Question about Dryers
Due to a clogged vent pipe my dryer abruptly quit working, giving off a burnt smell. I have since gave the venting a good vacuuming. I checked the breaker and turned on the dryer with no results. Do you think it was the thermal fuse that has blown?
    President:
  • 2,468 Answers
Yes it sounds like the thermal fuse opened up in the dryer vent duct work due to the plugging of the vent and not being able to get rid of the excess heat
Posted on Apr 24, 2010
Testimonial: "I found the thermal fuse - removed it and had it tested. It was bad. I have ordered a new one on-line and will have my dryer working in a few days. "
    President:
  • 949 Answers
That is the most likely suspect. If you can get me the complete model number from inside the door area I can help you locate and check that component
Testimonial: "I did locate the thermal fuse and had it tested. It was bad. A new one is on the way. Thanks a lot."
Dryer smoking up house and threw exhaust vent smells like something burnt
Hello, Well the smell is most likely from lint that is trapped in the dryer burning. The first thing you need to do is check the lint screen just inside the door. Second is to take the vent tube off of the back of the dryer and check to see if it is plugged with lint inside of the dryer. Clean out any you can see, also if the tubing inside of the dryer is most likely plugged with lint and the heating element is catching the lint on fire. If let go without cleaning this will cause a fire! I work for an appliance repair company and have seen dryers catch fire due to them being clogged with lint, you have two options; first is to clean it yourself, second is to have an appliance repair technician come to your home and clean it. The second is easier and safer but the first is cheaper but very labor intensive. I hope that answered your question and helped. Good luck!
Dec 09, 2010 | Kenmore Elite HE4 Electric Dryer
The heat goes on temporarily and then shuts off
The most common problem is a clogged vent.
To do this, unplug your dryer and move the dryer out enough so you can get to the dryer duct easily. Most dryer ducting is flexible like a big slinky with a vinyl(older style no longer used) or metal type covering. There are some that are rigid as well.
Remove the duct from the dryer and where it attaches to the wall. Use a shop vac or house vac with attachments and insert through the wall and vacuum as much as you can. I use a shop vac since it has the blowing capability and I can check if air is coming out of the dryer vent located outside after I vacuumed it out. It is good to get confirmation that air is coming out of the vent. Check the dryer where the duct was attached and vacuum anything that is in there. Put everything back in reverse order and give it a whirl.
There are some homes,condos,and apts the have the hidden ducting go up the wall and through the roof. If this is the case, you will need to go on top of the roof and find the vent pipe. This pipe will have some sort of cap on it to let the hot air out but keep other elements out. Since you mentioned the heat goes on for a bit, have someone go on the roof (use caution) and have someone else turn on the dryer. The person on the roof can check the vent pipes with his hand for heat.
Nov 16, 2010 | Whirlpool Dryers
My dryer is heating up, but the lint is not coming out..taking hours to dry small lot of clothes
first check the outdoor vent, make sure there is no restriction of the damper blades, they should flip open when the dryer is running. remove all lint build up around the hinge pivot points. in a cold climate ,if this is you, the moisture and lint become hard and coagulate and turn stiff restricting the movement of the damper or blade. make sure that the pipe joints were not connected with screws or rivets and that the joints are going in the same direction as the air flow. all joints should be made with a good quality tape.
the next question is how long is the vent run? follow the manufacturers venting instructions. if not available, the International Residential Code says that you cannot vent a dryer longer than 25 ft.
next, unplug the dryer, pull it from the wall and remove the vent pipe connector. look inside of the vent pipe and inside the dryer vent outlet collar.use a vacuum to clean it out and reconnect. make sure there are no kinks or crushed areas on the pipe. I do recommend using only aluminum flexible or rigid pipe and not plastic or foil type flex pipe. these types restrict air flow, clog much easier and are a fire hazard.
check these things and let me know. we'll go from there.
Dec 26, 2009 | Kenmore 63942 Dryer
Whirlpool gas dryer LGR6636PWO heats for appro. 5 minutes & quits heating but still runs.
First check the exhaust vent and connecting vent material for a clog. If vent is OK,replace the gas valve coils.
Oct 04, 2009 | Whirlpool LGR6636 Gas Dryer
Need to run clothes thru twice to get them dry. model GGW9868KQO
the common reason for the problem you describe is a partially lint clogged vent tube. pull the machine out from the wall, unplug it and then disconnect the vent pipe. Remove all of the lint you can find inside of the machine and in the vent pipe. Then go out doors and check the spot where the dryer vents to outdoors. Remove any blockage you see there also. Get back if this doesnt fix your problem, but I am pretty sure it will.
Jun 05, 2009 | Dryers
I have an LG DLE2532W dryer and it takes hours to
the vent pipe is probably full of lint. pull the dryer away from the wall, disconnect the vent pipe and look inside the rear of the dryer and thru the vent pipe. remove any lint u find as it is a fire hazard.
Apr 21, 2009 | LG DLE2532W Electric Dryer
Dryer shutting off too early. Faint smell of something burning?
Check the vent for clogging condition that will turn off unit and cause it to overheat. If vent goes up to roof check up there also - that is where mine was clogged with a sort of paper mache clog!!!!!
Sep 02, 2017 | Whirlpool LER4634J Electric Dryer
My dryer gets really hot, but the clothes take a long time to dry and it is really humid inside the dryer. Also, there is a weird smell almost like a burning smell.
It sounds like the dryer isn't getting enough airflow, which might mean a clog.
Make sure you clean the lint filter every time. Also, make sure the vent hose isn't kinked or clogged (if you can, remove the vent hose and clean it out.) Also check between where the vent hose connects to a wall or pipe. There could be a lint clog anywhere between the dryer and where the air leaves the house.
Dec 02, 2008 | Dryers
Whirlpool Dryer
Your prof. vent cleaner failed to do his job. Ther is a definite restriction in the vent from point A to B, The prof is in the test u performed. You need a straight shot from the dryer to the outside using a class A 4"vent line and a dryer exhaust hood at the termination point,then your problem will be resolved...
Apr 29, 2008 | Dryers
Dryer must have ignited lint inside the cabinet " smells like burnt popcorn" now the dryer takes forever to dry the clothes.
check your venting !!! run a load with out the vent pipe on the back see if it drys normal if so your problem is in you vent duct to the outside
Nov 10, 2007 | Whirlpool GEW9250 Electric Dryer
Dryers Logo
46 people viewed this question
Top Dryers Experts
