Question about Intel Computers & Internet
How to configure enrtr-514 broadband router - Intel Computers & Internet
SOURCE: Configuring Belkin Wireless Router
You choose a wireless router so you need to install in some freequency. You can choose the freequency by the list like 2.4 G.Hz ect. then just select the link & fix threre working ares / type. Avoid the command prompt. use bessic settings your user manuel help you further.
Posted on Feb 13, 2008
2Gigs
  • 141 Answers
SOURCE: Linksys wireless-G router configuration on PPPoE internet connection
Connect modem to the internet port of the wrt54g
Connect pc to port 2 of the wrt54g
Reset the wrt54g, push reset button for 30seconds with the power on, uplug the power for 10 seconds
Open internet explorer, type 192.168.1.1, you will be asked to login, no username, password is admin. This will take you to the router page. On the page you will se AUTOMATIC CONFIGURATION DHCP, change that to PPPOe, enter your broadband username and password. Click save settings at the buttom of the page. YOU WILL ONLY GET CONNECTION IF YOUR USERNAME AND PASSWORD IS CORRECT.
GOOD LUCK
Posted on Mar 15, 2008
SOURCE: Configuring DLink Wifi router for Reliance broadband
Reliance Wimax will be Dynamic (DHCP)
Step 1 :
Connect the Wimax wire from the wall outlet (power adapter provided by Reliance) to the computer directly. The computer must be in DHCP mode.
Check the IP Address of the Computer. It should be a public IP Address.
Step 2 :
Open a web browser. If you try to open any page, it will take you directly to the Reliance Broadnet Login page. Login with your Reliance User ID and Password. Then Log out.
Close the web browser.
Step 3 :
Now, connect the wimax wire to the WAN Port on the Router and the computer to any LAN port. You can open the Router Setup Page. Do MAC Cloning. Then, save changes. Run DHCP on the Router.
Also you can configure wireless network, by changing the SSID and security.
Step 4 :
On the wired computer, open web browser, go to Reliance Broadnet login page and login and start enjoying the service.
One problem, you might face is when the Router is turned off in between. You may have to repeat the Steps 1,2 & 3 to get the connection back.
Posted on Oct 20, 2008
airoff
  • 160 Answers
SOURCE: Using a Dlink DI-514 as a simple hub
Any router can be used as a hub by not using the WAN port. The cable which connects to the rest of your network goes into one of the 4 LAN ports, leaving you 3 wired open ports to connect additional devices. The wireless part will continue to function nomally.
You'll want to disable the DHCP router function in this router. Do this before setting it up as the hub. Connect to it with a cable from a desktop machine into the router - no other network connections at the same time.
Either use the setup CD for the router, or browse to the router address (192.168.x.x) depending on if you're using the default address, or it's been reconfigured.
Then turn the DHCP server function off.
Connect it to the rest of the network, and you're good to go.
Posted on Nov 14, 2008
dante777
  • 623 Answers
SOURCE: how to configure dmz on linksys wireless n router?
  1. Log into your router. (If you need help how to do it let me know!)
  2. Go to th "Application & Gaming" tab.
  3. click on "DMZ"
  4. choose "Enable"
  5. Enter the IP address of the computer you want to put in the DMZ.
  6. Click "Save Settings"
Some notes:
  • Putting a computer in a DMZ is pretty risky, because all ports to this computer are opened. Make sure that all recent patches are applied and your virus software is up to date! A more secure solution is to use portforwarding. (See this site how to do that for a specific software for your router.)
  • Your computer should be set to a static IP. For two reasons:
  • A) DMZ will not work if your DHCP server (your router) assigns at one point a different IP address to your computer,
  • B) If a different computer gets the Ip address assigned that you specified in your DMZ settings, then that machine is exposed.
If you don't know how to assign a static IP address, let me know and I walk you through the steps.
If you have any more questions, just come back here and leave a comment - I'm happy to help.
Posted on Aug 08, 2009
How can i reset Encore enRTR-104 router to default factory settings? When i push the reset button after few seconds begin the light nr. 4 faster to blink. When i release the button - the reset is done in...
I found these instructions for resetting the router to the defualt settings:
Use the "Backup Settings" tool to save the Broadband Router's current configuration to a file named "config.bin" on your PC. You can then use the "Restore Settings" tool to restore the saved configuration of the Broadband Router that you set before. Alternately, you can use the "Restore to Factory Defaults" tool to force the Broadband Router to perform reset and restore the original factory settings.
􀁺 Restore Factory Default
To restore the factory default settings of the Broadband Router, click on the "Restore" button.
