Question about Frigidaire FAC126P1 wall/window Air Conditioner
Frigidaire window air condition unit
I bought a fac127s1a-12,000 btu's can you tell me why they have styrofoam pack inside of the the walls over and around the blower fan what type of material the blower fan is made of thank for asap answer i need to install unit
  • 455 Answers
Hello,Lilo The styrofoam pack MUST stay in place.When in operation the air tempature is so cold the unit will condensate(create water)if not insluated.Your unit would LEAK all over the place.The blower fan is a PLASTIC composit and should not rust.
Posted on Apr 24, 2010
How do I remove the interior packing styrofoam from PAC CN120E
that IS NOT PACKING FOAM!!!that is used in air conditioners nowto be energy efficient,its cheaper than plastic
Jun 06, 2015 | DeLonghi PAC-C120 12,000 BTU Home Electric...
The blower dosent work on my fra124ht1 frigidaire ac what can be done
If the unit is not producing any cool air, then you must see if there are replacement parts available for this unit from your manufacturer. Some units, this small, do not have many parts that can be purchased and repaired.
Jul 18, 2012 | Frigidaire fra12h1 wall ac,12,000 btu 120v
I HAVE STYROFOAM INSIDE THE AIR CONDITION DO I NEED TO REMOVE IT
Is it packing or is it insulation? If packing, as in you just bought this unit and have never used it, remove it.
Aug 05, 2011 | Haier ESA3109 WallWindow Air Conditioner
What is the btu of this model.m7q08f2a.
Hi, to find out the tonnage of your unit in b. t. u.'s, look at the 08 in your model number. There are 12,000 btu's per ton of cooling. You have a window /wall unit, and according to the model # 08 is not a 1/2 ton or a 1 ton, but a 3/4 ton unit or 8,000 btu's if indeed this is the correct model number. Most units we come across are in btus as 06 which is 1/2 ton, 12,000 is 1 ton, 018 is 1 1/2 ton and on up with a properly matched indoor coil. Your unit is a package window unit, so both coils are equal.
Sincerely,
Shastalaker7
A/C, & Heating Contractor
Nov 18, 2010 | Maytag M7Q08F2ACOM Air Conditioner
We installed a 12,000 btu Frigidaire unit last night and it doesn't seem to blow 'cold' air. And it doesn't cool our tiny 12x12 bedroom...
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool…
Air Conditioner Trouble - Review the Possibilities
heatman101
Aug 26, 2010 | Frigidaire FAC126P1 wall/window Air...
IS THERE SUBPOST TO BE STYROFOAM INSIDE THE AIR CONDITION, IT IS BEHIND THE FAN WHEEL, AND ON BOTH SIDES INSIDE UNIT WATER RUNS OUT THE FRONT, NOW UNIT DOES NOT TRUN ON. THANKS, DEE
Yes to the Styrofoam , If there is water running out the front of the system your drain is blocked and or the system  needs to be removed to inspect the drain tray and clean out if required.(serviced). As for it not turning on , check that the fuse isn't blown as the water may have shorted the controls wires and blown the fuse
May 10, 2009 | Haier 5200 BTU Window Air Conditioner...
Noise
Adding cloth or any other sound absorbing material will not work. There is not enough room to add anything appreciable in the fan area.
Jul 22, 2008 | Frigidaire FAC107P1A Wall/Window Air...
Frigidaire Air Conditioner - FAC102P1A Compact II th
I spoke with the Frigaire support line 706 374-4432. They said that the large piece of styrofoam, that extends from side to side and nearly top to bottom, is part of the unit. It should not be removed.
May 27, 2008 | Frigidaire FAC126P1 wall/window Air...
Frigidaire FAC126P1 wall/window Air Conditioner Logo
872 people viewed this question
Top Frigidaire Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Are you a Frigidaire Heating and Cooling Expert? Answer questions, earn points and help others
