Question about Ovens
I have a Gaffers and Sattler stacked double oven that I would like to have a manual for. I also want to remmove the doors for better cleaning. I am unable to find any modle number on the unit.
5 Suggested Answers
reg501
  • 413 Answers
SOURCE: cant unlock self clean oven door
Door lock motor has probably failed.....Self clean on many ovens can be a self destruct mode. Door latch motors, sensor probes and even the electronic controls can be destroyed by this operation. Suggest oven cleaner method.
Posted on May 29, 2008
  • 17 Answers
SOURCE: cleaning between double glass oven door
Without disassembling the door, you can't. the glass is sandwiched between two rather rugged metalized gaskets to create an air pocket (or vent space) to keep the outside glass cooler than the inside.
Posted on Feb 04, 2009
SOURCE: HEATING ELEMENT GAFFERS & SATTLER BUILT-IN
our 1985 gaffers and sattlers oven would not turn off tonight. Any idea? Its Propane oven
Posted on Nov 22, 2010
SOURCE: I have a 1965 gaffers
My Mom has a 1965 Gaffler & Stattler Mark 21 wall mount oven, it had the "Same Problem", People may tell you that the flame switch is no longer avalible but I found a universal fit flame switch at Applance Parts Center, I took the old part in and had it matched up, with a minor modification to the thermal sensor mounting bracket, "drilling a larger hole and lightly crimping it", it's a perfect fit, "problem solved". You may want to try cleaning the pilot light area with a small wire brush first, if that dosn't work try a jumper wire on the two terminals of the flame switch, if that works then replace the flame switch.
This operation can be done without removing the oven from the wall mount, just remove the two screws from the panel at the inside rear of the broiler, you will find the flame switch behind the panel it has two screws two wires a thermo leed and a sensor tip that goes up to the thermo sensor mounting bracket above the pilot light, the thermo sensor mounting bracket has one screw and a nut behind it, you will also need to remove one end of the 1/4" pilot gas pipe in order to remove the thermo sensor mounting bracket, When your done puting it back togather, check for gas leaks using soapy water in a spray bottle, a dish soap solution works great, also check your vent pipe connections.
After I cleaned the dust and grease out of this old thing, the 45 year old clock and timer started working again.
My Mom is very happy, try and find new oven to fit the cutout and vent, we saved a lot of $$$,
"Good Luck".
Posted on Jan 06, 2011
How do I turn off the timer on my gaffers & sattler wall oven?
Try rebooting the oven; unplug it for 90 seconds, or flip the circuit breaker off for 90 seconds, then back on.
Apr 17, 2016 | Ovens
Need to reattach the oven door
most doors lift off. there should be some stops on the hinge .set them before remmoving door . but you have already got the door off so you will have to reset the hinge lever till the stop will hold then insert the hinge into slot and fold the door down . release the stops and door work work properly . mm .
Jul 16, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
HEATING ELEMENT GAFFERS & SATTLER BUILT-IN OVEN
Dec 22, 2009 | Ovens
Dacor CPO230, can't get lock to engage for self cleaning. I follow step clean symbolcomes up door lock moves into locked position then beeping starts and the word door flashes and the lock opens up.
For some reason the oven thinks you have a door that is not shut all of the way. Check the locking slot to make sure that there are no obstructions. Make sure that you are only doing one oven at a time, and not trying to cook in the other. Make sure you have no racks in the oven. Try pushing lightly on the door when the lock engages. For some reason your lock isn't engaging fully and that's why door is flashing. Good Luck
Below is from the owners manual for your oven.
Oven does not self-clean Door not shut tight Check for obstructions. Close door tightly
Oven set for delay timed cleaning Oven will start to self-clean at preset time.
Press CANCEL/SECURE to return to
normal operation
Double ovens only: Other oven is on. Turn off other oven.
May 10, 2009 | Dacor ECD230 Epicure Electric Double Oven
Old Gaffers& Sattler oven won't heat up. I suspect timer setting?
The most common failure in any electric oven is the heating element.
Jun 20, 2017 | Ariston Technologies Ariston FO98P...
Selfcleaning Jenn-Air electric oven
How do I clean my jenn-air double oven when I lock oven door and turn oven to clean mode set time to start I don't get anything. Also when I lock the oven door the oven lock light does not come on.
Dec 05, 2007 | Jenn-Air JJW8230D Electric Double Oven
Ovens Logo
193 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
