Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
What does f1 mean on a cabrio washer - Whirlpool Cabrio WTW6600SBT Top Load Washer
  • 15,935 Answers
Keypad/User Interface Failure
F then 2 flashes when in:
Diagnostics Test mode if a stuck key is detected.
Standby mode if there is a user interface mismatch.
DISPLAY (Saved Code) EXPLANATION AND RECOMMENDED PROCEDURE
Console and Indicators
This test is performed when any of the following situations occurs during the Console and Indicators Diagnostic Test:
None of the indicators light up No beep sound is heard Some buttons do not light indicators None of the indicators light up:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the P11 connector is inserted all the way into the machine/motor control.
2. Visually check that the user interface assembly is properly inserted in the console assembly
3. If both visual checks pass, replace the user interface assembly.
4. Plug in washer or reconnect power.
5. Activate the Console and Indicators Diagnostic Test mode to verify repair.
6. If indicators still do not light, the machine/ motor control has failed: Unplug washer or disconnect power. Replace the machine/motor control assembly.
Plug in washer or reconnect power. Activate the Console and Indicators Diagnostic Test mode to verify repair.
No beep sound is heard:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the P5 connector is inserted all the way into the machine/motor control. If visual check passes, replace the user interface assembly.
2. Plug in washer or reconnect power.
3. Activate the Console and Indicators Diagnostic Test mode to verify repair.
4. If replacing the user interface assembly failed: Unplug washer or disconnect power. Replace the machine/motor control assembly. Plug in washer or reconnect power. Activate the Console and Indicators Diagnostic Test mode to verify repair.
Some buttons do not light indicators:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the console electronics and housing assembly is properly inserted
into the front console. If visual check passes, replace the user interface assembly.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 20, 2010
SOURCE: Whirlpool Cabrio Washer Error message code F1
I have started a petition to be sent to the CEO of Whirlpool Corp., Jeff Fettit.
Follow the link, and please sign it! The more the better! Spread the word!
You may also copy and post it to any other groups/discussions about this problem.
http://www.petitiononline.com/cabrio08/petition.html
Thank you!!!
Posted on Aug 02, 2008
canbruce75
  • 1776 Answers
SOURCE: My Cabrio dryer is flashing f1. What does this
This is from a service bulletin. This may be of interest to you. There have been many problems with these machines in this area. Anyway, I sympathize and hope this helps. Best wishes.
CORRECTION:
HE Top Load Washers
Models:
F1 Error Code
WTW6200S WTW6300S WTW6400S WTW6600S WTW6700T
MTW6300T MTW6400T MTW6500T MTW6600T MTW6700T
Serial Numbers: CT01 – CU52
There are four areas of concern that can cause the F1 Error Code. Each area must be sequentially addressed to ensure
that the diagnosis is correct and the proper repair is completed.
A) Air leaks in the air pressure (switch/sensor) hose.
a. Inspect the hose for cracks, pin-holes or loose connection.
b. Replace the hose and harness assembly (W10058730) if it is compromised.
B) Moisture in the air pressure (switch/sensor) hose.
a. Inspect the hose for evidence of water.
b. Replace the hose and harness assembly (W10058730) if water is detected.
C) Lint or flashing in the air dome hose connection port.
a. Inspect the air dome hose connection port for lint or flashing.
b. Use a small round device (small screwdriver) to ensure that there is nothing blocking the air dome outlet on
the tub.
D) The control needs to be replaced.
a. Replace the control only after you have completed steps A – C above, and verified that there are no issues
with the air pressure system.
Comments: - I don't know what satifaction they will give you, but you could contact Whirlpool. I don't know if it's fact, but some folks with this problem said that they were able to get the cost of repair covered in some cases, while others complained that they got no proper assistance from the manufacturer at all, so I really don't know for sure what good it will do, but it's worth a try. I'm sorry for your trouble and hope you find a good resolution to your problem. Best of luck and best wishes.
Posted on Sep 10, 2009
  • 180 Answers
SOURCE: Whirlpool Cabrio top loading washer F1 Error
F1 means the control board is shot. Call whirlpool and they should take care of the parts and labor even though your machine is out of warranty.
Posted on Nov 27, 2009
SOURCE: What does F1 mean on the cabrio washer?
I had the same error on my washing machine. I just called whirlpool customer service 1 800 253 1301. Apparently there are having several issues with this. I called them and after giving them the model number, and serial number, they gladly are replacing the washer board free of charge. They were excellent customer service, and i didnt even have to gripe! Thats what is good about customer service!
