Question about Compaq Presario R3000 Notebook
Adding RAM memory
I have a Compaq Presario 3000R and i want to add two 1GB cards. I found one location. Can someone provide me assistance on finding the other one. THanks
  • 95 Answers
The other one sits under the keyboard
Posted on Apr 24, 2010
    Sergeant:
  • 260 Answers
Usually they are both in the same spot: inside a removable panel on the bottom of the laptop. One is just above the other. If you only find one slot on the bottom of the laptop, then the other one is usually just under the keyboard. Some keyboards are easier to remove than others. Sometimes there are screws going thru the bottom of the laptop casing that hold the keyboard in, as well as some small screws going along the top of the keyboard; which are usually covered up by the molding with the power button on it. There could be several screws that you have to remove in order to get the molding and keyboard removed. Be delicate with the ribbon cables. They can be expensive to replace, and be sure to remember exactly where all your screws go back into.
Can the compaq presario c500 take more RAM than the standard 1.5Gb
You can upgrade the memory to a maximum of 2 GB using either 533 Mhz or 667 Mhz modules. There are two memory slots in this notebook so you would need two 1GB modules
Aug 30, 2011 | HP Compaq Presario C500t Notebook
I have a laptop of compaq brand whose modle no is presario C700 in which intel celeron microprocessor is installed. 512 MB ram is installed i want to update it 4 improving its speed. i want to setup a...
I found the manual on the net that gives you instructions on replacing components if you're not sure how, it can be found here.
RAM upgrade
The Compaq Presario C700 uses DDR2 Laptop RAM as shown below.
slasher_x_11.jpg The motherboard of the Presario C700 has two RAM slots, one of them will be occupied by the 512MB RAM (running at 667MHz) module you have at present. This leaves one more that can accomodate a DDR2 667Mhz card of up to 1GB or you could get two 1GB DDR2 800MHz (the faster DDR2) cards and remove the 512 leaving you with a wopping 4GB of memory, that'll definately speed it up. Just remember the Presario C700 can only have up to 2GB of RAM so don't go higher than that or Windows will not boot for some reason.
Processor upgrade
The Presario C700 supports any Socket P, Core 2 Duo or Pentiun Dual Core chips. The fastest processor you can get is the Intel T8300 2.4GHz Core 2 Duo Processor with 3MB L2 cache and an 800MHz FSB
For a full list of compatible processors go to page 9 of the user manual found here.
Jan 11, 2011 | HP Computers & Internet
I have a compaq presario cq60-215dx notebook pc, was wondering how do i go about upgrading the RAM?
I have checked the Compaq Presario CQ60-215DX Specification It Originally has 2GB Memory and supports upto 4GB RAM max. If you intend to upgrade the RAM, you can buy additional RAM and put them in you system. Here is the HP Guide to Replace RAM and How to Upgrade RAM Guide
Compaq Presario CQ60-215DX has two RAM slots for DDR-2 (533 or 667) Memory Modules. First you have to check that the RAM slot is available for additional RAM. I believe that it has two modules of 1GB each in both slots. So, you have to get two modules of RAM 2GB each to upgrade to 4GB (or one 2GB RAM module to upgrade to 3GB). Hence, it is recommended that you get 2GB replacement module for each 1GB module you have on you system from local laptop repair/ service center, which would be cost effective as existing 1GB RAM Modules would be useless for you upon upgrade.
Let me know if any further clarification/ assistance is required.
Good Luck!
Appreciate generously, if the solution could have been of any help!
CreativeTECH
Dec 31, 2010 | Compaq Presario Notebook
I have compaq presario 2.6ghz with Max Capacity 1gb Ram- is there anyway i can increase capacity to 2gb or even higher?
Unfortunately, if the manufacturer states that the max RAM supported is 1GB, that's going to be all you're going to be able to install - unless you replace the motherboard. This can be a considerable expense.
One last thing you could do is go to Crucial - there, you can run a scan on your computer to find out what memory options you have. I would be very surprised to learn they differ from what Compaq is telling you (unless the motherboard was replaced by someone already).
Please rate this reply - good luck!
Sep 02, 2010 | Compaq Presario S5100NX (E120866) PC...
