Question about Watches
How do I get to the battery of a CASIO DW-1500 model 590 watch to replace it?
  • 299 Answers
You have to remove the caseback but without the proper tools you'll risk damaging the watch. You also must replace the gasket or it will leak. Best bet is to take it to a watch shop or jewelry store where they can do it for you for about $8. Sears has a kiosk in their stores to do this too.
Posted on Apr 25, 2010
How do I unclasp the battery on a Casio DW-290 T watch?
Take it to a walmart store and they will replace it if you buy the battery there .
Jun 02, 2015 | Casio Watches
Dw-6600 need a manual for my watch, where to find one on-line
Hi.
Please click on the link below to open the manual for your Casio G-Shock (DW-6600 module 1199):
Casio owners manual.
Regards.
Ginko
Sep 08, 2011 | Casio Watches
How do I replace the watch battery for Casio DW-6900?
mcdevito75 here, Casio uses an LCD crystal, Liquid Display Crystal, during a battery change any, any un do pressure remopveing or replaceing the battery could destroy the LCD. Take my advise, with a casio watch, look for a small watch repair shop in your area for the battery change. I"ve ruined many of my casio watches during battery change.
Aug 27, 2010 | Watches
Where can we buy replacement watch bands for this watch Casio DW-9052
You can buy genuine Casio watch bands from www.tiktox.com
Check out there website first.You can order online,or give them a call.
Make sure you have measured the shoulder correctly when ordering a new watch band.Your watch model number will help in the search on their website.
Apr 07, 2010 | Casio DW9052-1V Wrist Watch
I've changed my battery on my casio g-shock dw 003 but the illuminator no longer works! why?
Did the same with my DW-003 and thought I'd broken the Illuminator (and the alarm didn't work). Next battery change was via a shop and the illuminator worked again (as did the alarm). This was just a battery cahnge, rather than a repair job - One of those things, I guess
Sep 30, 2009 | Casio G-Shock GW300CA-1V Wrist Watch
Model & spring issue with an ol casio G-Shock when replacing batt
This spring is connector to caseback for transmitting sound. Get an eyeglass and find out on movement backplate written SPRING COIL and put it back. If there is no marking SPRING COIL then check for the hole with approx. same diameter as spring (must easy fit in). The hole shoud be empty with contact spot at the bottom. Put the spring in and close the caseback. Check alarm sound. If it works, you did find the right hole- if not, try again till you find the right one.
Good luck
Arthur
Dec 13, 2008 | Casio DW290 1V Classic Alarm Chronograph...
Manual for casio G.shock DW-5900
How do I replace the battery on a casio wrist watch?
Apr 25, 2008 | Casio G-Shock GW300CA-1V Wrist Watch
I had the battery in my Casio G Shock DW 6800 replaced. Since then none of the beeps or alarms have worked. Is there a reset button he didn't press?
There is a reset button inside your watch, but I don't think that is the problem. Most likely, there is a spring that makes contact to the watch and the back of your watch case, and it fell out by the person replacing your battery. I would definitely go back to the place where you had the battery installed, and have them take care of the problem buy ordering you a new spring or have them pay for you to send it to Casio.
Apr 24, 2008 | Casio G-Shock GW500A-1V Wrist Watch
Battery replacement for a G-shock.
The reset trick works with other Casio Alarm Chrono digital watches, such as my old Model W-720, as well. After the new lithium coil cell is installed and secured with the spring clip, the watch may show random segments in the LCD display or may simply be blank. Insert a sewing needle, paper clip, or blade of a small jeweler's screwdriver into the hole on the back of the movement stamped "AC" (All Clear) to momentarily connect the gold plated contact at the bottom of the hole to the stainless steel battery clip. The battery clip in most such Casio watches is connected to the "+" terminal of the coin cell. This will reset the CMOS chip and it should start up with the watch displaying 12:00 and the date at 1-1. Then, use the control buttons to set the time and date in the normal fashion.
Mar 24, 2008 | Casio G-Shock GW300CA-1V Wrist Watch
Watches Logo
246 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
