The drying cycle has finished, but I can't open the door.
  • Washing Mach... Master
  • 43,501 Answers
Check out this tip that I wrote, it will tell you how to get into the washer manually...
http://www.fixya.com/support/r3864434-washing_machine_door_jammed
heatman101
Posted on Apr 26, 2010
Why does dryer continue running after dry cycle finished?
I would say this is in the control board but not 100 percent on this. If you go to an appliance store, not a big box, they will probably help you diagnose and order the part for you if you want to do this on your own.
Feb 09, 2016 | Dryers
My wash/dry cycle has finished but I can't open the door. Is there a manual release please?
turn the dial and listen for a click to release the door. no their is no manual release
Jan 06, 2015 | Electrolux Washing Machines
Ld 14aw3
Most dishes in any dishwasher are still wet when cycle is finished. The heat built up in the dishes during the washing cycle is what causes the water to evaporate when the machine stops.
If you want to accelerate the evaporation, simply open the door very slightly so that as the hot air escapes it causes the dishes to dry quicker.
Aug 04, 2014 | LG Dishwashers
When I set it to normal wash it takes more than a hour to finish I also press all the other settings dry heat, sanatizer. dont know if I'm doing something wrong
Every setting extends the wash time. You only need sanatizer if your doing a lot of baby bottles. The normal cycle with the strong dishwasher detergent will kill all bacteria anyway. The dry heat extends the time even longer and uses more hydro. Just open the door when the cycle is finished and they will dry on there own.
I hope this is of some help.
Dec 31, 2009 | Frigidaire 24 in. FDB1050REC Stainless...
Dishwasher maytag 945 awq
Door gasket or sealOver time, door gaskets and seals harden and lose their ability to seal properly. You can't repair the seals. You need to replace them if they've begun to leak.
Nov 08, 2008 | Maytag MDBH945AWW / MDBH945AWQ /...
Bosch dishwasher not 'steaming' plates dry
first check to make sure you don't have a air dry option.then look at the thermostat then heater.
Oct 01, 2008 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Cabinet under the sink is very warm when the dishwasher is in drying cycle. Is this normal?
Dishwashers do have a heating element that heats up during the dry cycle. Warm next to the d/w is normal. There is usually a switch/cycle that you can use "no heat" drying... just open the door when it finishes rinsing... also saves energy.
MM85
Jul 21, 2008 | Dishwashers
Unit will not turn on at all. Power source definately works. Unsure if unit stopped during dry cycle or finished and never came back on, but clothes were dry, indicating it was finished with the wash...
To open the door. First kill the power supply. There is a vaccum switch as part of the door lock which has a small diameter pipe connecting from the lock to the a vaccum container mounted on or near the pump remove this pipe to allow air in to the switch. Whilst you are in the process clear the vaccum container, pump and all pipes leading to and from pump of debris (usually lime scale related). Then reconnect everything. Put a cup full of soda crystals in drum and wash on hottest temperature.
Apr 13, 2008 | Washing Machines
Won't turn back on and finish cycle
Press "end of cycle" for over 3 seconds, & wait for 2 minutes to open door. You can then re-start the wash. It is possible you cld hv damaged fhe door switch. For front loaders you do not open the door during a wash, never. Less problems.
Mar 30, 2008 | GE Energy Star WCVH6260F Front Load Washer
Sounds like the problem is with the control board.  There is an internal fuse in the board but it is not replaceable.  You will need a qualified LG technician to service this unit.
Nov 03, 2006 | LG WD-3245 Front Load Washer / Dryer
Washing Machines Logo
12 people viewed this question
Top Washing Machines Experts
