Just began working with an EX2220X Monitor. Picturew is GREAT, but email arrives too small...HOW CAN I MAKE IT LARGER? I'm using a 15'' MacPro. What's a HAS stand? Whats better about it and where can I get one? The printed info is useless as is the ''manual'' CD...where do I go on-line to get it explained? THANKS! Carl Fisherman cdfisherman@mac.com 201-337-9053
You can set the default font and size in the browser preferences... the system wide default sizes don't seem to work, windows or pc... but does depend on the email client you are using
Posted on Jul 05, 2010
Lexus rx 330 air conditioning
possible freezing up of either condenser or evap coil have freon level checked as well a expansion valve replaced
Jul 10, 2012 | Air Conditioning and Heat for Lexus RX 330
How do you use external monitor facility? Aged friend has Versa m370 and needs larger screen due to poor eyesight.
does your friend laptop supports dual monitor if does you need another monitor a larger one so that your friend wont have a problem with his poor eyesight. But if it doesn't support dual or multiple monitors do the same buy a new monitor a larger one.
Jul 01, 2011 | Computers & Internet
My Canon 10D will not Power On. Do I need the original battery ? Currently I have A battery from my Canon 30D in the 10D.
According to Canon, the battery should work in either camera. Does the battery work in the other camera but not in the 10D?
Oct 01, 2010 | Canon EOS-10D Digital Camera
I m having acer ac515 15" crt monitor. its CRT is got damaged. i want to know which crt will be applicable for that becoz the existing mounted CRT is not visible ( which specification it is having is not...
Any crt monitor will work with your computer.
I suggest you get a LCD monitor instead and a larger screen than 15".
LCD screen take up less desk space and are lighter and more energy efficient.
May 22, 2010 | Acer AM 501 15 in.CRT Conventional Monitor
Should I turn off my monitor over night?
If you turn off your computer then you should turn off the monitor too to save energy.
You can also leave it on standby which uses less energy but we want to save the planet :)
Sep 25, 2009 | Dell E152FP 15" Flat Panel LCD Monitor
Cannot set up the arrival alarm to a point
If you set your arrival alarm to .001 you are trying to hit a very small circle, only 6' in diameter and the odds of actually reaching that point are incredibly low so it's not likely the alarm will go off. Try setting your arrival alarm to .100 just to see if the arrival alarm works better.
When you set alarm to 15 second arrival you should see and hear an alarm, however, the slower you are going, the smaller the arrival circle gets, which means its gets harder to hit the area that triggers the alarm. 15 seconds is the default setting and I have found that it works fine at normal cruising speeds. If you are traveling very slowly, try bumping the arrival time up in 30 second increments to see if you can get an alarm.
When the alarm does go off, it is a very faint double beep which is hard to hear over the sound of wind and engines. I don't remember exactly how the visual arrival message appears but it is also very subtle. It appears either as a change to the menu bar at the bottom of the screen, or as a message box on the screen that dissappears very quickly. When I use that model I frequently miss the arrival alerts.
Jan 08, 2009 | Garmin GPSMAP 3210 GPS Receiver
Heavy vibration and noise
YOU MAY HAVE CUT THE COVER CHUTE
INCREASING THE GAP BETWEEN THE
BLADE AND CHUTE BOTTOM ALLOWING
LARGER CHUNKS TO PASS THRU. INSPECT
AND IF NEEDED ORDER NEW ONE FROM
OMEGA AT 717 561 1105. ABOUT $15.
Dec 28, 2008 | Omega 1000 Juice Extractor
Email not arriving
Verify with your ISP if they have  a Spam Trap, and how you can "whitelist" addresses.  If they have a spam trap,  you might NEVER never see the emails it catches.   You could ask them to turn it off and see how much more email traffic  you get.
Nov 04, 2008 | Microsoft Windows XP Professional
Regarding L1515S 15" LCD Monitor Resolution
Hello mallik, The LCD monitor is actually a active matrix of small transistors (3 for each pixel). They have one native resolution, a FIXED one for example you monitor has 1024 x 768 pixels. This results in 786432 pixels displayed on the screen. Because each pixel is controlled by 3 transistors there will be 2359296 transistors controlling your entire screen. This is a fix number. You can't raise the resolution to 1280 x 1024 because this will require as you can see now... a lot more transistors on the same surface. All you can do is to lower the resolution, in this case 4 pixels (12 transistors) form a larger pixel acording to that lower resolution. The image can look blurry in these situations. THe bottom ideea is that a LCD pannel (more corectly said, TFT (thin transistor film) pannel, has one optimum resolution, it's native one. The higher the better, when choosing one to buy, but you can't raise the resolution over that. You can just lower it. It works different then the normal conventional CRT monitors. Sorry for my bad english as I live in a non english-speaking country. Also if you have anymore questions please post a comment.
Mar 25, 2007 | LG Flatron L1515S 15" LCD Monitor
Computers & Internet Logo
200 people viewed this question
David Payne
David Payne
