Question about Nokia N70 Cellular Phone
N70 - blank screen
It just died on me... it was working fine before bedtime, and when i woke up, the screen is blank. i have tried removing sim card, resetting it several times, but it just cant work....
  • 1 more comment
  • mewsy Mar 24, 2008
    still doesnt work... i need to retrieve my contacts and all my data from the phone... I had a recent backup. Is there any way to retrieve the data from my backup? thx...
  • Anonymous Apr 03, 2008
    screen freeze after updating virus definitions
  • pilphinda Apr 20, 2008
    i have n 70 with the half screen error but after format, be same not normaly what can i do? please help me.
  • 4 Answers
That problem is hardware
thats the display ic tested many times
Posted on Apr 28, 2008
The chips driving the display have burned out... they're two small surface mount devices on the main board. this is not a software problem
Posted on Apr 27, 2008
This is a known problem. You should have nokia fix this problem (replace a electronic part)
Posted on Apr 19, 2008
    President:
  • 1,017 Answers
Take your SIM card out.
Make sure your phone battery is fully charged.
Press * 3 send at the same time and turn the phone on. Keep them pressed until the reset screen appears.
Give it time to reset.
Yes! I know, you need someone to press the ON button.
Posted on Mar 23, 2008
  • Raysagem
    Raysagem Mar 23, 2008
    Then do an update of the phone software. Go to Nokia of your area. But be careful with updating, read carefully:
    You need to download the latest Nokia PC Suite to do an update on your phone.
    Before updating software you should check that there's a newer version of software available.
    WARNING
    When updating software on Mobs, be sure to:
    HAVE A FULLY CHARGED BATTERY INSERTED;
    PUT IT ON GENERAL PROFILE;
    TURN OFF YOUR PIN NUMBER;
    CONNECT YOUR CHARGER TO YOUR MOB AND SWITCH IT ON;
    DO NOT ----- DO NOT ---- TOUCH YOUR PHONE WHILE THE UPDATE IS GOING ON;
    THIS CAN TAKE 30 MINUTES OR MORE.
    And obviously don't unplug the phone from the PC.
    Be patient, you may have to do a restart or two on your mob afterwards. Even remove the battery to get it going again (not recommended). But give it plenty of time.
    It is also wise not to use your PC while updating software, just in case the PC freezes.
    If the PC freezes during an update, you're up the creek without a paddle...
    I did an update on a Sony Eric 810i it took nearly two hours.
    More... Your phone turns itself on and off, sometimes more than once while updating software, you should leave it well alone during the update.
Every time i insert my sim card into my phone and switch it on it tells me to insert a sim card and the phone stays in offline mode and cannot be put back into general or silent(n70)
remove the sim, battery, and memory card then clean your sim with eraser then try it on. if problem continues try a new sim and if not work again no other solution but to consult a technician.
Mar 28, 2011 | Nokia N70 Cellular Phone
I have nokia n70..till yesterday it was working fine..it got switched coz its battery went off..today when i was chargin tried to switch it on..but the screen is nly white no display,its makind beep...
Power cycle the phone. Here's what you need to do:
1. Remove the battery.
2. Remove the SIM card and the memory card.
3. Give for about 5 minutes and then put everything back.
4. Turn the phone ON.
If the problem still the same, you need to bring it to the Nokia Care Center for possible firmware upgrade.
Have a great day!
May 23, 2009 | Nokia N70 Cellular Phone
My HP, Nokia N70 Music Edition,now the screen is blank, the number can't to receive a call n can't to call anywhere...plz help me
Hi
perform this steps below..
1.remove memory card..(take phone book backup either in to MMC or any other sim)
2.Now type this code *#7370#
enter security code default is 12345
It will reset to factory settings..
3.Now insert MMC if this issue still persists format memory card also.
4.Still if this issue is there contact service center they will format User Area using UFS3 software.
Regards,
Suraj.
Feb 18, 2009 | Nokia N70 Cellular Phone
Nokia n70 blank screen or white screen
Your phone's real messed up.. Uhmm.. Listen, this may or may not work, but do try it before you do decide to go to a technician.
Hard format method:
  1. turn phone off
  2. hold the following keys WHILE its turning back on: (3 + * + green call key)
  3. do not let go until it asks you about your location
That hard formats all data on the phone, but your phone may need to be reprogrammed if the entire software is corrupted. Here in the philippines it costs 300 pesos, which is cheap. I dont know about the price from where you come from.
Anyways, negotiate (if possible) for a better price. It could also be a damaged hardware from within that may need fixing or replacement.
Let me know how it goes
johnny
Sep 03, 2008 | Nokia N70 Cellular Phone
Blank Screen
thats bcoz n70 is full of virus...its very bad phone & it gets worst phone award in 2007 in world...for solving ur prob u pls change ur phone immediately......
Feb 26, 2008 | Nokia N70 Cellular Phone
N70 Problem
Try a reset:
First turn it OFF, take the SIM card out.
Press * 3 send at the same time and turn power on. Keep them pressed untill the reset screen appears.
Give it time to work.
This might not work but it's worth a try.
I think your phone has been Black Listed.
It must have been reported stolen.
Jan 11, 2008 | Nokia N70 Cellular Phone
Nokia n70 music edition
format the card and phone simultaneously it'll surely work 99%
Nov 13, 2007 | Nokia N70 Cellular Phone
Nokia n70 not recognizing sim card
are you a pinoy???
anyway, probably the sim loss its contact to its sim terminal... try inserting together to your sim a folded paper same size of your sim( just to compress your sim to its rterminals)... be sure not to cover the sim terminals...
Oct 29, 2007 | Nokia N70 Cellular Phone
Nokia N70 Cellular Phone Logo
130 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