􀁺 Backup Settings
Press the "Backup Settings" button to save the current setting in a filed "config.bin" or given filename.
􀁺 Restore Settings
To restore the backup file to the Broadband Router, enter the path and filename on the restore settings.
You can find the manual here:
http://www.encore-usa.com/us/support/ENRTR-104
May 05, 2011 | Encore ENRTR-104 Router
How to configure
To secure your wireless network from unauthorized access, please click on this link and follow my instructions to configure your wireless router and the wireless card in your laptop/computer :-
http://www.fixya.com/support/r3559128-wireless_router_security
Jun 25, 2010 | D-Link DI 514 Wireless Router (DI-514)
Can't get internet connection
Plug your broadband connection to router'e broadband port and check your router's are getting automatic IP address or not, if not then need to feed manual IP address in your router which one provided by your ISP.
Mar 31, 2010 | D-Link DI 514 Wireless Router (DI-514)
Want to use Dlink DI-514 with Qwest modem to hardwire 2 computers
Believe it or not, Actiontec modems from Qwest are setup as a router already (even though ports are missing from it). You should use a switch instead of another router. Otherwise you will have to configure the DI-514 to act as a switch rather than a router. This is done by assigning a new starting IP address into your DI-514. By default both routers use 192.168.0.1 as the default. You will have to plug the DI-514 seperately into a computer (to take it off the network) and assign a new starting IP address for the DI-514 such as 10.150.1.1 for example. Then you will be able to get it work. I would strongly recommend using a switch instead and turn the wireless on the modem itself (this is why the modem is the router). It will save you some headaches if the power goes out.
Feb 04, 2009 | D-Link Dlink DI-514 Air Wireless 2.4 GHz...
Linksys Wireless G Router Set up
I ended up loading the router setup cd onto another laptop, and it worked fine. I still don't know why the first laptop had the error code, but they now both, work perfectly fine. Thanks, anyway.
Sep 06, 2008 | D-Link DI 514 Wireless Router (DI-514)
Please help
hello!
are you trying to access the router setup?
are you trying to configure the router?
i have read the same problem on the supportrix forum and you may try this simple steps and see if this help solve your problem. make sure your computer is directly connected to the router
Step 1: Shutdown the computer.
Step 2: reset the router while power on then Unplug the router’s power cable.
Step 3: Unplug the Broadband modem’s power cable and wait for 30 seconds.
Step 4: Plug in the Broadband modem’s power cable and wait for its lights to appear stable.
Step 5: Plug in the router's power cable once the modem’s lights appear stable.
Step 6: Power on the computer on and configure the router settings
Step 7: test the Internet connection.
if this still didnot work, upgrade the firmware of your router and repeat the same steps.
note:
configuring the router settings will depends who is your provider. if your isp is dsl you need to configure your ISP username (email address format) and password on the router. if your router is a cable no need to change any settings on the router. it should automatically work
Aug 14, 2008 | D-Link DI 514 Wireless Router (DI-514)
Will it work
hello!
yes, the router will work with your pc and xbox 360.
You have to set the internet connection first between you modem, router and pc before you configure the xbox 360. try this and see if it will work with your network
you may try this and see if this help solve your problem
to set up your modem and router:
Step 2: Unplug the router’s power cable.
Step 6: Power on the computer on and test the Internet connection.
to set up your xbox 360:
Step 1: Power down the Xbox and connect a regular straight thru Ethernet cable from one of the numbered ports on the router and plug the other end of the cable into the Xbox™’s Ethernet port.
Step 2: Power on the Xbox without a CD in the tray and the Xbox Dashboard should appear.
Step 3: Select Settings and press A on the controller.
Step 4: When the Xbox screen appears, select Network Settings and press A on the controller.
Step 5: When the Network Settings screen appears, select IP Addresses and press A.
Step 6: Under Configuration, select Automatic and press A on the controller. Take note that the IP Address being shown will be the Xbox’s IP Address. Press B to return to the previous screen.
Step 7: When the Network Settings screen appears, select DNS Servers and press A.
Step 8: Under Configuration, select Automatic and press A on the controller to save the changes. Press B to return to the previous screen.
Step 9: When the Network Settings screen appears, select PPPoE Settings and press A.
Step 10: Under Configuration, select Off and press A on the controller to save the changes. Press B to return to the previous screen.
Step 11: Once the Network Settings appears, select Connect and press A to test the connection.
Apr 26, 2008 | D-Link DI 514 Wireless Router (DI-514)
Computers & Internet Logo
163 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
