Question about RCA DRC622N Portable DVD Player with Screen
My portable DVD player, freezes after about 5 minutes
After inserting the DVD disc. The whole player freezes. I open the door, start the disc again, same thing. Sometimes when I remove the disc, and reinsert it, its says NO DISC. CDs and SD photo slot cards work. It is the DVDs that freeze.
  • 14 Answers
SOURCE: DVD not working!
sound like the lazer drive unit is faulty.
Expensive to fix.
My suggestin is by a new one.
Posted on Dec 13, 2007
  • 2427 Answers
SOURCE: My RCA DRC 220 Dvd Players disc tray does not want to close
It seems that the track (carriage) is proberally damaged or needs cleaning, open it out and have a look at the track that takes in the disc if it has dust clean it out or you can open and close it bu hand to get it loose a bit.
If that dont work the motor that pulls in the track or sends it out has a band on it, it might be slack or worn or even dried up and lost elasticity, test it by pulling it in and out a few time to see if it snaps, if you think its worn are slack replace it with a rubber band or a smaller size to the band...
the last think to check is the motor it self.if the abose fails you'll need to change the motor
Posted on Jan 05, 2008
  • 4102 Answers
SOURCE: Unit won't open compact disc door
hi your problem sounds like the flap has come off the runners or become jammed if you remove the case by undoing all the screws if you cant get to the dvd with the case off then plug it in and it will open as the flap will be conected to the case the screws should be located down either side might be 2 or 3 screws running down either side towards the bottom also on the back their might be a couple of screws also but look first in case their isnt you should see the screww going through the outer casing.
Once you have removed all the screws then the case will either lift off by pulling upwards or some of them will slide off if it dont lift off the hold the case either side and pull the case towards you from the front not the back it should slide of forwards let me know how you get on ok or if you need further assistance
Posted on Feb 01, 2008
SOURCE: rca dvd/vcr dual recorder, wont play dvd
My VCR/DVD Model # DRC6200N is not working. I can hear the DVD but no picture, do you have any suggestion what is wrong?
Posted on Jul 17, 2008
sree-here
  • 61 Answers
SOURCE: rca drc628 portable dvd not reading disc
This is due to faulty DVD lens/head. Try cleaning it with DVD/CD lens cleaning CD.If still the problem persists, contact near by service center for replacing the faulty Lens.
Posted on Mar 13, 2009
Unlock portable dvd philips pd9000 for all regions (region free)
Try this:1. Turn on player.
2. Open disc tray.
3. Wait till 'Open' appears on screen
4. Type 9 6 5 3
5. Press up or down button to reach REGION option
6. Press OK button
7. Scroll UP/Down to TEST0 , press OK
8. Press setup again to exit
Let me know if it works!
Sep 19, 2010 | Philips PD9000 Player
DISC DRAWER WILL NOT OPEN
First, start with power cycling the player. Turn off the player and disconnect the power cord from the wall socket. Leave it unplug for about 5 minutes. Turn the player back on and try to open the drawer.
If same problem occur, then follow the steps below:
1. Turn off your DVD player. You do not want to risk electrical shock while working with it.
2. Locate your DVD player's manual Eject button. It is usually a small hole located underneath the DVD drawer.
3. Insert a stiff wire-such as a paperclip or safety pin-into the hole. Push gently and the drawer should open partway. Gently pull the drawer the rest of the way open.
4. Remove the DVD and see if there is a problem with it. Most DVD player drawers get stuck when a DVD is warped or the label is starting to peel. If the DVD is warped, discard it. If the label is peeling, remove the label.
5. Turn your DVD player back on. If it gets stuck again on a different DVD, then the problem may be with your DVD player rather than with your DVDs.
Mar 21, 2010 | Panasonic DMR-ES10 DVD Recorder
Coby DVD shows Invalid Disc HELP PLEASE
Did you make the disk if you made the disk your computer has to give it a digital signature so the DVD player can read it if you're using a regular DVD then I would very carefully using rubbing alcohol and Q tip clean the actual laser I would be very careful doing this if too much rubbing alcohol is on the Q tip it will ruin the laser you can also try resetting the DVD player by taking out the battery and unplugging it from any power source and leave it that way for at least 20 seconds to a minute if that doesn't work you might have something else wrong
Jul 18, 2009 | Coby TF-DVD7005 Portable DVD Player
DVD PLAYER SAYS "INCORRECT DISC" AFTER "READING DISC"
LOCAL TV REPAIR SAYS THAT, WHEN THIS HAPPENS, THE DVD PLAYER NEEDS TO BE REPLACED AND WILL COST ABOUT $125 TO DO SO, WHICH IS NOT AN OPTION AS WE ONLY PAID $100 FOR THE WHOLE THING.
Jan 21, 2009 | Toshiba M24F51 24 in. TV/VCR/DVD Combo
My PDV-705 Portable DVD
Durabrand portable DVD players are no longer supported because the company that made them for Walmart went out of business last Novemeber. You can contact Walmart for a replacement unit.
Jul 29, 2008 | Durabrand PDV-705 Portable DVD Player
Unlock DVD Portable Philips PET 716
1. Turn on player.
2. Open disc tray.
3. Press setup button on remote.
4. Press right button three times to highlight "preference page"
5. Type 9 6 5 3
6. Press up or down button to change the region code ("0" for all regions)
7. Press setup again to exit
Jul 07, 2008 | Philips PET710 Portable DVD Player
Freezes while watching a DVD
send it back to sony and get it fix. you have one year warranty
Feb 24, 2008 | Sony DVP-FX810 Portable DVD Player
Durabrand pdv-702
changes are good that there is a disc stuck in the dvd player
Aug 24, 2007 | Durabrand PDV-705 Portable DVD Player
RCA DRC622N Portable DVD Player with Screen Logo
57 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
