Question about Minolta EP1031/1031F CS/PRO Copier
Reset ep 1031 plis - Minolta EP1031/1031F CS/PRO Copier
  • Minolta Master
  • 6,161 Answers
Is the code c500? if so power off then on if returns means that the fuser the hot part is dead. have to replace the upper fuser roller and lamp. service technician required unless you bye the parts and replace with service manual.
Posted on Apr 25, 2010
My photocopying machine is sending me blank pages after photocopy
Minolta cspro ep 1031 My photocopying machine is sending me blank pages after photocopy
Jan 15, 2013 | Konica Minolta EP 2030 3000 Toner 2-410...
Minolta EP 1031 J2 code What causes this code
Check the paper cassette sensor actuator and the exit unit(fusing unit) paper exit sensor actuator.
Sep 07, 2012 | Minolta Office Equipment & Supplies
Konica minolta EP-1031 PC code and toner install
PC MEANS NO PAPER IN THE TRAY OR PAPER JAM IN MACHINE WHEN TURNED ON. WHEN OUT OF TONER RED LIGHT SHAPED LIKE A PYRAMID WILL COME ON
Apr 16, 2010 | Office Equipment & Supplies
Copier does not copy. Error message is
you have a paper jam somewhere inside the machine...
Dec 18, 2009 | Office Equipment & Supplies
I have a Minolta CS Pro EP 1031 Printer that makes streak marks
Drum cleaning blade has gone bad. Especially true if the streaks seem to get progressively worse as you run multiple copies. In other words run 10 copies. If the last one out is worse than the first one out it is the drum cleaning blade. Cheap part...around $25
Oct 12, 2009 | Minolta EP1031/1031F CS/PRO Copier
Minolta ep1031 with a C 50 error
http://files.mail.ru/E3J8UV
Read service documentation EP 1035/1031
error C50Warming-up Failure
Faulty Fix Unit reasons:
- no contact or faulty lamp of the heating
- no contact or faulty thermistor
- no contact or faulty Fuse
- no contact or faulty controller of the direct current
The Repair is not simple and is required experienced master of the service, change the adjustments, clear instruction of the regulation of the check. Recommend to apply to service Vinolta Good luck
Oct 09, 2009 | Minolta EP1031/1031F CS/PRO Copier
There are black spots and lines on my paper when I
Clean the optical section(mirrors,lens,glass).Remove tje IU unit,change the OPC drum cleaning blade and clean the drum,charge corona and transfer/separator corona,after perform F5.
Sep 25, 2009 | Minolta Office Equipment & Supplies
Timer is on then
check the 9volt regulator
Jan 28, 2009 | JVC AV-27530 27" TV
Copies print all black
Make 1 copy with the lid open & verify that the scan lamp is lighting & that the scanner moves. A blown lamp is the most common cause for all black copies.
Jun 11, 2007 | Gestetner 5499 Black and White Copier
216 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
CheckitRight
CheckitRight
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
