Question about Whirlpool GH9185XL Microwave Oven
F7 code on Whirlpool Microwave model GH9185XLT - 1
We have a Whirlpool microwave model GH185XLT-1 model, 1100 watts, manufactured in 2002. After we enter the time and press starts, it goes for a short while and then stops displays -F7- on the display. What does this mean?
We've turned the breaker off and on a couple times, still, same problem.
I did notice that our power went off and then on this morning. Could that have anything to do with it?
Is this fixable or do we need to look for a new microwave
    Top Expert:
  • Whirlpool Master
  • 25,266 Answers
Power to magnetron
interrupted
12. Replace inverter.
13. Replace all parts and panels before operating.
14. Plug in microwave oven or reconnect power.
15. If problem persists, unplug microwave oven or disconnect power.
16. Replace electronic control.
17. Replace all parts and panels before operating.
18. Plug in microwave oven or reconnect power.
19. If problem persists, unplug microwave oven or disconnect power.
20. Check for reversed plug connection on controls or loose wiring.
21. Replace all parts and panels before operating.
22. Plug in microwave oven or reconnect power.
Posted on May 23, 2017
bestdarngood
  • 3037 Answers
SOURCE: whirlpool microwave oven model gh5184xpq
Models: GH9177XL GH5176XP GH5184XP GH6178XP GH6177XP
KHHS178L KHHS179L
Microwave will not operate (cook). F7 error code
appears on the display.
Electrical circuit interruption between L1 and Neutral in
the microwave inverter circuit.
Possible reasons:
1. Check door, hinge and cavity front alignment and adjust
as needed.
2. Check the operation of all interlock switches.
3. Check over temperature protector for the magnatron.
4. Check all Cavity Thermostats for closed circuit.
5. Unplug the oven for at least 40 seconds. If this solves
the problem
A. Check the Cooling Fan for proper operation or
blockage
B. Check the resistance of the magnetron thermostat.
It should be 0 Ohms, replace if necessary.
6. Check that the control cable to the 1100 watt inverter
is properly connected to plug P2 on the display PCB
& Adjust or Reconnect
7. If interlock switches operate correctly, replace 1100W
inverter.
8. If problem persists, replace control assembly.
Please let me know if you need any more help or have further questions about anything that I have posted. I would be glad to help
thanks
Posted on Apr 27, 2008
SOURCE: Sylvania microwave
my sylvania mircro wave doesnt shut off after i use it. it is healing---just rnning with th light on. i have to unplug it to stop it and then plug it bak in when i want o use it. can i repair it?
Posted on Jul 22, 2008
SOURCE: No heat in GE XL1800 1100 Watts microwave
model # JVM1870BF001 GE Profile spacemaker XL 1800 microwave
after episode of using defrost which burned food--now stopped heating--still has power/fan--don't know how to change fuse--please help
Posted on Sep 21, 2008
grandadfixer
  • 99 Answers
SOURCE: Smoke Coming from inside of Microwave even when warming for 10 seconds
Proberly wave guide cover at side it can get grease behind it,And when you used it with small load it tried to cook it and then burned the mica cover,Take mica cover off and try it without it to seeif problem resolved if ok,New cover can be obtained if req.Regards grandadfixer
Posted on Oct 11, 2008
SOURCE: Whirlpool GH5184XPQ 1100 Watts Microwave Oven Fan Won't stop running
Check for any cardboard on the side - that is not removed.  This also can cause problems :
- Kiran.
Posted on Oct 19, 2008
How CAN i TEST MY MICROWAVE?
Most common cause of an F7 code on these models is a bad inverter or magnetron. Generally it is best to replace both the magnetron and the 1100 watt inverter board at the same time, since a bad magnetron is usually what burns out the inverter board.
Jul 24, 2014 | Whirlpool Gold GH5184XPS 1.8 Cu. Ft. Over...
Whirlpool microwave oven model gh5184xpq
KHHS178L KHHS179L
Possible reasons:
as needed.
the problem
blockage
inverter.
thanks
Apr 27, 2008 | Whirlpool GH9185XL Microwave Oven
Microwave error message F7
This is for whirlpool models.Try this procedure and see if it helps.what is your model?
KHHS178L KHHS179L
Possible reasons:
as needed.
the problem
blockage
inverter.
Feb 11, 2013 | Microwave Ovens
MY microwave is giving me an error code F7 - call for service
This is all i could find on this error, Its alot to check. Microwave will not operate (cook). F7 error code
Possible reasons:
as needed.
the problem
blockage
inverter.
Jun 23, 2011 | Whirlpool GMH5205XVS Microwave Oven
F7 error code displayed
Hi jruszas,
This F7 error code that you have on your display is all about the function key stuck on ERC. The only way to resolve this is to replace control board (also called ERC or clock). You may contact Sears for the replacement part at 1-800-252-1698; M-F 6:30 AM-10:30 PM - Sat 7:00 AM-9:30 PM - Sun 7:30 AM-9:30 PM - All times Central. Just get your model number ready when you call.
Hope this helps.
Thank you for using FixYa.
May 22, 2011 | Whirlpool MH9181XM 1100 Watts Microwave...
What does error code F7 on our Whirlpool g2microven mean?
Hi rongoin,
This error occurred if you have a stuck function key on ERC. This can only be resolved if you will replace control board (also called ERC or clock). You may contact Sears for the replacement part at 1-800-252-1698; M-F 6:30 AM-10:30 PM - Sat 7:00 AM-9:30 PM - Sun 7:30 AM-9:30 PM - All times Central.
Hope this helps.
Dec 11, 2010 | Whirlpool GH6178XPQ 1100 Watts Microwave...
Error F7
Possible reasons:
as needed.
the problem
blockage
inverter.
Nov 18, 2009 | Whirlpool GH9176XMS 1100 Watts Microwave...
F7 Error
This is schematic:
http://www.servicematters.com/docs/wiring/wiring_main.htm
But your correct model # is: GH5184XPS4
F7 Power to magnetron
interrupted
1. Check the door, hinge and cavity front alignment. Adjust as needed.
3. To check the over-temperature protection for the magnetron, unplug
4. After 40 seconds, check to see whether this solves the problem.
5. If this solves the problem, check the cooling fan for proper operation or
blockage.
6. Unplug microwave oven or disconnect power.
7. Check resistance of the magnetron thermostat. It should be close to
0 ohms. If necessary, replace magnetron thermostat.
8. Check that the control cable to the 1100 watt inverter is correctly connected
to plug P2 on the display PCB. If necessary, adjust or reconnect.
9. If interlock switches operate correctly, replace 1100W inverter.
10. If problem persists, replace electronic control.
11. Plug in microwave oven or reconnect power.
Dec 06, 2008 | Whirlpool GH5184XPQ Microwave Oven
We have a whirlpool GH5184XPS-4 microwave that we are getting an F7 error on. We removed control panel and parts of the board were scorched. we resoldered in loose parts still have smae problem
From the technical sheet usually located behind the control panel or grille:
F7 Power to magnetron interrupted
3. To check the over-temperature protection for the magnetron, unplug microwave oven or disconnect power.
5. If this solves the problem, check the cooling fan for proper operation or blockage.
7. Check resistance of the magnetron thermostat. It should be close to 0 ohms. If necessary, replace magnetron thermostat.
8. Check that the control cable to the 1100 watt inverter is correctly connected to plug P2 on the display PCB. If necessary, adjust or reconnect.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Whirlpool GH9185XL Microwave Oven Logo
597 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
