Question about Sharp 25L-S100 25" TV
How do i adjust brightness without remote - Sharp 25L-S100 25" TV
  • yovanny13 Apr 24, 2010
    I have a rca tv model number 1989 I fault a
    transistor
    EN LA PIESA S20520WN model
    1104-01AKH
    RCA H850
    THIS CAN GET ME ALGUIN PIESA
    01AKH RCA 1104-H850
Toshiba mv19m4..can i get to the menu without a remote? Want to adjust brightness..
YES THER WIIL BE A BUTTON THAT SAYS MENU DOWN BELOW AND THERE YOU CAN ADJSUT THE BRIGHTNESS CONTRAST SHARPNESS AND SOMETIMES DENSITY OF THE SCREEN INCLUDING THE COLOR
Dec 04, 2016 | Toshiba MV19M4 19 in. TV/VCR Combo
How to adjust the brightness without a remote control
Is it possible that the menu button (and possibly other buttons) are on the side or top of the tv? You don't say what make or model# you have so I can't research it. Many sets hide their buttons and even extra A/V inputs on the side for a cleaner look. I know my Sharp Aquos has the control buttons on the right side. If you don't have any buttons then you will either have to get a replacement remote from the manufacturer or find an appropriate universal remote that can access brightness
Aug 28, 2015 | Televison & Video
How to adjust the brightness without the remote control.
  • Surprisingly many cell phones, such as the Samsung Galaxy line, come with built in IR Blasters- this means they can act like a universal remote control.
  • Purchase a low cost universal remote as a replacement.
  • On some models there is a small manual brightness adjustment, a small wheel with ridges, usually on the bottom portion of the front of the set.
I have an older sharp tv. How do I adjust the brightness without the original remote?
You should be able to use the buttons on your TV to adjust settings. Using the menu channel and volume buttons to navigate the menus.
Nov 18, 2014 | Sharp Cameras
We have had this 24 inch Avanza, Honeywell television for almost 1 yr. now. the problem is the brightness and the picture becomes very dark especially when we lay down at night, sometimes use something to...
The brightness issue is indicative of a power supply problem. The remote does not control it.
You may be able to find a replacement OEM remote by searching several sites online that offer them.
Jan 11, 2014 | Honeywell Avanza 32" Class LED-LCD 720p...
Brightness adjustment
There will be a control panel on the TV, usually on the side of the TV. You can use these buttons to enter the menu and adjust picture brightness. You can find an inexpensive universal remote easily.
Nov 04, 2013 | Sharp Aquos Televison & Video
How do we adjust color without a remote ?
Hello
If your TV has a "Menu" button on its front panel, press it once to get into its menu option. Surf thorogh and come to the picture control window. There you can see the adjustments. Will be Brightness, Contrast, Colour, Sharpness, Tint etc. Select the option you want to adjust, advance or decrese its parameter by volume Up/Down buttons. If there is no 'Menu' button on its front panel, it will be impossible to adjust these parametes withoug a remote control. OK.
Jul 24, 2011 | Televison & Video
The remote does not work and the tv will not accept an universal remote.How can I adjust the color, brightness, contrast, and etc. with out a remote. The screen is dark and can not be adjusted without a...
Tries press the tv menu button on the tv front frame bazel to select color,brightness,contract so on...Adjust ur setting.Try website like remotes.com to buy an a exact to the original remote.
Oct 20, 2010 | Panasonic PV-20DF63 20 in. TV/DVD Combo
How can i access the menu to adjust picture without the remote
On front of TV Press and hold vol- and vol+ together menu should apear then.
Jun 11, 2009 | Philips 60PP9202 60" Rear Projection...
Replaced bulb-now very bright white display
go to menu and to screen and adjust brightness and contrast
Jan 27, 2008 | Toshiba TDP-S20U Multimedia Projector
Sharp 25L-S100 25" TV Logo
246 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
