Question about Maytag Neptune MAH5500B Front Load Washer
Error code upsidedown f and e
This happens after I have done more than 3 loads in one day if we unplug the machine for an hour it sometimes will work fine we have had two recall notices on this machine purchased in feb 2006 model # mah8700aww
serial number 10982232gg
thank you so much
    President:
  • 1,314 Answers
Ok you need to reply to the recall notices as that could be causing your promblems the code you are seeing is unusal high low temptures being sensed pop me an e mail at b4829@yahoo.com
Posted on Mar 23, 2008
LG Front Load Washer
te is a error code for a bad thermister. it senses the temp of water in the tub. this needs to be replaced
May 01, 2014 | LG WM-2277HW Front Load Washer
Washing machine want wash
please do a hard reset by leaving the unit plugged off from power for few hours
Jun 30, 2008 | Hotpoint Ultima WF860 Front Load Washer
I have a Kenmore HE3t washer than continues to stop during the cycle and flash the F2 error code even after cleaning out lines, hoses, trap, boot and replacing the drain pump.
It is possible that the brushes on the motor that spins the drum are worn down. The drum will start and stop when this happens. Check the brushes.
Nov 07, 2013 | Kenmore Washing Machines
My Maytoag Bravos Top load washer drains really
Is the drain hose kinked or clogged? Is the drain hose installed properly? look in the installation Instructions, Press POWER/CANCEL to clear display........ hope this helps.....
Jul 09, 2009 | Maytag Bravos MTW6600T Top Load Washer
Intermittant trouble with code d 11
Answer Duet HT®
Duet®
duet_f_dl_actualsize.gif Duet SportTM
This error code indicates that the door is not locking.
Is the washer door firmly shut?
The door must be completely closed for the washer to operate. The door may look as if it's closed, but it may not be latched. Open the door and firmly close it.
Were you washing a large load?
Before you close the washer door, check for laundry items sticking out beyond the door opening. Leave enough space in the washer to allow the clothes to freely tumble. Reduce your load size if needed.
fl_doorseal.jpg To remove the error display, press Pause/Cancel twice.
If Pause/Cancel does not work:
  1. Unplug the washer or disconnect the power for one minute.
  2. Plug in the washer or reconnect the power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, and all of the other conditions above have been checked, call for service.
Dec 19, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore Elite he3t model 11045972404
POSSIBLE COMMUNICATION PROBLEM BETWEEN MAIN AND MOTOR CONTROLLER
Nov 22, 2008 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
F 06 error code
The "F06" error code is a Motor Speed error. The following link explains the recommended course of action you should take:
http://www.fixya.com/support/r714929-f06_error_whirlpool_duet_kenmore_elite
Now, another tip to try BEFORE you assume you have any failed parts is to unplug the washer for at least 30 minutes. This is recommended by the manufacturer to reset the main computer (or CCU). Sometimes this tip will reset most common system errors. If the problems persists, I would recommend checking the wiring harness between the Motor Control Unit (MCU) and the Drive Motor, followed by resistance checks of the motor windings. You may have a loose connector somewhere (as you suggested) or a component beginning to fail after it heats up (hence, the reason why the washer works for a while, then sometimes fails). Intermittent problems aren't always easy to troubleshoot. If your symptoms keep reocurring, take note of when and how (i.e., after several loads, during heavy loads, during final spin, etc.). This will give me an idea of what may be causing any repeated error codes. I hope you find this information helpful. Let me know if you require additional assistance.
Sep 08, 2008 | Whirlpool Duet GHW9150P Front Load Washer
How do i find what an error code means?
if that is a whirpool or kenmore remove bottom panel look for tech sheet in plactic bag codes are in it
Sep 02, 2008 | Washing Machines
Cycle running for hours
With the machine off using any button but power and cancel and press 2-5 seconds on then repeat 5 times, you will see 88 and if a code is stored it will flash or if F 2 comes on your panel is shot and cost 100 plus to change.
Aug 04, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Error code upsidedown F followed by an e
whats the model number on the washer and whats it doing and when get the model number off the serial plate and the serial number
Mar 22, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
375 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
