Question about Whirlpool 24 in. GU2500 XTP Built-in Dishwasher
NOT POWERING ON
I HAVE HAD MY DISHWASHER FOR ALMOST 2 YEARS ONE DAY IT JUST STOP COMMING ON
    President:
  • 949 Answers
If you are getting no lights no power or any sounds the first thing to check is the power to the dishwasher, make sure there are no wall switches in the kitchen that have been turned off and that the breaker has not tripped if those are fine then the most common component to fail and cause this symptom is the thermal fuse.
It is located in the console attached to the control circuit board. The fuse is about $20.00 in cost. I would have to have the complete model number off the tag just inside the dishwasher door area to give you the part number needed.
If you want to replace this part your self I would be happy to walk you through the process, a little mechanical ability some hand tools and a basic understanding of electricity is needed.
Posted on Apr 25, 2010
Miele G1182 dishwasher not working
Any water comming in to the dish washer area?? If not check the inlet water valve, they get clogged with sand from the water supply. They can also clog open, in which case the dishwasher will flood the floor with water afer about 3 to 4 imins of use.
Dec 19, 2012 | Miele Dishwashers
My dishwasher (model # DU81ODWGU1) is leaking water and suds during the wash cycle. I ran out of dishwasher powder so I had used regular dish soap for this cycle. Did this cause the problem? My...
MOST DEFINITLY You can put regular dish washing liquid in a dishwasher will do that every time take a few washings to stop run 2-3 times empty it will stop.
May 06, 2011 | Whirlpool Dishwashers
Normal cycle never completes. Have to CANCEL to
check the temperature is reached the setting temperature,
or replaced the control board
Jun 04, 2010 | KitchenAid 24 in. KUDS01FLBL Built-in...
Dishawasher drains but right after lets all the
The check valve might be stuck. The valve is supposed to let the water out but stop it from flowing back in. Also make sure you discharge line has a loop. And check your air gap at the sink(if you have one) and make sure it is not plugged.
Aug 04, 2009 | GE HDA3500NWW Dishwasher
Sounds like dishwasher is running but no water coming out (there are no broken pipes or leaks)
I had the same problem. The motor is working (humming) and my dishwasher goes through the whole cycle without water. I googled it and found it on a website. Sorry I don't remember which website. Basically, it said to put some hot water in the bottom of your dishwasher and add some citric acid. I added 2 small packets (2 oz each) and filled the bottom of the dishwasher with hot water until it covered the motor or the drain of the dishwasher and left it overnight. The next day my dishwasher started and ran perfectly fine. That was over 4 months ago and I have not had any problems.
Mar 24, 2008 | Dishwashers
Kitchenaid Dishwasher - LOUD
i've found that if a glass or a dish breaks little pieces get caught in the grinder that is built in with the motor in time it will go away.
Jan 25, 2008 | Dishwashers
Miele G638 CS Plus - Salt PC light flashes and will not run
have you added salt to unit?If so then you have a water intake problem or unit is oversudsing.
Dec 07, 2007 | Dishwashers
Dishwasher problem
sounds like a blocked pump or pump line is blocked. you will need to check these and also clean out the spinners. not using a dishwasher can do more damage to them as there is long periods for the systems to dry. this cause a build up of food particles. using a cleaning agent for the dishwasher can help stop the build up.
Jun 15, 2017 | Dishwashers
Whirlpool 24 in. GU2500 XTP Built-in Dishwasher Logo
116 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
