to show in your channel listing ( or move it manually later).
I have about 10 to add each time I reset my recorder.
Feb 15, 2008 | Sony DHG-HDD250 200-Hours Video Recorder
Distrorted Picture on all Analog Channels, HDMI and PIP Picture is fine.
Sounds like a bad DLP chip and they will prob end up replacing the light engine in the set most people dont like replacing this part. Hopefully they get you up and running.
Jan 20, 2008 | Samsung HLR5667W 56" Rear Projection HDTV
Philips Magnavox 51MP392H Rear Projection Television Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