Posted on Mar 03, 2010
tzweeb
  • 318 Answers
SOURCE: what does F1 mean on my cabrio washer
i have changed dozens of these main control boards for this problem. whirlpool knows it is an issue and if you call them they may send you the part for free or suggest you have a tech come out and check it first, but most certain you will need a new main board.
1-800-253-1303 whirlpool
Posted on Aug 10, 2010
What does an F-1 code mean on the display? washer will not start.
power problem
  • Whirlpool Fault Codes - AppliancePartsPros.com www.appliancepartspros.com > Appliance Repair Whirlpool Range / Stove / Oven Fault Codes: Failure Code: Fault Code Description: Solution: 4 Digit Failure Codes (for 2 digit codes see below) F1 - E0
  • Washer Diagnostic& Repair - F1 Error Code power supply ... www.youtube.com/watch?v=BAVS9mI3JLQ
    • BY APPLIANCEVIDEO.COM
    • 4 MIN
    • 65K VIEWS
    2014-02-07 · Troubleshoot your trusty Whirlpool Top Load Washer that has these following symptoms: F1 Error Code At: http://www.appliancevideo.com To ...
  • Whirlpool Cabrio f1 error and how to fix it https://whirlpoolcabriof1error.wordpress.com Control board W10189966 will work with the Whirlpool model numbers listed at the bottom of this page. These models include the Maytag Bravos and Kenmore Oasis.
  • whirlpool F1 code - Appliance Repair Forum forum.appliancepartspros.com > ... > Washer Repair
    • 68 POSTS
    • FIRST POST: 2008-07-28
    2009-09-29 · Discuss whirlpool F1 code in Washer Repair. "whirlpool cabrio washing machine displays f1 code. have already pushed cancel and restart to no avail.
  • Cabrio Washer by Whirlpool F1 Error Code - Facebook www.facebook.com/CabrioWasherByWhirlpoolF1ErrorCode Cabrio Washer by Whirlpool F1 Error Code. 793 likes. Got the F1 Error Code? Tell your story! Share ALL your issues with this washer to warn others...
  • Whirlpool Fault Codes - Appliance Help Online appliancehelponline.com/whirlpool.html Whirlpool Range / Stove / Oven Fault Codes: Failure Code: Fault Code Description: Solution: 4 Digit Failure Codes (for 2 digit codes see below) F1 - E0
  • May 04, 2016 | Whirlpool WTW8200YW Cabrio Top Load Washer
    I have a Whirlpool Cabrio top load washer. When I load the clothes and start the washer and it begins to run I hear an alarm, it stops and a F1 flashes on the display. What does this mean?
    F1 (F60-68)
    Primary Control Failure F then 1 flashes when there is a primary control failure. Replace the machine control assembly.
    See Accessing & Removing the Electronic Assemblies.
    F1 flashing on the display indicates a primary control failure.
    "F then 1 flashes when there is a primary control failure. Replace the machine control assembly."
    The link below lists Cabrio failre codes.
    http://www.advantagesupplyfl.com/WhirlpoolCabrioWasherFaultCodes.html
    Dec 16, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
    What does F1 error code mean on washer
    It means you have a control board fault. Call Whirlpool and tell them the fault you are getting and see if it's recalled. There's a good chance. You can install yourself or have and appliance tech do it.
    Rich
    Western Appliance Repair Meridian
    Nov 19, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
    What does code f1 mean
    Hello
    Error code F1 means that the control of washer has either gone bad or about to go bad. This is a common issue with Whirlpool Cabrio washers. I have also seen them replacing the control without any charge, don't really know about the labor charges but they usually won't charge for the part. Please get back to me if you have any other questions.
    Kevin
    Nov 16, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
    What does F1 mean for a whirlpool cabrio
    F1 error code is for main board failure, replace main board
    Sep 07, 2010 | Washing Machines
    F1 code whirlpool
    whirlpool F1 code - Appliance Repair Forum THERE IS A RECALL ON YOUR WASHER,CALL THE FACTORY AND GET IT FIXED FOR FREE
    Dec 11, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
    I have a cabrio whirlpool washer and a F1 code keep's on coming up what doe's it mean
    i just called on mine for the f1 code and they said its a defect and would fix it call 18002531301
    Oct 04, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
    F1 error on Whirlpool cabrio
    it means that the control board is not sensing the water pressure (this tells the machine how much water to put in the washer) in my experience you have to replace the control board which will cost over 200 plus labor which will be over a 100
    Dec 23, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
    f1 code means the main control needs to be replaced. pretty common repair
    Dec 12, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
    Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
    55 people viewed this question
    Dan Webster
    Dan Webster
    Sal DeAngelo