How to increase memory hp presario c502
In reviewing your message, I understand that your Compaq Presario C502 Notebook PC is running very slow and you wish to upgrade the memory of your Notebook.
I greatly appreciate that you have forwarded your concerns and have given me a chance to assist you with this matter.
I have checked the database and found that the Notebook is preinstalled with 512MB DDR2 System Memory. However, I am providing you the exact specifications as below,
DDR2 PC2-5300
CL=4
Unbuffered
NON-ECC
DDR2-667
And, also provoding you the part number for the 512MB and 1GB memory module as below,
435772-001
512MB, 667MHz DDR2, PC2-5300, SDRAM Small Outline Dual In-Line Memory Module (SODIMM)
431403-001
1GB, 667MHz DDR2, PC2-5300, SDRAM Small Outline Dual In-Line Memory Module (SODIMM)
You can purchase the compatible media from your nearest HP retailers. HP has a network of authorized retailers and resellers within the U.S. You can find the nearest HP authorized retailer by visiting the Following Web site:
http://hp.infonow.net/bin/findNow?CLIENT_ID=HP_LOC_USA_SLS
Under the "other ways to buy" section, click "find Compaq retailers" option. Enter the required details in the Web form and click the "find" button. This will display a list of Compaq retailers nearest to your location.
You can also order the memory module from the web link given below,
http://www.notebookparts.com/products/description.php?II=18984
NOTE: The URLs above will take you to non HP Web sites. HP does not
control and is not responsible for information outside of the HP Web site.
After purchasing memory module for remove and replacement, I am providing you the web link that contains detailed information,
http://h10025.www1.hp.com/ewfrf/wc/genericDocument?lc=en&cc=us&dlc=en&docname=c00262554
Moreover, I would like to inform you that you can also improve the performance of your Notebook by performing the steps provided in the web site given below,
http://h10025.www1.hp.com/ewfrf/wc/genericDocument?docname=c00816938&cc=us&dlc=en&lc=en&jumpid=reg_R1002_USEN
I hope this information has been of assistance to you.
Please let me know if the issue still persist or you have any other issue because it is important that I resolve your issue in a timely manner. I would like to add that we value your precious time and We assure you of our dedicated support, 24 hours, 365 days a year.
May 12, 2010 | Computers & Internet
Bsod when adding 1gb of ram to my compaq 2200 laptop
jayson30
In regards to the memory issue the problem is that your notebook only support 1gb of memory so you will have to split it between 2 512 sticks as that is the max the computer can handle. This is why the system blue screens with the 1bg stick.
Let me know if you have any more problems or questions
Issken
Mar 04, 2010 | HP Compaq Presario 2200 Notebook
What is the most RAM I can add to the compaq presario 5000 I currently have 512 MB RAM
if I am correct you can go up to 2 GB's of system memory 2 1gb sticks each!
Thanks I hope this helps please do rate with the 4 thumbs above.
Feb 13, 2010 | Compaq Presario 5000 PC Desktop
RAM increment
yes just pur chase 1 128 MB or 512 MB or 256 MB ram but check first *********** bord ram module
check your old 64 Mb ram if it has 1 notch it is ddr1 or ddr2 if it has 2 notch it iks sdram
then pur chase from shop.
then fix it on secodn slot
Apr 24, 2009 | Compaq Presario 5000 PC Desktop
Installing 2GB of memory in my Fujitsu Siemens Amilo Pro V2020
Here is the problem, the laptop take 2GB RAM. 1GB in each slot, so get 2X1GB RAM. They are cheap now. You need 2, 1GB sticks of ram. For cheap prices go to Newegg.com
Have a nice day!
Dec 22, 2008 | Fujitsu Siemens AMILO Pro V2000 Notebook
Cannot upgrade Memory on Compaq Presario 2110US
hi Rileysue ... what is the model of your HP? ... the ram modules generally have to match each other ... brand should make no difference at all .... start by removing all of the old and add one stick of the new ... you may also have to go into the BIOS each time and verify the change in ram size ... then add the next stick and so on...
Mar 30, 2008 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
Compaq Presario R3000 Notebook Logo
126 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
