Question about RTO Spur Sprocket For Stihl 017, 021 Chainsaws
What is the proper length of the start rope fro a Stihl 017?
4 Suggested Answers
  • 583 Answers
SOURCE: Stihl 017 that will not throddle up after getting warmed up.
Isuggest you clean the carburetta does not take much grit or dust to foul up the works
Posted on Sep 06, 2009
dontbother10
  • 2220 Answers
SOURCE: Hello, my stihl 017 chainsaw is over oiling the
No oiler adjustment. Sorry
http://www.stihlusa.com/stihl_ownersmanuals/017_018_Manual.pdf
Are you using bar oil or something lighter? Stop by your local Stihl dealer (leave your saw in the car), give him a latte, and chat. He might have an idea or 2. He will not be chatty on any weekend or if there is a perspective sale in the store, HTH
Lou
Posted on Jan 20, 2010
SOURCE: i am trying to install
Hi this is how I did my spring on the my stihl 017 this work for me.
rewind a un coiled pullstart spring
Good luck. Steve
http://www.youtube.com/watch?v=qTcL3_3leTk
Posted on Jan 11, 2013
The rope broke when I tried to start the chainsaw. How do I replace it?
Your rewind spring is now sprung. Remove recoil assy ( the part your rope slides into). Remove all old rope remnants and rewind the spring. Install new rope, tie it off and slowly release spring rewinding the rope.
Mar 14, 2014 | Stihl 017 018 Ms170 Ms180 Chainsaw Starter...
Stihl fs 86
I am a Stihl mechanic. We tell all our customers that the proper starting procedure for a Stihl is as follows. Turn on the switch. Set the choke lever to full choke. Prime the primer bulb three times(if it has one) and pull the pull rope NO MORE THAN THREE TIMES with the choke on. If the unit has not tried to start after the third pull, open the choke lever and pull till it starts. Sthil carburetors are notorious for flooding after pulling the rope more than three times on choke.
Thanks;
George
Oct 08, 2013 | Garden
Will a stihl chainsaw engine assembly from 017 fit in a ms180
those saws are part of the same family so there should be no problem putting the two together
Jan 10, 2013 | Stihl 017 Crankshaft Assembly W/ Piston...
Which is more reliable..a stihl 017 or a stihl 021 ? looking to bid both in good runnung shape...thanks
Hi, you cant go wrong their both stihls. The 021 is a more powerful saw and the 017 is lighter, so it all depends on your intended use. Regards Phil.
Jun 26, 2012 | Garden
I am trying to install spring for the pull rope on a 017 stihl chainsaw
If it is new this is much easier. The spring comes in a plastic keeper and only needs to be aligned and pressed into place.
If the spring is loose this is much easier as a dealer, with the correct tools. tighten the spring back into a col and set it in place.
Good luck
Joe
Mar 10, 2011 | RTO Spur Sprocket For Stihl 017, 021...
Sthil are a roal panin in the *** takes 50 time of pulling the rope to get it started
Read you manual. you will NEVER have to pull anything 50 times to start it... pull off your muffler (if you filled it with gas) and let it dry out.
READ YOUR MANUAL
Mar 09, 2010 | RTO Spur Sprocket For Stihl 017, 021...
I just replaced the recoil \\starter rope on my blower
Are you sure you have the right length rope??? If you are sure the rope length is correct you may have wound the recoil spring too tight causing it to run out of travel. You want the recoil spring just tight enough to pull the rope all the way in.
Wayne
Feb 26, 2010 | Oregon Scientific Complete Carburetor for...
The starter rope doesnt pull, and when the saw is
sounds abit like it ,but remove the spark plug and you should be able to rock the flywheel back and forth. sounds a bit like no oil in the gas or at least insuficient oil and may have grabbed, (i assume you have the chain and bar off the powerhead,if not then remove them ,and then try ) it could also be the centrifgal clutch jammed up.
Dec 29, 2009 | RTO Spur Sprocket For Stihl 017, 021...
Sep 06, 2009 | RTO Spur Sprocket For Stihl 017, 021...
RTO Spur Sprocket For Stihl 017, 021 Chainsaws Logo
48 people viewed this question
Top RTO Garden Experts
John Trevino
Joseph Mueller
Joseph Mueller
Andy
Are you a RTO Garden Expert? Answer questions, earn points and help others
