Question about Dryers
How do you replace the belt on a Maytag clothes dryer
    Passionate:
    Visited the website for 10 consecutive days.
    Champion:
  • 202 Answers
Frist unplug dryer then take front panel off dry then take lint housing off there 4 screw on both side take that off remove broken belt put new belt on around dryer drum an loop belt over white idler pulley an around motor pulley idler pulley put tension on the belt
Posted on Apr 25, 2010
How to replace an Dryer Drum Belt ?
check youtube for a lot of vids on this subject
Feb 14, 2018 | Maytag Performa PAV2200
Just replaced the belt & it spins until I put clothes in it?
It sounds like you didn't get the belt tight enough to handle the load of wet clothes. Suggest you use something to put more pressure on the belt while tightening the motor bolts. Although there is a recommended torque for the belt, most technicians don't measure when they replace a belt.
Jan 01, 2012 | Maytag Dryers
The Atlantis Gas Dryer comes on, heats the clothes, but will not tumble the clothes so that only the outside of the clothes are dry.
hello,
I believe the the problem with your dryer is a broken belt this youtube i have attached will show you how to replace it
http://youtu.be/6ufArteqWXk
Jul 23, 2011 | Maytag Atlantis MDG7400AW Gas Dryer
Dryer can't turn on. Start button just buzzes.
replace the "Broken-Belt" switch by the drum motor,when the belt breaks it shuts off the heating element so as not to burn the clothes because the drum can't turn to produce air flow to dry the clothes as they tumble,when you replace the belt it will make the switch close the circuit again and it will start
Dec 26, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Belt replacment
Here is a diagram from kenmore corp. that should help you out
Maytag Dryer Belt Routing
This is the most common belt routing found on most Maytag brands clothes dryers.
Since you will have everything disassembled to change the belt, this is an excellent opportunity to vacuum out the cabinet to remove dust and lint and perform preventative maintenance on your dryer. When replacing the Belt is is a good idea to also change the Drum Support Rollers, Drum Glides, Idler Pulley and Clips. All of these items are easily changeable when replacing the belt. The upside is that your dryer will operate like new.
Dec 04, 2009 | Kenmore 66862 Dryer
Maytag Performa PYE G2200 gas dryer, the dryer seems to turn on but the drum will not turn.
Based on the information provided, it sounds like a broken drum belt is at fault. Below is an illustration of the drum belt.
http://www.repairclinic.com/SSPartDetail.aspx?s=t-PYG2200+-%3d%3di529597&PartID=529597
Here is a parts/disassembly diagram:
http://www.repairclinic.com/Dryer-Gas-Maytag-Style-Appliance-Diagram
Here is a belt installation diagram:
Dryers have a drive belt that turns the clothes drum. If the belt breaks, the drum stops rotating. Then you need to replace the belt, and often the idler pulley, because the pulley tends to wear out at the same time.
Click here for a belt installation diagram.
All links courtesy of www.repairclinic.com
Aug 16, 2009 | Maytag Dryers
My dryer wont tumble
Your belt is not installed correctly. The weight of the clothes is making it slip.
Jun 30, 2009 | Maytag SDE2606 Electric Dryer
Maytag gas dryer squealing
Hi, this is a belt issue. make sure the tension on the belt/motor is sufficient. adjust to specs. if the belt is fine, this will be bad bearings in the roller assembly.
Replace the rollers in this case.
May 21, 2009 | Maytag Dryers
Dryer won't turn
The problem is likely a slipping dryer belt. The belt tensioner is not working or the belt needs replacing.
Apr 29, 2009 | Maytag Neptune MDE4000 Electric Dryer
GAS DRYER, JUST REPLACED BELT BUT DRUM WILL NOT TURN WITH CLOTHES IN IT.
My guess: bad motor bearings which let the rotor move off-center and bind.
Usually the motors are not repairable
Apr 25, 2009 | Dryers
Dryers Logo
113 people viewed this question
Top Dryers Experts
