Question about Belkin N Wireless Modem-Router F5D8633au4A
Unable to get VPN working - have set up port 1723 TCP/UDP without success
    President:
  • 1,768 Answers
1. Check at this phone number for tech support.
+44 - 1933 35 20 00
2. make use port forwarding is configured properly for UDP/TCP
3. check the DMZ rules.
Posted on Apr 26, 2010
Wrt160n vpn error 800
Error 800: Unable to establish VPN connection
This issue may be caused by a router that has outdated firmware.
Make sure that port 1723 is opened on your router.
For VPN connection , you can try opening port 500, 443-447, 10000-20000 and important port 1723 on your router.
I will suggest you to upgrade firmware on your Linksys router.
After upgrading the firmware, reset the router to factory default and reconfigure it manually.
Open the ports mentioned above and see if that works.
See How to upgrade firmware on Linksys router.
See How to setup Linksys router
Mar 12, 2012 | Cisco Linksys E2000 Advanced WirelessN...
Client does all the handshacking with the router
forward these ports for your VPN client ip address on your router...
TCP&UDP 50
TCP&UDP 51
TCP&UDP 500
TCP&UDP 10000
TCP 1723
UDP 1701
also disable firewall...
Jul 25, 2010 | Linksys RVS4000 Router
I have Timewarner cable and can't set up a vpn so that a client can connect into my Lynksys vpn router. Is it possible that the firewall in the TW router is blocking a client or that maybe I need a static...
No you need not buy a static address... just forward these ports in linksys router...
50 both TCP and UDP 51 both TCP and UDP 500 both TCP and UDP 10000 both TCP and UDP 1723 both TCP and UDP 1701 both TCP and UDP
also disable firewall in linksys router....
May 10, 2010 | Linksys -Cisco Wireless-G VPN Broadband...
Trying to set up a vpn server on windows XP using
Did you already forward port 1723? I guess you have done that. To isolate it, try to bypass the router and setup or establish the VPN session there. If it doesn't work, maybe your ISP doesn't allow port 1723 or it's just the modem.
Oct 22, 2009 | Belkin F5D7230-4 Kit (F5D7230V4SNPDQ)
I have a netgear rangemax won824 v2 I can connect to it fine, but I cannot connect to a works server after vpn connection successful. can someone help
VPN Passthrough Configuration
1. Please assign an IP address to your computer using the IP Address Reservation.
a. Please open any web browser like Internet Explorer or Netscape Navigator.
b. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field and click Enter or Return key.
c. A window will prompt for a user name and password. The default username is "admin" and the default password is "password".
Note: If it does not take password as the password, you might have changed it when you have run the NETGEAR Setup CD so please try other passwords. If you cannot remember the password, you need to reset the router and run the Setup CD to reconfigure it.
d. On the setup page, please click LAN IP Setup under Advanced tab.
e. Click Add under Address Reservation then you will be brought up to a new window.
f. On the Address Reservation window, please select the radio button of the computer you wish to add.
g. If the computer you want is not on the list; click the Refresh button to update the table.
h. If the computer is still not on the Address Reservation Table; please enter the IP Address, MAC Address, and Device Name of the computer you wish to add.
i. Please click on the Add button when finished.
2. On the Set Up page of the router, select on Port Forwarding/Port Triggering under Advanced tab.
3. Click Add Custom Service and type VPN on the Service Name box.
4. Set the Service Type to TCP/UDP and input the VPN port numbers under the Start and End Port field.
5. Type in the last digit of the IP address of your computer. Then, click the Apply button.
Example: The IP address of the computer trying to establish the VPN connection is 192.168.1.2.
Service Name Start Port End Port Server IP address
VPN1 47 47 192.168.1.2
VPN2 50 51 192.168.1.2
VPN3 500 500 192.168.1.2
VPN4 1723 1723 192.168.1.2
Jun 07, 2009 | NetGear RangeMax WPN824 Router
I cannot access internet when connected to VPN.
Dec 01, 2008 | NetGear WGR614 Router
VPN
the following is from a nice guide i found on the net, see if it works for you: First thing to check is whether your router has any settings for PPTP or IPsec "pass through". These are commonly found in Linksys routers but you may have to hunt around for them on other makes. All you need to do is enable the setting for the VPN protocol that you're using, reboot your router and, if you're lucky, the VPN connection will come right up. Note: Not all routers have these enables and the lack of them doesn't necessarily mean that you can't get VPN working. Open up that Firewall Still no connection? The next step is to try opening some ports in your router's firewall to get your VPN connection made. In each case, you'll need to open the specific ports (and protocol) to the IP address of the computer that you're running the VPN client on. NOTE that port mappings work with only one computer at a time. If you have multiple VPN clients that you need to connect, your router will have to support the VPN protocol that you're using without requiring ports opened. If you're using Microsoft's PPTP protocol, TCP port 1723 is the port you'll need to forward to allow PPTP control traffic to pass. Figure 2 shows the Forwarding screen on a Linksys BEFSR41 set to forward this port to a client with IP address 192.168.5.100. PPTP also needs IP protocol 47 (Generic Routing Encapsulation) for the VPN data traffic itself, but note that this is a required protocol, not a port. The ability to handle this protocol must be built into the router's NAT "engine"?which is true of most present-generation routers. IPsec-based VPN's need UDP port 500 opened for ISAKMP key negotiations, IP protocol 51 for Authentication Header traffic (not always used), and IP protocol 50 for the "encapsulated data itself. Again, the only "forwardable" item here is UDP port 500, which is also shown programmed in Figure 2 to the same LAN client machine?protocols 50 and 51 must be built into your router. Tip: Not all routers are created equal! Some allow only one VPN tunnel to be opened and used by a single client. Others support multiple tunnels, but with one client per tunnel. Unfortunately, most vendors don't make the VPN pass through capabilities of their products clear in their documentation, nor do they have support staff properly trained to provide this information either. In most cases, your only option is to try a router in your specific application, and make sure you can return it and get your money back if you can't get it working. Still not Working? Getting many IPsec-based VPN setups working can be a black art due to the wide variation in techniques used by various vendors. Although IPsec products have become more uniform as the technology matures, your company may use older, more proprietary products that may not be configured with NAT in mind, or require additional ports to be opened in your firewall.
Feb 19, 2006 | Microsoft MN-700 Wireless Router
Belkin N Wireless Modem-Router F5D8633au4A Logo
140 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
