Question about Kenmore Elite Oasis 27052 Top Load Washer
Have Kenmore Elite top-loading washer that will not agitate or spin. told it is probably the coupling between motor and transmission. can't get control panel off.
  • 15,935 Answers
Disconnect your Kenmore Oasis washing machine from its power source. Make sure that your washer is unplugged before beginning to disassemble it.
Remove the screws that hold the control console to the top of your Oasis washer. In some Kenmore Oasis models, the two screws may be covered by plastic end caps. After removing the screws, set them aside until you are ready to replace them.
Flip the console up, back and out of the way.
Locate the cabinet clips on the top of your Kenmore Oasis washer. These clips are located toward the back of the washer top and would be hidden by the console if it were not currently flipped up.
5
Slide your screwdriver underneath the metal cabinet clips. Wiggle the screwdriver back and forth to gently pry the cabinet clips free.
6
Disconnect the group of colored wires that plug into the top of the washer from the control console. These wires control the lid switch on your Kenmore washing machine. To disconnect, grasp the white plastic clip and pull gently.
7
Remove the washing machine cabinet. Tilt the cabinet towards you, and then lift the entire cabinet up and off of its platform.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 30, 2010
Kenmore elite washer model 110 won't empty water and spin
Does it agitate? If it does not then it maybe the coupler that connects the motor to the transmission. If you hear a clicking sound. This may be your problem.
May 21, 2014 | Kenmore Oasis Agitator 4.5 cu. ft....
Need manual for kenmore top load washer model 82891120. washer will agitate but not spin pump works to drain water.
the drive coupling or clutch is bad ! the coupling is between motor and the transmission. on a lot of washers its rubber or hard plastic to keep from ruining appliance if it breaks.this is why washer will not spin.
Oct 25, 2011 | Kenmore 24032\24036 Top Load Washer
Won"t spin or agitate. Makes a loud rattling noise
If this is a Whirlpool manufactured TOP LOADER (such as Roper, Estate, Kenmore, Amana, and Frigidaire), you may have a damaged or broken motor coupling. Whirlpool manufactured top loading washers use a motor coupling between the drive motor and gearcase (transmission) in place of a drive belt. This configuration is known as "direct-drive". The coupling can break through normal wear and tear. Washing frequent loads of heavy items and reduce the life span of the coupler. Common symptoms include the following:
1. No spin or agitation.
2. Washer will fill and empty.
3. Drive motor still runs.
4. Strange rattling, grinding or clicking noise during agitation or spin cycles as the drum sits still.
If your washer is exhibiting these symptoms, then its probably a safe bet that the motor coupling is bad.
The following link explains how to replace one:
http://www.fixya.com/support/r3574231-replacing_a_motor_coupling
The part number for a replacement motor coupling is inlcuded in the link I provided. Replacements can be purchased at any of the following websites:
searspartsdirect.com
appliancepartspros.com
pcappliancerepair.com
repairclinic.com
All these sites are reputable and offer great service with competitive pricing, so shop and compare. The first three sites I have listed also included helpful exploded view parts illustrations to assist you with locating and properly identifying any parts you may need.
If you have any questions, please post back with your complete MODEL NUMBER (located on a nameplate along the wash tub rim under the lid) and let me know. I hope this helps you.
Dec 17, 2010 | Kenmore 24032\24036 Top Load Washer
Model # 82891120 kenmore washer will not spin or agitate..
If the washer is top load then it is probably the drive coupling between the motor and the transmission.
Dec 07, 2010 | Kenmore Washing Machines
Kenmore Elite Model 11023032101 will not Spin
if it agitates and pumps out water it is not the lid switch.  you most probably have a bad brake/clutch mechanism.  the fact that it spins tells me the transmission is good
Jul 30, 2010 | Kenmore 23822 Top Load Washer
I have a kenmore 80 series top load washer. the agitation has gotten weaker but still works but now it will not spin after the rinse cycle. any ideas?
sounds like you have a problem with the motor. It could either be that the motor itself is going bad or it could be that the coupling between the motor and the transmission is broken. Have a look underneath the machine and look for bits of rubber. If there is some rubber down there its probably a busted coupling otherwise you may need a new motor.
Dec 12, 2009 | Kenmore 23822 Top Load Washer
My top loading kenmore elite washer model #20972
No, this is probably a direct drive that has a faulty plastic coupling from motor to transmission. Go to:
http://www.fixya.com/support/r385252-replacing_motor_coupling_W... by jsrock516
Please give him a pat on the back for the help.
Oct 12, 2009 | Washing Machines
Kenmore washer will not spin or agitate, it makes noise
IN BETWEEN THE MOTOR AND TRANSMISSION THERE IS A MOTOR COUPLING PART # 285753A REPLACE THAT WILL FIX YOUR PROBLEM
Apr 28, 2009 | Kenmore 23822 Top Load Washer
Kenmore Washer Grinding Sound - No spin or agitation
sounds as if oyou have a bad motor coupling, you can search you tube for keywords, whirlpool motor coupling, far easier to watch someone perform the repain that try to explain it, easy to do!!! part number 285753
Feb 23, 2009 | Kenmore 24032\24036 Top Load Washer
Won't agitate or spin
Probably the motor coupling has cracked. Located between the motor and transmission/gearbox.
Nov 30, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore Elite Oasis 27052 Top Load Washer Logo
174 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
