Question about Adobe FrameMaker 5.5 Upgrade Version for PC
I can not run my FrameMaker 5.5 on Windows 7. Can you help me?
  • Richard Williams Jul 16, 2010
    You need to update your Frame Maker 5.5 software to run on Windows 7.
Windows not genuine notification
Windows 7 not genuine notification using command propt How to make Windows 7 genuine using Command Prompt
Press Windows key + R
Now "run" box will appear , in "run" box type CMD
Click on OK
Note : Run CMD as Administrator
Now command prompt will appear
In command prompt type SLMGR -REARM
Hit Enter.
Wait 5-10 seconds
Now a message will appear as shown in image below.
Done !!!
Now your Windows 7 is genuine .. :D
Restart your PC once. Hereafter you won't see the warning message that "Windows 7 is not genuine"
Apr 05, 2014 | Microsoft Windows 7 Ultimate 32 bit Full...
Windows 7 not running for my pc
if your computer is 5 yrs or older it might not support windows 7 also you will need a minimum of 1 GB of RAM for 32 bit or 2GB of RAM for 64 bit to install windows 7
hope this helps
http://windows.microsoft.com/en-AU/windows7/products/system-requirements
hope this helps
Sep 16, 2012 | Computers & Internet
ON INSTALLATION OF TRIAL VERSION OF PAGEMAKER 7 ERROR MESSAGECOMES SAYING ERROR 115 PLEASE ADVISE
Issue
Error 115 when installing Adobe FrameMaker 7.0 or 7.1 on Windows
Solutions
Do one of the following solutions:
Solution 1:Disable anti-virus applications, and make sure all 3rd party applications are closed before installing.
Solution 2:Copy install files to HDD are run setup from that location (Frame installer lives in FM directory)
Solution 3: Remove all files from %temp% and %windir%\temp and reinstall
Background information
Error 115 from the InstallShield help reads as follows: "Specified file cannot be opened as write. An attempt was made to overwrite a locked file belonging to a file group that does not have the Potentially Locked or Shared property set to Yes; an attempt was made to install a file with a long file name (or to a folder with a long path name) in a 16-bit setup; or the path to the target folder is invalid."
Apr 10, 2011 | Adobe PageMaker V7.0.2 for PC
The Chinese font (simsun) is available in the FrameMaker font list, but when I copy and paste the content in FrameMaker, the content shows only question marks. Could you please suggest a solution for...
It is possible the font lives only in the program you are using. Try locating downloading the font from a site like www.dafont.com or similar and installing it to your machine. You can do this by downloading the file, typically a .zip file, then opening the file and in the upper left corner click the "install" button. That will install the font to your machine globally. Hope that works, best of luck
Mar 17, 2011 | Adobe Systems Adobe FrameMaker...
Does CAD KEY 19 work in windows 7 ?
If you run it in Windows 7 in Windows 95/98/00 or NT 4.x compatibility mode then there is no reason why it wouldn't work. To do this;
1. Right-click on the executable (.exe) file and click on 'Properties'
2. Click on the 'Compatibility' tab
3. Check the box next to 'Run this program in compatibility mode for:'
4. Select 'Windows 98/Windows Me', 'Windows 2000' or 'Windows NT 4.0 (Service Pack 5)'
5. Click 'Apply' then 'OK'
6. Double-click the executable (.exe) file to open.
Hope this helps!
Regards,
Matt
Mar 03, 2011 | Cadkey Corp Cadkey 19 Full Version for PC
Webworks 7 wizard unable to scan document: While trying to generate a *.CHM file using the Microsoft HTML help template and FrameMaker 7.0 sourcefile, WW throws the following error: Wizard was unable to...
you need to add following entry to maker.ini file present in C:\Program Files\Adobe\FrameMaker7.0 location
Under section API Client add following line
WWPPE7=Standard,WebWorks Professional Edition Plugin,C:\Program Files\Quadralay\WebWorks Publisher Professional Edition 7.0\bin\wwpfm7.dll,all
Please note that path given to wwpfm7.dll may defer depending upon your webworks installation directory
Thanks
Rohit
May 07, 2010 | Quadralay WebWorks Publisher Professional...
Pets Don't Have Faces
Check that you are running in compatable mode. Since Windows 7 is so new not all programs run properly so you should have a link to run the program in a compatable stage. If not check and make sure your program is compatable with Windows 7. You may have to reinstall the program and you will probably get a message to install in a compatable mode. If you do make sure you install in that mode then the program should work. Windows 7 is like when they first came out with Windows Vista there are a few bugs that they are still working out and that is probably what is causing the problem.
Jan 10, 2010 | Ubi Soft Petz: Dogz 5 and Catz 5...
Webworks ePublisher 9.2
Try a software uninstaller. Hope this Help.
Feb 07, 2008 | Quadralay WebWorks Publisher Professional...
Adobe FrameMaker 5.5 Upgrade Version for PC Logo
115 people viewed this question
Top Adobe Computers & Internet Experts
lemesee
Are you an Adobe Computer and Internet Expert? Answer questions, earn points and help others
