Question about Gateway Computers & Internet
I cannot install the mouse to my pc. - Gateway Computers & Internet
    Guru:
  • 324 Answers
Its very easy , what type of mouse, and what interface does the mouse have, if its USB connect to a usb port on the system, if its the DB9 pin type connect it to the db9 port, and once connected the system will identify the hardware automatically, if it requires drivers, it will request for it and follow the instructions
Posted on Apr 26, 2010
Nextech mouse through usb continues to install successfully, then freezes while trying to move about my laptop! No, it is not that the Lptp is working in the background, leaving the mouse to freeze th
Step 1:
For a standard trackball mouse, unplug the mouse, turn it over and then twist the retaining ring counter-clockwise to remove it. Remove the trackball inside the mouse. Clean the trackball with warm water and dry carefully. Clean the rollers inside the mouse with a cotton swab dipped in rubbing alcohol. Replace the trackball, then secure it with the retaining ring. Clean the outside of the mouse with rubbing alcohol and a cotton ball. For an optical or wireless mouse, clean the bottom of the mouse and the surface it sits on with a damp cloth. Solve Hardware Problems Make sure the mouse is connected properly. The connector will either be USB or PS/2. A PS/2 connector is color-coded green and can only be inserted in one direction. Check for any bent or broken pins or damage, then carefully plug it in, making sure the connection is secure. Reboot the computer. Connect the mouse to another computer, then reboot the PC. If the mouse works after testing it on another computer, the problem is most likely with your PC or operating system. Also, try a different mouse on your computer. If there is no PC freeze, your mouse is probably malfunctioning. Switch to a different USB port. Sometimes mouse freeze will occur if the mouse is connected to a USB hub. Connect the mouse directly to one of the USB ports on your PC. Try different ports until you find one that works. Replace the batteries. If you have a wireless mouse, replace the batteries with fresh ones. Also, try using a different kind of mouse pad. Sometimes surface imperfections can interfere with the operation of a wireless or optical mouse. Install more RAM or memory. If your PC doesn't have enough memory, PC mouse freeze may occur when you are running resource intensive programs. Installing more RAM will help your PC run more efficiently. Solve Software Problems Check for device conflicts. When you install another device on your computer, it can sometimes conflict with a PC mouse. Remove any new hardware and drivers you may have installed, then reboot the computer. Reinstall PC mouse drivers. In Windows, open "Control Panel" then "System." Select the "Device Manager" tab, then scroll to and select your mouse. Uninstall any drivers that are listed. Unplug the mouse and reboot the PC. Plug the mouse back in, reboot the system, then allow Windows to reinstall the drivers if prompted. Remove viruses. PC mouse freeze and other serious problems can be caused by viruses lurking on your system.Set the program to run a complete scan every 24 hours. Also make sure the virus definitions are updated regularly. Turn off video acceleration. Sometimes video acceleration can cause PC mouse freeze. Go to "Control Panel," then click "Display," and then "Change Display Settings." Click the "Advanced Settings" button, then the "performance" tab. Set the acceleration slider to "None," then reboot. Repeat the process moving the slider up one notch until you have the maximum amount of acceleration with no mouse freeze
Feb 18, 2013 | Computers & Internet
Cursor freezing
Remove viruses.
hope this helps
Oct 09, 2012 | Sony Vaio VGN NS20E Laptop Car- Air DC...
How to install wirless mouse
It depends on the wireless technology used by the mouse.
1. Infrared
If your mouse used Infrared for communicating with your PC, you will have to place an Infrared receiver on your desk, in line with the mouse you want to install. You will definitely have to install the drivers supplied with the mouse/Infrared receiver.
2. Bluetooth
If the mouse uses Bluetooth, first you either will have to install a Bluetooth dongle on your PC/Laptop (if it doesn't have Bluetooth integrated) or activate the Bluetooth on your PC/Laptop. Then, using the Bluetooth software supplied with the dongle or PC/Laptop, search for new devices and choose the mouse to pair with. You may have to install the software provided with the mouse for if to work.
May 09, 2011 | Computers & Internet
To install the mouse
jut plug in ur mouse... if its a usb mouse it will be automatically installed.... if u have an installation cd, insert it first... have the s/w installed and then plug in ur mouse...
good luck
Mar 16, 2011 | Computers & Internet
How do i connect my hp wireless mouse to the computer
The first step is to install its driver, after taht you can connect the wireless dongle into a free USB port of your computer, then put the batteries inside the mouse and turn it on, in the most of cases, the wireless dongle and mouse sinchronize automatically, if they don't, there's a small botton in both devices press it in each one to synchronize them manually.
Feb 25, 2011 | HP Wireless Optical Mouse
Virus on pc. installed norton internet security.
Never before have I heard of a VIRUS installing ANTI-VIRUS software. I have had intermittent mouse problems before though. Thought it was a virus, as I interchanged with like 4 other (used) mouses (mice?) and there was no change. Found a fifth used mouse-a genuine Microsoft mouse (I was running Vista 64bit Home Premium) and installed it and my mouse problem disappeared ("installing new device"). I couldn't figure it out for the longest time, (still can't), I'm just glad it cleared up.
I run AVG FREE antivirus software and Ad-Aware anti-spyware (also FREE). I run both of those at least once a week, in addition to defragmenting once a week, haven't had a problem since.
Jun 06, 2010 | Gateway Essential 400 PC Desktop
How to install a technika mouse?
my technika laptop mouse wired wont install on my laptop
Oct 31, 2008 | Casio Parts Cash Register PC Desktop
How do i install a mouse on windows98 without original startyup disks
For installing a generic mouse you need not to use any startup disk.
1. Make shutdown your pc.
2. Connect your mouse.
3. Boot your pc.
A message will be display by window that new hardware found, (if your mouse hardware is differ from previous mouse), and window will install the required driver for your mouse.
Thanks
Iqbal
Mar 10, 2008 | Belkin MiniScroller Mouse
Cordless Mouse & Keyboard install I need help
if you have a disc for the new items ,install first,shut down pc, then take the old mouse & keyboard off connect the new wireless ones before rebooting
you may need to sync the mouse & keyboard by holding in the small little button on each item and the reciever unit untill the lights come on indicating it is recieving the signals from both mouse & keyboard.if this does not work put the old mouse back in reboot then go into control panel / mouse, and sellect wireless mouse ,turn off the pc plug the new mouse back in then boot up
good luck
Terry
Mar 09, 2008 | Computers & Internet
Computers & Internet Logo
22 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
