Question about Fisher and Paykel DEGX1 Electric Dryer
Dryer not heating the air
I cleaned out the lint mechanism by unscrewing the cover inside the drum and it was packed with lint! I cleaned it all out (though I don't know why there was such an accumulation since I clean out the lint bucket every time) vacuumed and wiped it clean. Reassembled it and it still has no hot air. I went outside and made sure that there was airflow through the vent on the outside and there is good air flow. I had this problem once before and had a repairman here who referenced a reset button. I am pretty much a do-it-yourselfer, so if there is such a reset butten...where is it? If no such button...what are my options?
  • sfalbaum Apr 24, 2010
    I need more basic information to begin. I don't know how to access anything that you mentioned.
  • sfalbaum Apr 25, 2010
    how do I access these areas
  • Fisher and P... Master
  • 3,051 Answers
Hello there: Normally this is the problem please follow the troubleshooting guide that i have provided Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable. Thermal fuse looks like this On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.) Wiring A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to. ok? so please follow this guide ok hope this all helped Best regards Mike
Posted on Apr 25, 2010
  • 1 more comment
  • Michael Thomas
    Michael Thomas Apr 25, 2010
    This should help out too
    best regards mike
  • Michael Thomas
    Hello there
    there should be a couple of screw or clips that you will need to unclipwith a flat tip screwdriver like in the pict
  • Michael Thomas
    sometimes the lint filter can be unscrewed and removed to assist cleaning out the lint
    President:
  • 2,468 Answers
Check the element,the high-limit thermostat and cycling thermostats on the element housing,if these all check good,then look for a thermal fuse on the dryer vent piping near the exhaust vent outlet as if this opens like a fuse the element cannot heat,most of these resettable thermostats are bi-mtetal and reset automatically when they cool off,but the thermal fuse is a one time device like a house fuse and when they burn out you need to replace them
Posted on Apr 24, 2010
  • danny Hendrickson Apr 25, 2010
    all of these components are located on the element housing or burner tube or near the dryer vent outlet in the lower area of the inside of the machine
    you will need to remove the screws on the base of the front panel cover,then lift upward like a car hood and the clips near the top will let go,then remove screws that hold the top cover on,then remove the drum belt and then remove the drum,then you can access all the components
What is fault code 6 mean?
Hi Darrell, The link below is about how to trouble shoot and fix your dryer.....I hope this helps.....CHEERS..
http://removeandreplace.com/2013/09/21/fix-clothes-dryer-heating-drying-clothing/
The most common causes for an electric or gas dryer to stop drying or heating is:
1. The dryer lint screen (lint trap) has not been cleaned (poor or restricted airflow).
2. A clogged or kinked (bent) dryer air vent hose (inadequate or no airflow).
3. Drum has stopped turning, broken drum drive belt.
4. Overheated or bad motor (possible thermal overload).
5. Thermal fuse or thermostat (could be caused from dryer air vent hose lint buildup)
6. Heating element burnt out.
7. Loose electrical plug or power socket.
8. Other mechanical issue, fault or malfunction.
Mar 31, 2016 | Fisher and Paykel DGGX2 Dryer
No heat in drum heat out of vent maytag mle2000ayw
Are you sure you dont need a professional Dry Vent inspection and cleaning?
If you are in the market for an Dryer Vent cleaning check out Dryer Vent Cleaning Dallas Tx.
Mar 17, 2013 | Maytag Neptune Dryers
There's a slight burning smell coming from the dryer drum.
Some item may have gotten between the drum that rotates and the housing and during the rolling of the drum this item may be heating up from the friction. Check closely to see if you can find anything rubbing on the drum.
Jan 22, 2013 | Maytag PYE2300AY Electric Dryer
My amana LE9207w2 has been taking longer and longer to dry the clothes. I clean out the vent regularly... when I use it a lot, it shuts down for hours. Now it stopped altogether with wet clothes insid
First the dryer vent should never go out of the roof thats just asking for trouble. The dryer has to work harder to get the air out. any lint that would be in the vent when the dryer shuts off just comes back down instead of being blow outside. there is probably a buildup of lint around the exit pipe on the roof. As far as your problem either you have a bad motor or there is something stuck in your blower wheel. the best way to check this is to reach inside your dryer and try to turn the drum. If your drum spins freely then hold the door switch and push the start button keep holding the door switch the dryer will be buzzing now turn the drum if it starts to go after you push the drum then you have a bad motor. If the drum does not spin freely then you probably have something stuck in your blower wheel
Aug 26, 2012 | Dryers
GE dryer, no heat?
Your heating element is most likely burned out . Have you made certain all of your lint vents for the dryer are not clogged ? Also , be certain to clean the lint filter every time you use the dryer. A buildup of lint in the dryer , in the hoses & on the back of the dryer inside in between the drum & the outer covering can get so hot it will catch on fire when the heat is working , and also , without a fire will burn up your heating element.
