Question about GE JKP45 Electric Double Oven
GE Oven door won't unlock after cleaning cycle (and cool down).
Model GE JKP45WP Double built in electric oven. After the last routine self cleaning cycle ended and cooled down, (actually days of cool down), the top door of our built in double oven still remains locked.
We've tried turning off the circuit breaker to hopefully reset it, but to no positive result. We've run it through another cleaning cycle to hopefully free it after a 2nd cooling.... still nothing.
Any information anyone can offer would be greatly appreciated? Thank you!
  • GE Master
  • 43,501 Answers
Cycling the power off and then on again will sometimes reset it...often you will have to call the customer service number to get the steps to take to unlock that...
Also check out this tip...
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
Posted on Apr 26, 2010
Oven will not unlock after self cleaning
User manual says that the oven must cool off. I am sure this is not the case. Try starting the oven self clean function, and then clear/off to stop the function. Since the oven is cool, perhaps the oven will unlock.
Finally, you could try turning off the circuit breaker and then back on to see if it unlocks - unfortunately you will have to reprogram everything. All else fails, call a technician.
http://www.manualslib.com/download/58340/Ge-Jt912-Jt952.html
Mar 04, 2015 | GE Profile JT952 Electric Double Oven
Door won't open after self cleaning and cool down has stopped.
if you are sure it has cooled down cycle it again to clean hitting the cancel button shorty after it starts
Dec 09, 2011 | Maytag CWE5800A Electric Double Oven
H E L P !!! My oven made some noises this morning when my husband was wiping down the front of the oven door. Noise sounded like the "oven was going into clean mode"....but then only lasted...
Hello.
Please apply the solution this way!
To close an oven door when it's in the locked position and the door is open, press and hold the oven door light switch while following these simple steps:
  • Program the oven to self-clean.
  • Wait 20 seconds.
  • Cancel self-clean.
  • Wait 20 seconds.
To self-clean your wall oven, follow these simple steps:
  • Remove the oven racks.
  • Set your oven control to "Clean."
  • Select a cleaning time or choose a cleaning level: light, medium or heavy. For typical cleaning needs, we recommend that you select a cleaning time of three hours or choose the medium setting.
  • Select "Start." (To set a delayed start, see your Use & Care Guide.)
Note: For safety reasons, the oven door will remain locked until the oven cools down. When it is sufficiently cool, the door will automatically unlock.
Thanks for using fixya.
Sep 07, 2011 | Dacor Ovens
Oven door won't open after self cleaning cycle
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have usedthe self cleaning option. Thanks for the info!! " - amymrocks
Aug 13, 2011 | Viking 27" Professional Select Built-in...
Locked after self clean cycle
you may have a bad door lock . in this case replace. but first reinstall the door and run a new clean cycle and see if it unlocks .. mm
Jul 14, 2010 | GE JKP45 Electric Double Oven
I cannot unlock my door after self cleaning, it has been several days i pushed the 9 and unlock key but it will not open.
Unplug the unit or shut off the circuit breaker for 5 minutes. Plug the unit back in or turn on the circuit breaker. Set the clock and gently try moving the door lock lever (is so equipped) or opening the door.
or
Set the self-clean cycle again and only allow it to work for 15 minutes. Cancel the self-clean cycle and allow the oven to cool. Gently try moving the door lock lever (is so equipped) or opening the door.
If these procedures fail to correct the condition, the lock must usually be accessed and moved manually to open the door.
Some model ovens require the oven door to be manually unlatched before the controls are returned to the OFF position or else the door may not be able to be unlocked. Check the owner's manual for proper operating procedures.
Feb 23, 2010 | GE Profile JT952 Electric Double Oven
I'm getting a F2 Error and door locked with flashing and beeping after I ran the self-cleaning mode on my GE Model JTP85 built-in oven.
f 2 code states that your oven temp exceeds 590 w/unlocked door .. the oven tempt sensor will need to be replaced .. hope this helped mm
Dec 04, 2009 | GE JTP85 Electric Double Oven
GE Electric Double Oven Door Will Not Unlock
heatman101
Nov 05, 2008 | GE Profile JTP56 Electric Double Oven
Ge double oven
I believe this is because it takes a while for your oven to cool down (the cleaning cycle uses a very high temperature to burn up the grease and food). The timer is how long it takes before it will be cool, at which time the oven will unlock.
Mar 17, 2008 | GE Monogram ZET3058SHSS Stainless Steel...
Ge Electric Double oVen
This may be related to a problem I have helped others solve. The solution is available free at my website. I have at last count helped over 1000 oven owners with a similar problem. http://fp1.centurytel.net/Powerman/Dreaded%20F7%20Problem.pdf Hope it works for you too.
Aug 09, 2007 | GE JKP45 Electric Double Oven
GE JKP45 Electric Double Oven Logo
3,906 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Are you a GE Oven Expert? Answer questions, earn points and help others
