Question about Euro-Pro NV22 Shark Navigator Bagless Upright Vacuum
Shark navigator n22
The roller brush stops when backing up and sometimes when going forward.
What I tried and it worked for me is to losen the hose slightly from where it connects to the long plastic tube on the side to allow the little hole to show. What that does is to lessen the suction power a little since the problem is that the suction is too powerful on the carpet and the roller freezes.
Posted on May 22, 2010
I have the shark rotator vacuum and the brushes won't spin
Hello again Lois Victor,
Make and model number always help... Thanks.
If you don't have your manual...
find them FREE at
Shark NV750ANZ Owner Manual
or here..
Shark Rotator NV752 Owner Manual
or by going to
http://poweredliftaway.com/
AGAIN... hope this helps
Carnac the Magnificent
Jan 10, 2018 | Shark Vacuums
My shark navigator delux model is nv4226 the brush will not spin it is clean an I thought perhaps the belt was stretched so I replaced it and the brush still doesn't move.how can I fix this
Hello, this is Ava with Think Crucial.
There are a number of reasons why your brush roller has stopped moving. General maintenance to your vacuum is crucial and will help it work at peak performance.
First things first lets focus on the brush roller. Unplug the vacuum and turn it on its side. Look for any noticeable clumps of debris or hair strands that may be caught in the brush roller. Remove these obstructions, probably best to do so with a scissor if it's hair or long pieces of carpet fibers. After removing the debris try manually rotating the brush roller to uncover other hidden clogs. Another thing to take note of is the condition of the bristles on the roll itself. Are they loose or worn down? These are signs that your brush roller is in need of replacing.
While checking out your brush roll you might as well take a look at your vacuums belt. Your belt should be replaced about every three months. After regular usage, the belt will stretch out, lessening the tension on the brush roller. Lesser tension diminishes the brush roller's turn rate and speed. If the belt feels loose then it certainly is affecting your vacuums suction as well as your brush roll not moving at all.
You can purchase a wide variety of high quality Shark replacement parts for your Shark vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/search?type=product&q=shark
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Dec 24, 2016 | Shark Vacuums
Roller on shark navigator professional
Ava B.
Nov 27, 2016 | Shark Vacuums
Roll brush on the shark navigator lift awat
While checking out your brush roll you might as well take a look at your vacuums belt. Your belt should be replaced about every three months. After regular usage, the belt will stretch out, lessening the tension on the brush roller. Lesser tension diminishes the brush roller's turn rate and speed. If the belt feels loose then it certainly is effecting your vacuums suction as well as your brush roll not moving at all.
http://www.thinkcrucial.com/search?type=product&q=shark
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Ava B.
Sep 24, 2016 | Shark Vacuum. Navigator Lift-Away Bagless...
Why does the brush roller work for a second, then stop?
could be a loose belt or brushroll endcaps need to be cleaned
after you check this if it still cuts out its the electronic board
sorry not repairable
here is the belt if you need it Vacuum Belts Shark Navigator vacuums Lift Away Motorized Floor Brush NV350...
Dec 31, 2015 | Shark Vacuums
Brush roller won.t turn. It turns for a sec. then shuts off. I have cleaned all clogs. This is a shark navigator. Can I remove bottom of vac to access the roller? The manual doesn,t mention this as a...
There are a number of reasons why your brush roller has stopped moving. General maintenance of your vacuum is crucial and will help it work at peak performance.
First things first let's focus on the brush roller. Unplug the vacuum and turn it on its side. Look for any noticeable clumps of debris or hair strands that may be caught in the brush roller. Remove these obstructions, probably best to do so with a scissor if it's hair or long pieces of carpet fibers. After removing the debris try manually rotating the brush roller to uncover other hidden clogs. Another thing to take note of is the condition of the bristles on the roll itself. Are they lose or worn down? These are signs that your brush roller is in need of replacing.
While checking out your brush roll you might as well take a look at your vacuum's belt. Your belt should be replaced about every three months. After regular usage, the belt will stretch out, lessening the tension on the brush roller. Lesser tension diminishes the brush roller's turn rate and speed. If the belt feels loose then it certainly is affecting your vacuums suction as well as your brush roll not moving at all.
https://www.thinkcrucial.com/collections/vendors?q=Shark
Ava B.
Apr 06, 2011 | Euro-Pro NV22 Shark Navigator Bagless...
Euro-Pro NV22 Shark Navigator Bagless Upright Vacuum Logo
859 people viewed this question
Top Euro-Pro Vacuums Experts
 Tony C
Tony C
Level 1 Expert
Dennis Key
Dennis Key
Are you an Euro-Pro Vacuum Expert? Answer questions, earn points and help others
