Question about Kenmore Oasis HE 27082 Top Load Washer
F51 & SD Codes -- Maytag Bravos Washer - Kenmore Oasis HE 27082 Top Load Washer
  • 5 more comments
  • Anonymous Mar 25, 2008
    My washer started this yesterday too. Flashing F## and then 51. Should I call the repair guys???
  • lolmousy Mar 31, 2008
    my mashine doesnt even fill up it throws the water through the drain and then flashes F51code. Please help!!! I need it fixed as soon as possible. What can I do
  • amratliff Apr 05, 2009
    f51 code displayed and the washer shuts off and does'nt finish the load
  • robert samples May 11, 2010
    The electronic control displays an F51 code.
    CAUSE:
    There is an intermittent connection at the Rotor Position Sensor, (RPS), causing the electronic control to indicate an F51
    code.
    cORECTION:
    Remove and reinstall the connector at the RPS at least three times to clean off any corrosion built up on the connector and
    RPS due to the intermittent connection. Confirm that the connector is fully seated onto the RPS control upon final connection
    and verify there are no damaged wires.
    Replace the electronic control with part #W10130544. This new control is designed to check the RPS sensor differently and
    is less sensitive to intermittent RPS connections.
    sd is the code for too much suds cut down on your detergent f51 is the code for a bad rotor postion sensor or connection
    what do you need chuckles
  • Anonymous Mar 18, 2014
    how to fix error code f51 maytag bravos
Remove what piece 10 times? not clear on armature. is that the circuit board in the plastic piece, the holder containing the circuit board, or the piece that connects to the circuit board from harness?
Posted on Jun 30, 2009
Sign the petition ... http://www.petitiononline.com/cabrio08/
Posted on Aug 20, 2008
  • 413 Answers
This has been a troublesome issue for Whirlpool and many of Whirlpools customers. The F51 code indicates a problem with the RPS (Rotational Speed Sensor) that monitors the motor speed. This issue has been identified as relating to the the connection system between the RPS and the controller.
Whirlpool has changed the RPS connector design, providing a more reliable connection and is available as a service kit. The control has also been updated for better sensing of the RPS. Also, if you have experienced problems with certain wash loads getting tangled and knotted, there is also an update washplate intended to reduce this issue. You should contact Whirlpool for possible repair concessions related to these issues.
If you would like to get to the RPS.. Here's how:
In some cases, the F51 code can be fixed by cleaning the RPS connector. The RPS is located on the motor armature underneath the machine.
1. Tilt the machine backwards, resting the console against the wall.
2. using a disposer tool or suitable hex wrench loosen the center stator screw completely (the screw is captive and will not fall out of hole).
3. The stator contains a series of strong magnets and will take some tugging and wiggling to pull off.
4. Remove the 4 bolts that secure the armature to the tub. CAREFUL this assembly is a little heavy, support well before removing last bolt.
5. The RPS is attached to the armature. Remove and insert RPS connector (the one with 6 wires) 10 times to 'wipe' the contacts providing a cleaning action.
If I can assist you further, please let me know
reg501
The FixYa Team
Posted on Jun 21, 2008
    Problem Solver:
  • 3 Answers
I have a question for tech17....
the part #W10130544 is around $199.00. Am I correct? Is this the entire control board or a new RPS Sensor? I checked prices on just the sensor at around $34.00. I also got a quote from a local Appliance Parts shop for what i thought was the same part, a Whirlpool part for around $78 bucks. What is the correct repair? I have attempted the reseat and clean atleast 3 times and still cannot get this code to clear!?!?! Also, how can I get into diag mode on this console? I am assuming the power needs to be on!?!? How can I clear the stored fault codes? Any help would be greatly appreciated! I love this machine but for a few dollars more I can go back to the old style controlled machine and be done with this electronic BS! Like I said any help would be greatly appreciated! Thanks for the previous posts!
Posted on Mar 30, 2008
How to run diagnostic
Maytag Bravos MTW6600T Top Load Washer Run ... - Fixya
www.fixya.com > ... > Maytag Bravos MTW6600T Top Load Washer
Maytag Bravos MTW6600T Top Load Washer, run diagnostic test cycle related issues. Get free help, solutions & advice from top Maytag experts.
Maytag Bravos MTW6600T Top Load Washer, run diagnostic test ccu related issues. Get free help, solutions & advice from top Maytag experts.
Maytag Bravos MTW6600T Top Load Washer Diagnostic ...
Dec 02, 2015 | Maytag Bravos MTW6600T Top Load Washer
What does it mean f 51
http://forum.appliancepartspros.com/washer-repair/131926-maytag-washer-error-code-f51.html
Jan 30, 2013 | Maytag Bravos MTW6600T Top Load Washer
Maytag washer flashes f 51
You will need to replace the RPS sensor. There is a kit available that will update that washer to the current design. Here is the kit to order.
Nov 23, 2012 | Washing Machines
I have a Maytag Bravos MVWM750WQO washer. A F51 code came up and I called a repairman in he said it was the bearing and would be $406.59 to repair. Not sure if its worth it since its only 2 1/2 year
Well the failure is Motor RPS Failure. Depend how he consider the charge for parts+job.
I am sorry. Try to locate another tech service.
God bless you
Aug 01, 2012 | Maytag Washing Machines
MAytag Bravos Quiet Series 300 washing machine starts to fill, stops and shows code F51
F-51 RPS senses rotation when basket ought to be stopped.
It is probably loose or worn out.
Video How To
Oct 22, 2011 | Maytag Bravos 3.8 Cu. Ft. Washer
I have a Maytag Bravos washing machine that has just recently become really noisy when it goes into high speed spin. I have lifted the cover and found no items or debris. When I spin the tub by hand it...
Hi.
F51 is motor position sensor error. From manual:
F51: Motor RPS Failure
F then 51 flashes when there is a motor rotor position sensor (RPS) failure or lower harness problem.
The motor position sensor failure may be the result of a problem between basket and motor.The parts below the basket must be inspected. There is need to remove the basket to check parts in there. I can give you the procedure to remove the basket if you want.
Aug 20, 2011 | Maytag Bravos MTW6600T Top Load Washer
Maytag washer -- what does the code f51 mean?
hello, you need to install part #W10183157. it comes with instructions itnot that hard to install. it should correct your issue. thanks and please rate me :)
Jun 08, 2011 | Maytag Bravos MTW6600T Top Load Washer
My Maytag 300 quite series has a code F51 what does this mean?
Hi and welcome to FixYa, I am Kelly The F51 code is a motor rotor position sensor (RPS) feedback error. In other words the control board is not sensing any motor rotation. It is fixable but will result in the replacement of failed parts. (Sensor or electronic control board) The control board is not cheap. Hopefully you only have a failed sensor.
Thanks for choosing FixYa,
Kelly
Feb 16, 2011 | Maytag Bravos MVWB400V Washer
I have a Maytag Bravo top load glass washer and a f51 code. Top wont open and machine has stopped
Defective hall sensor most likely, The cabrio bravos and Oasis machines are all basically the same.
MORE here
Dec 19, 2010 | Maytag Bravos MTW6600T Top Load Washer
Kenmore Oasis HE 27082 Top Load Washer Logo
1,606 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
