Question about GE Profile Spectra JGBP90 Gas Kitchen Range
GE XL 44 oven does not heat. Model # JGBS23WEA 1WW
Hi, I have a GE XL 44 oven, model # JGBS23WEA 1WW. The stove burners light, but the oven does not. I replaced the oven igniter, but it still does not ignite the oven flame tube and there is no gas smell when I turn the oven control on. The old igniter was cracked. Any suggestions?
Thanks, Mitch
catriver
  • 878 Answers
SOURCE: GE Spectra XL 44 Self Cleaning
Ray, sometimes the burners get gunked up. Remove the cap and burner and see if the small orifice that is located by the spark electrode is clogged. Clean it out with a paper clip. Make sure the burner cap has good contact with the burner. Catriver..post back.
Posted on Dec 08, 2006
rickzilla
  • 706 Answers
SOURCE: GE XL 44
If your top burners are not lighting or will not work, it is possible that the burners have become dirty or wet. Please follow the troubleshooting directions below before calling service:
  1. Turn you burner to the Lite position:
    If you hear clicking or sparking, go to Step 2.
    If you do not, check your circuit breakers. If the circuit breaker is ok, we recommend that you schedule service by calling 1-800-432-2737 or schedule service online.
  2. Clean the burner and electrode:
    First remove the burner grate, cap, and head. Use a needle or paper clip to poke through the holes on the burner head. Re-assemble and try the burner.
    Remove the burner grate, cap, and head. Even if it looks clean, wipe the tip of the electrode with a clean, dry paper towel and PRESS IT DOWN. Re-assemble and try the burner, again.
    Check to see if the burner works, If not, then go to Step 3.
  3. Re-assemble - Make sure that each burner top matches its burner bottom. The burner top will lay flat if put on correctly.
    Check to see if the burner works, If not, then go to Step 4.
  4. The spark igniter is operating properly, but the burner is still not lighting. At this point, we would recommend that you schedule service by calling 1-800-432-2737 or schedule service online.
Posted on Sep 01, 2008
docjohn174
  • 943 Answers
SOURCE: GX XL 44 Gas Stove Oven won't Work
HI. thanks for your question. the problem you are having is with the bare igniter, located in the oven on the gas burner. replace the igniter. thanks the appliance doc.
Posted on Oct 12, 2008
  • 56 Answers
SOURCE: lower oven burner has a yellow flame,broiler flame
Just Live With It
Posted on Aug 07, 2009
MNfisherman
  • 11896 Answers
SOURCE: Flame on my Whirlpool gas stove burners are too high on low
either turn down the gas knob or turn knobs to lowest setting without going out. That is about your only options
Posted on Aug 25, 2009
I have a GE Profile XL 44 gas range, Model #JGBP79BEA2BB, Serial #RV224810P. The Broiler works, the oven does not. I am fairly certain the problem is the round style oven Igniter. I am trying to verif
What have you got to lose , 25.00-65.00 I would see if the ignitor works . Have someone else turn it on while you watch underneath if it sparks the try to get it closer to burner .
Jan 20, 2015 | GE Kitchen Ranges
My stove is a GE and everything works but the burners and oven.
check your breakers everything you said means not enough voltage
Apr 05, 2014 | GE Stove/Oven/RanSurface Burner Knob -...
GE GAS STOVE XL-44 [?17B034] Oven broiler works; however, lower oven ignites and burner comes on but flame is low and DOES NOT HEAT to selected temperature; e.g. 350 degrees.
The problem is usually the igniter not reaching the correct amp draw .When the igniter does not reach the correct amp draw it may allow the gas valve to partially open or not open at all. The igniters are inexpensive and easy to replace. This video will walk you thru the correct procedure for testing an oven igniter. It may be a different model but the testing will be the same.You can also enter your model # for diagrams and illustrations of your specific model. Not all models are available. All parts come with installation instructions.
Dec 10, 2010 | GE Kitchen Ranges
Broiler works but oven does not ge xl 44 model JJBP24BEA2WH serial LV201917P Is this worth fixing?
Hello-  Yes if it's the igniter for the oven burner. The lower burner may light, but if igniter is bad, gas flow will not increase, causing under-temp condition. The part is available for 40-75$, and is fairly easy to install. Part is accessed by removing drip pan at bottom of oven. Gas ranges last longer than electric if the self-clean 'function' is avoided. Go ahead and fix it!  Let me know if this info helps-- have more if needed.   Thanks-  Ed
Mar 17, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
Stove burners will not light
I went directly to GE's website and found the diagrams for my stove with the parts listed. Thats what I needed !
Thank you,
Penny
Jun 29, 2009 | GE Kitchen Ranges
Getting to the Pilot
Your model JGBP28DED2WH uses spark ignition on the stove top burners, and a glow bar ignitor, part number WB2X9154 for the oven and broiler. To get to the bake ignitor if oven will not light: Take the racks out of the oven. Remove oven floor by removing two screws at back of oven floor and lifting floor. Remove the square metal flame spreader to get to the burner / ignitor assembly. (note: The ignitor may still glow when you try it, but usually is still the problem)
Feb 22, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Oct 08, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
GE XL 44 Kitchen Range
replace the ignighter bar in the lower oven pull the racks out remove the two screws in the oven bottom pemove the panel under that remove the metel flame spredder the ignighter is at the back of the burner bar get your model number and go to appliance parts store for a new one and follow inst even if it glowes doesnt mean its good it should light the oven whithen 30 seconds
May 24, 2008 | GE JGBC20 Gas Kitchen Range
GE Profile Spectra JGBP90 Gas Kitchen Range Logo
122 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
