Question about Adcom GFA-5802 2-Channel Amplifier
Adcom GFA 5500 'mechanical' hum from amplifier
Adcom GFA 5500 'mechanical' hum from amp. Comes and goes. 60Hz, does not affect sound from speakers. Thought it might be the transformer but toroids have nothing to rattle. Capacitors?
    Problem Solver:
  • 12 Answers
When power transformer is stres it gave that hum . check if you have some big power consume even with no loud. if yes might be capacitor. but my opinion that is not the transformer is the problem it need a bath with enamel
Posted on Jun 25, 2015
    Problem Solver:
  • 12 Answers
Possibly. Most amps filter out line hum via low-pass filters. If you can locate a schematic, those would be the caps to check.
Posted on May 11, 2010
Adcom gfa 7000 amp makes a cyclic humming noise in unit not in speaker
Are your grounds to BARE metal sounds like a ground loop issue.
Feb 25, 2013 | Adcom GFA-7500 5-Channel Amplifier
Bridge adcom gfa-5500
not unless it has a Bridge switch OR you design an inverter circuit for one of the inputs. If it has XLR inputs you can try to invert pins 2 & 3 on one of them, that might work...
Aug 12, 2012 | Adcom GFA-5500 2-Channel Amplifier
Adcom gfa-5500 sounds like **** when turned up loud,whats the issue? distortion lights dont come on.
Your Speakers Can Only Handle So Many Amps Sent From Your Amplifier Adjust Your Amp To Pair With Your Stereo
Mar 17, 2012 | Audio Players & Recorders
Is a Adcom GFA-7500 5 channel power amplifier bridgable?
no this AMP is not bridgable to get more power out of this amp you need 4 ohm speakers.
Power rating
1 - 150 watts into 8 ohm speakers
1 - 225 watts into 4 ohm speakers
Feb 23, 2011 | Adcom GFA-7500 5-Channel Amplifier
When turning on you hear thumping sound from speakers turning off aswell i am using very efficient speakers
This sounds like an electrolytic capacitor that's discharging. Follow the wires from the speaker terminals in the amp to the PC board. This should lead you to the main amp board. If you look around it you might see what is called speaker coupling capacitors. I reckon they could be a bit larger than others and be around 220 to 470UF or perhaps higher. These capacitors will be the last thing the signal goes through before the output goes to the speakers. They can cause that. Otherwise it could be a capacitor in the power supply section.
Aug 24, 2010 | Adcom GFA-5500 2-Channel Amplifier
Adcom gfa 555 blows the 10 amp fuse and the 6 amp fuse on the far right
Any fuse blowing is caused by a shorted component in either the power supply section or main audio amp part. Follow the fuse circuit and see where it leads you. Look around for burnt of damaged parts. Suspect anything sitting on a heat sink. The most common culprit is the audio amp main transistors, especially if someone shorted the speaker leads together. In the power part it could be the transformer, the large Electrolytic capacitors, rectifier, or voltage regulator. Some amps use an IC for amplification and this can blow the fuse.
Oct 19, 2009 | Adcom GFA-5500 2-Channel Amplifier
Adcom GFA 5500 right channel emits horrible sound. Broken highs and no bass. Is is repairable by a semi amatuer?
Adcom makes a great amplifer! Usually broken highs and no bass means blown speaker. Try hooking it up to a completely different input source. Try different speakers also. If problem persists, check the fuse. Most will have a fuse on the back you can screw out. Some have two fuses (one for each channel) If this doesn't fix the problem it could be expensive to fix. Also, does this model ave the thermal protection light and if so, does it come on at all?
Jun 22, 2009 | Adcom GFA-5500 2-Channel Amplifier
Adcom 7500, Adcom 5400(bi-amp), Marantz AV-9000, Dakiom HA103
Try just the power amp on ..nothing connected
no Dakiom thingy either. It's a matter of elimination. Start at the output device and work back. Keep the Dakiom out of the loop.
If there's hum with just the Adcom..then it's the ADCOM
Mar 25, 2009 | Adcom GFA-7500 5-Channel Amplifier
Adcom GFA-5802 2-Channel Amplifier Logo
707 people viewed this question
Top Adcom Audio Players & Recorders Experts
 Grubhead
Grubhead
Computer Links
Greg Cann
Greg Cann
Are you an Adcom Audio Player and Recorder Expert? Answer questions, earn points and help others
