Question about Roper RAX4232KQ Top Load Washer
Roper RAX4232KQ Top Load Washer will not drain or spin. What does it need?
  • Roper Master
  • 43,501 Answers
Here is a tip that will help you with that...
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
heatman101
Posted on Apr 26, 2010
My roper RAX4232KQO washers but won't drain. What could be causing this?
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 27, 2011 | Roper RAX4232KQ Top Load Washer
My washer will not spin or drain, what could be wrong?
I had the same problem. I changed the lid switch, which took less than an hour and the problem was solved. This is the first thing that I would check.
Jun 27, 2011 | Roper RAX4232KQ Top Load Washer
Dose not spin oll the water out. jpnixsr@yahoo.com
Hi
If the lid switch is fine and the washer will spin fine then the issue is with the drain pump, something is either stuck inside or the drain pump is bad and should be replaced. Please check this video for cleaning/replacing your washer drain pump assembly:
Hope this helps...please post back for further assistance.
Daniel
May 04, 2011 | Roper RAX4232KQ Top Load Washer
My washer spins but not enough to get the water out of clothes.
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
If you are having problems with your front load washing machine then checkout this tip...
heatman101
Feb 18, 2011 | Roper RAX4232KQ Top Load Washer
Washer does not drain and spin
Washing Machine2_bing.gif does not Pump or Spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
May 20, 2010 | Roper RAX4232KQ Top Load Washer
Everything works-no spin-motor sounds like it won't engage
Sounds like the clutch is malfunctioning. Not an easy DIY job -- probably need a service call.
May 31, 2009 | Roper RAX4232KQ Top Load Washer
Won't go to spin cycle-water still in
sounds like your lid switch is defective. if it will fill and agitate but not drain/spin, the most common problem is the lid switch....your machine thinks the lid is open
Dec 29, 2008 | Roper RAX4232KQ Top Load Washer
Roper top load washing machine
you may have a bad lid switch,or the lid is not making contact withthe switch . not recognizing the door being down the machine , for safeety reasons, will not advance any furhter
Nov 02, 2008 | Roper RAX4232KQ Top Load Washer
Roper washer top loader spins very slow
if the appliance has a induction type motor could be that the running capacitor is failing coul be the motor itself
Sep 16, 2008 | Roper RAX4232KQ Top Load Washer
Roper RAX4232KQ Top Load Washer Logo
128 people viewed this question
Top Roper Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
