Dvd drive not detect in IDE secondary
I've change of my laptop dvd drive, Its working well but disabled in IDE secondary so i'm unable to Boot from cd, I've done many settings in REGEDIT but after restart laptop all previous settings are back,please help if I insert old drive IDE secondary is detect cd drive model as enabled
old cd drive is..sosc-2483k
new dvd drive is. HL-DT-ST-DVD RAM GSA-T40L
    Guru:
  • 163 Answers
Go to the BIOS settings and in the main menu and set the first boot device as cd rom. Then reboot ........
Posted on Apr 24, 2010
Secondary ide won't detect HDDFoxconn 915 P7AC
Try putting both secondary channel Hard drive jumpers to cable select to see if that doesn't cure it
Feb 20, 2014 | Computers & Internet
Unable to boot internal devices? bug?
Did you go into the bios settings and check the status of the hard drive? it would seem that is where the problem lies.
Jul 06, 2012 | ASUS Computers & Internet
My Gigabyte GA-945GZM-S2 motherboard is not detecting any CD/DVDROM attached to the ide port. it is also not detecting the rom in bios. cable and rom ate both working fine there have been tested on other...
IF THERE IS ANOTHER IDE PORT FOR A SECONDARY DRIVE i WOULD TRY TO SWITCH OVER TO IT . IF NOT THE MOBO MAY HAVE A PROBLEM WITH THE IDE PORT. VEIRFIED THAT THE DRIVES ARE CORRECT AND TRY TO CHANGE THE BOOT ORDER IN BIOS .
May 15, 2010 | Gigabyte GA-945GZM-S2 Motherboard
Primary IDE port does not work on intel d865GVHZ motherboard
we are repiar the mother board and 100% warrnty contect for more detetil : www.compudesk.in E-mail: support@compudesk.in
Oct 12, 2009 | Intel D865GVHZ Motherboard
I m unable to open my laptop some kind of
Are you trying literally to open up your Laptop with a screw driver or something... or are you trying to install XP on a Vista pre-installed laptop... Here's the solution...
Go to the BIOS setup [press F8 on startup], & change the disk controller setting from AHCI to IDE. might worth the try. Some Laptops don't have option of SCSI or IDE. But there are SATA Enable/Disable option. Try disabling SATA. Make sure you have all the necessary drivers for your laptop before installing windows...
Let me know if this doesn't solve the problem...
Aug 09, 2009 | Computers & Internet
Hp nx9110 laptop
There are several ways you can check if you have a working hard drive in your laptop.
1. Get into the BIOS configuration of your laptop, you may be able to see your laptop's configuration, and maybe even see your hard disk. This means your computer has been configured to work with the hard disk, but does not mean the hard disk is OK
2. If your laptop has a floppy disk attached then you can use a boot floppy disk and boot up in DOS. Then you can then run FDISK and then display the hard disk. If FDISK does not detect a hard disk the it is most likely dead.
3. If you can get access to a USB hard drive adapter cable or an IDE adapter cable that you can connect to a working computer's secondary IDE controller. THEN
Remove your laptop drive and connect and connect it to the USB adaptor or an IDE cable, (make sure you connect the drive correctly to the connector) then connect it to a working computer.
If you use an USB adapter, when you connect it to a working compute with XP or Vista operating system, and if the hard drive is OK then you will see the contents of the laptop hard drive.
If you connect the IDE cable to the secondary contriller and then boot up the working computer with XP or Vista operating system, if the laptop drive is OK you should see the contents of the laptop hard drive.
If you don't see the hard drive, then most likelt it is dead.
Jul 27, 2008 | HP Compaq Business NX9110 Notebook
Sony VAIO laptop; DVD-R not reading disks
Check the status of the device in Device Manager to make sure that the device driver is working correctly. (If you need help doing that please ask.)
If no joy then:
Change the transfer mode for your CD drive in IDE Channel Properties loadTOCNode(2, 'resolution'); loadTOCNode(2, 'resolution'); 1. Click Start, right-click My Computer, and then click Manage. 2. Under Computer Management (Local), click Device Manager. 3. On the right side, expand IDE ATA/ATAPI controllers. 4. Right-click the channel where your CD drive is connected, and then click Properties. Typically, this channel is Secondary IDE Channel. 5. On the Advanced Settings tab, in the Transfer Mode box for the device that represents your CD drive, click PIO Only. Typically, this device is Device 0. Then, click OK. If the issue is not resolved after you change the transfer mode for the secondary IDE channel device 0, your CD drive may not be located there. Use the same procedure to change the transfer mode back to DMA if available. Then, repeat these steps to change the transfer mode for IDE devices in the following order until the issue is resolved: • Primary IDE channel, device 1 • Secondary IDE channel, device 1Note Primary IDE channel, device 0 is connected to your boot disk. This is the hard disk that typically contains your operating system.
Jul 05, 2008 | Computers & Internet
Hard Disk and Booting issue
go into your BIOS and on the bottom of your screen there should be a (last good config) of (fail-safe config) value for one or=f the F1 to F12 buttons. also. are you running a 4gb hdd??? or is that a typo? anyhow, XP REQUIRES 2GB at all times free if your hdd is running at less that that (cause its full) your boot up could be messed around. finally make sure that the little plug on your hdd is across the Master or cable select pins not the slave as this can cause probs too. good luck.
Sep 22, 2007 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
755A
You didn?t give a whole lot of information to go on but if the problem is just slow drive detection you can speed things along by deactivating the IDE drive slots that are unused. For example if you have one hard drive on IDE channel 0 and a CD device channel 1 disable the secondary spots on each channel, it will make the drive detection faster. If that doesn?t help give us some more specifics about your current configuration and we can pickup from there.
Mar 06, 2007 | EliteGroup 755-A (ECS 755-A) Motherboard
Computers & Internet Logo
122 people viewed this question
David Payne
David Payne
