Question about Refrigerators
Our 2 1/2 year old GE side by side frigerator has worked fine in the past, but now the top part of inside the freezer thaws part of the time. The ice cubes partially thaws then refreezes into a solid cube, and sometimes the ice cream is soft - and sometimes frozen hard.
  • Refrigerators Master
  • 3,051 Answers
Hey i got disconnected do me a favor AND CLOSE OUT OF THE CHAT SESSION AND PLEASE RATE IT FOR ME I WILL FINISH UP EVERYTH ING FROM HERE SO YOU WONT HAVE TO PAY FOR IT AGAIN
Posted on Apr 24, 2010
Testimonial: "Very helpful! I will do what you've suggested, then again feed back the results. If you've found out more about this particular model, please send."
  • Michael Thomas
    Michael Thomas Apr 24, 2010
    yes just go aheadand end the session but please do me a favor and give the session a good rating then just post me a comment in the problems section in the fixya site
    OK i really hope this chat session has been very helpful for you
    i have a lot of information that i can send you later once i can talk to you again
    best regards mike
  • Michael Thomas
    please dont for getto go back to the session and rate it so i can continue to help
Why is my GE side by side freezer not freezing on top?
It sounds like the freezer fan has failed. You are correct on the ice machine.
Jul 21, 2014 | General Electric GE Profile PSDS3YGXSS...
GE side by side gss25jepbb not cooling any longer, probably 10-15 years old
HI LISA.getting old.could be a no of things.try these simple checks1-is motor making noise.(compressor).if not is hot?2- condenser is it hot or cold3- any ice at all inside freezer?if yes defrost all and try.(could be defrost timer/heater/t/stat/fan)4-if NOice it could be lack of refrigerant condenser fanmotor.or motor .hope this helps otherwise call engineer.good luck.Ali
Jun 24, 2012 | GE 25.0 Cu. Ft. Side-by-Side Refrigerator...
Ice cubes taste bad
there should be one in the frigerator for the water if not go the the local home depot and get a inloine on for it.
Apr 20, 2009 | GE GTS22WCP Top Freezer Refrigerator
We have a G.E. mod.# GSS22KGMCWW refrigerator that frosts
you have defrost problem 1 timer 2 defrost thermostart 3 heater best way call service
Apr 05, 2009 | Amana ARS2464B Side by Side Refrigerator
No water but ice is fine
turn freezer side to zero for 1 minute press water dispenser
Mar 29, 2009 | GE GSH25JSRSS Stainless Steel Side by Side...
Freezer thawing and refreezing
The freezer is supposed to thaw at least everyday. Only, you usually kant tell because it doesn't do it long enough to melt the food so you don't notice it. You have a couple of components to check here. 1 is the defrost timer, which unless it has been changed recently, has the same pre determined defrost time. So you would have noticed by now. Next is the defrost termination switch. If you have excess ice on the evaporator, this will make the defrost longer than before. Unless the switch is going bad causing the defrost to go extra long, there is an excess amount of ice that is more than usual. Bad door seal will cause this. A slightly low freon charge. And a thermostat that is malfunctioning, causing the freezer to run continuously, will make excess ice buildup in the freezer. I would make sure the kids aren't leaving the door open and the gaskets are good. If not the case, call a repairman.
Jan 09, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Door dispenser stopped dispensing, starting making a constant clicking and now the entire fride isn't working
We had the same problem. Our frigerator is 1.5 year old. Everytime we try to dispence water or ice the dispencer clicks and the whole thing turns of. We had a GE repairman come by: the electronic board needs to be replaced: total cost $350. (cost of the board only: $150. We are considering disconnecting the dispencer by unplugging the board (according to the repain man the ice maker wil still work)or buy a new refrigurator (for sure NO GE!!!!!!)
Aug 01, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
186 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