May 18, 2012 | Dryers
My dryer SHOWS ERROR 68 ON PANEL and shuts off?
Error 68 can mean that your start button is stuck; check to make sure the button is not stuck in the pressed position behind the controls cover.
Apr 25, 2010 | Frigidaire Electric Dryer
My dryer heats,tumbles,but takes several cycles to dry a load(small).Not much air coming out of vent and have cleaned vent out.Any ideas?
The fan that pulls the hot air through the dryer and pushes the exhaust out through the vent hose is plugged with lint. You will want to remove the cover on the fan and manually clean the fan out. I had the same problem with my dryer, I was astounded by the amount of lint that was trapped in the fan.
Also look inside the cloths drum on the back wall and make certain the hole in that wall are not clogged with lint also. Use a flash light and make sure the hole are perfectly clean.
Good luck, clean it all out and let me know.
Regards,
Sep 09, 2009 | Maytag Dryers
Burning smell in in dryer
Take a flashlight and look inside the drum at the holes on the back end of the drum where the hot air comes in. On mine, there is an air deflector on the back side of the drum and the space between this deflector and the drum was packed with lint. The lint blocked about half the holes. I had to take the drum out, remove this deflector by removing four screws inside the drum then cleaning out the lint. The lint was all brown and scorched.
Jun 07, 2009 | Whirlpool LER4634J Electric Dryer
Whirlpool duet electric dryer taking too long to dry
A1 Pull the dryer out away from the wall. Unhook the vent from the dryer completely. Do not put anything over the dryer exhaust on the back of the dryer. Do a normal load with the vent unhooked. If it dries better or ok like this then the problem is in the dryer venting. Like a blocked vent pipe or a smashed or restricted vent hose.
A2 - If the vent  doesn't make a difference, then check the blower wheel for excessive lint build up, check that there isn't anything stuck to the air intake baffle inside the drum, (i.e. the screen on the back wall of the dryer when looking into the drum). Check the lint filter chute for blockage. Check that the heating element isn't shorted to ground. Check the exhaust temperature of the dryer. A meat or pocket  thermometer can be used for this. It should cycle between 120 degrees and 170 degrees. Check that the drum seals to make sure the are not worn out.
Mar 03, 2009 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Kenmore elite HE4
THE AIR FLOW THROUGH THE DRYER BEGINS UP THROUGH THE HEATER AND INTO THE DRUM THROUGH THE HOLES INSIDE THE DRUM TO THE LEFT IN THE REAR.
THESE HOLES ARE METALIC IN COLOR AND MAY SHOW SIGNS OF DISCOLORATION DUE TO THE HEAT OF THE HEATER ASSEBLY. FROM THERE, THE AIR WILL FLOW ACROSS THE CLOTHES AND THROUGH THE LINT FILTER.
IF YOUR LINT FILTER IS LOCATED ON TOP OF THE DRYER,
THE HOLES WILL BE IN THE BACK WALL OF THE DRUM ON THE RIGHT. IF YOUR FILTER IS LOCATED IN THE FRONT OF THE DRUM, THE HOLES WILL BE JUST BELOW IT.
USUALLY, LINT WILL COLLECT DOWN INSIDE THE SPACE WHERE YOU INSERT THE FILTER ON A FRONT LOCATION.
PULL THE FILTER OUT AND LOOK DOWN INSIDE. USE A CENTER CARDBOARD FROM GIFT WRAP TO CLEAN OUT THIS AREA. FLATTEN OUT THE CARDBOARD ROLL AND PUT IT DOWN IN THE SPACE ATTACHING THE OTHER END TO A VACUUM CLEANER HOSE.
ALSO, DISCONNECT THE DUCT WORK FROM THE REAR OF THE DRYER AND CLEAN OUT THE DRYER DUCT AND THE HOUSE HOLD EXHAUST DUCTING. WHEN REATTACHING THE FLEX DUCT TO THE BACK OF THE DRYER, MAKE SURE THERE ISN'T ANY EXCESS FLEX DUCT SNAKING BEHIND THE DRYER. CUT IT TO THE LENGTH NEEDED. MAKE SURE IT ISN'T FLATTENED BETWEEN THE DRYER AND THE WALL WHEN YOU MOVE THE DRYER BACK INTO PLACE.
Apr 01, 2008 | Kenmore Elite HE4 Electric Dryer
Fisher and Paykel DEGX1 Electric Dryer Logo
238 people viewed this question
Top Fisher and Paykel Dryers Experts
Tim Whalen
Craig Butler
Craig Butler
Virgil Watts
Are you a Fisher and Paykel Dryer Expert? Answer questions, earn points and help others
