Question about Fuji FinePix A350 Digital Camera
FinePix A350 Power Button stays down after being starting camera
I pressed the power button on my new A350 and the button will not pop back up. I took out the batteries to turn it off - I hope that didn't mess up anything - I still can't get the power button to pop up. Any ideas?
  • SherQ1 Mar 26, 2008
    Thanks for your help but there is a problem with the warranty.
    I received my camera as a gift and the person who gave it to me did not keep the receipt. Fuji wants proof of purchase and I don't have it so I am out of luck. Does anyone have any ideas on how to fix this or a trustworthy repair service that won't cost a fortune?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 198 Answers
This just plain shouldn't happen. Call Fuji while your warranty is in effect, and have them fix or replace it.
Posted on Mar 25, 2008
I downloaded photos on computer ,now I get card not initialized ? what do I do? Its a fujifilm camera..
Insert the memory card into the camera to format it if you are receiving error messages such as "Card Error" or "Card Not Initialized." Press the "Menu/OK" button then press the left/right directional button to select the "SET" option. Press the up or down direction button then press "Set Up" and press the "Menu/OK" to access the setup screen.
Press the down directional button to select "Option 1" and scroll down to the "Format" option. Press the right directional button to select the format option. Press the "Menu/OK" button to start the format process.
Move away from the target or brighten the lights if the auto focus does not work. Rotate the scenery mode dial at the top of the camera to the "Auto" mode. Press the "Flash" button to enable the flash mode to provide additional lighting if necessary.Manually set up the Fuji E500 camera with your computer if the computer does not automatically detect it. Connect the camera to the computer using the supplied USB cable and power on the camera. Click the "Start" button then click on the "Computer" option and select the FinePix Icon. Choose next on the download wizard to start the download process.
  • 2 Press the down directional button to select "Option 1" and scroll down to the "Format" option. Press the right directional button to select the format option. Press the "Menu/OK" button to start the format process.
  • 3 Move away from the target or brighten the lights if the auto focus does not work. Rotate the scenery mode dial at the top of the camera to the "Auto" mode. Press the "Flash" button to enable the flash mode to provide additional lighting if necessary.
  • 4 Manually set up the Fuji E500 camera with your computer if the computer does not automatically detect it. Connect the camera to the computer using the supplied USB cable and power on the camera. Click the "Start" button then click on the "Computer" option and select the FinePix Icon. Choose next on the download wizard to start the download process.
  • Read more: How to Troubleshoot a Fuji E500 Digital Camera ' eHow.com http://www.ehow.com/how_7636592_troubleshoot-fuji-e500-digital-camera.html#ixzz1OOyWsAIU
    May 31, 2011 | PNY Optima Pro 2GB Secure Digital Memory...
    Tip
    Fuji a350. When I got the camera, it took many many photos(50-100) with alkaline...
    Many digital cameras (eg Samsung D53, Nikon 2100) have extremely poor battery life with alkaline batteries (under 20 shots!). Sometimes they won't even take a single picture.
    Try using rechargeable batteries or "oxyride" disposable batteries. They perform infinately better.
    on Feb 04, 2009 | Samsung Digimax D53 Digital Camera
    When i take a picture, press te button, the camera lens goes back into camera and shuts off, why?
    Normally an indication of flat batteries. Low batteries do the same. Even bad quality batteries will do this. You should get 2 AA Lithium which will last a long time but when ready to go will die instantly.
    Nov 05, 2010 | Fuji FinePix A350 Digital Camera
    I have a Fujufilm Finepix S5700 digital camera. Does not power up
    hold power button down and remove battery at the same time once battery is out put battery into charger, if the light shows red then it needs to be charged if it shows green allow it to stay in the charger for 3 minutes then remove the battery and install in the camera pust the power button on hold for 5 seconds, if the camera comes on your ready to go, if not then you may have damaged the battery pack and will have to replace te battery. If you have a cable that plugs into the camera try using the powrord with battery plugged in, if it does not work then your battery is bad and you will have to purchase from fuji to get the right battery pack.
    Jun 13, 2010 | Fuji FinePix S5700 Digital Camera
    DSC-W150 SteadyShot says turn power on & off & lens pops in/out
    I had the same problem with my Sony DSC-W150 camera. It turned out to have an easy fix. At the same time, press the power button and depress the shutter button halfway (the one you snap to take pics) as if you were trying to engage the autofocus without pressing the button down entirely. The lens will attempt to autofucus, which in my case was enough extra power to dislodge whatever debris/sand had clogged the lens. Hope this works for you!
    Jun 04, 2010 | Sony Cyber-shot DSC-W170 Digital Camera
    Bissell 5770 vacuum power won't stay on. The power will only stay on if you hold down the button the whole time.
    I just had this happen to me. I took the top part of the vacuum off, unscrewed all of the screws from the top piece and opened it just enough to pop off the plastic red power button. Then I pressed the switch mechanism up and down a few times to reset it and put it back together. Turns out it didn't actually go bad.
    Feb 28, 2010 | Bissell 5770 Healthy Home Bagless Upright...
    I often miss a shot because there seems to be a delay when I press the shutter button on my Fuji FinePix A350 digital camera. Is there a setting I can change to speed up the process?
    It's called "shutter lag"...a common problem with all point and shoot cameras. To avoid it, press the shutter button half-way and allow the camera to lock in the focus (it will beep) before pressing the rest of the way.
    Jan 03, 2010 | Fuji FinePix A350 Digital Camera
    How do I get up with daveward712 to get the extra button he has
    do you need just the button or the whole bezel and power button? I have spares for A345 but should be same for A350, 360 and 370.
    Email: daveward712@aol.com
    Jan 28, 2009 | Fuji FinePix A350 Digital Camera
    Fujifilm finepix a350
    This is a common problem with this camera and it needs to be sent back to Fuji for repair.I've been through it three times and then they replaced the A350 with an A400 and now I'm having the same problems with the A400.
    They want to swap it with a E500.
    Both of these replacements are less of a camera then the A350.
    If they won't repair it under warranty I suggest you stay away from Fuji cameras in the future,I know I will never buy one again
    Dec 14, 2007 | Fuji FinePix A350 Digital Camera
    Fuji FinePix A350 Digital Camera Logo
    69 people viewed this question
    Top Fuji Cameras Experts
    Greg Cann
    Greg Cann
    Are you a Fuji Camera Expert? Answer questions, earn points and help others
