Question about Philips DVDR3450H DVD Recorder/HDD Recorder
DVDR 3460H - problem ejecting disk
DVDR3460h
Disk is being read by player but gets stuck and we are unable to eject disk from player - player is freezing and will not respond to remote or player buttons
  • 1 more comment
  • debij75 Sep 18, 2008
    i have same problem - i can not eject the disc from my Philips dvdrecorder (250gb - DVDR3460H) - when the player is turned on - it automatically starts scannin the disc thats in the drive and i can not prevent it, interrupt it or do anything with it - i contacted philips - they advised me to download the updated software - which is all well and good and i did do that.. only problem being - I NEED TO GET THE STUCK DISC OUT OF MACHINE FIRST SO I CAN LOAD THE DISC WITH UPDATE ON !!!.
    thank you philips - you were a great help!..
    please help i am stuck stuck stcuk
    yours frustrated
    debij75
  • Anonymous Jan 23, 2009
    I have the same problem. any solutions to this?
  • Anonymous Feb 22, 2009
    the same case either. i havent contacted philips yet but i still wished we could help it out without getting to em. several times ago, the same problem occured once, and i help when i first make power on then without trying to let the player read it pressed the "tuner" button on the rc, afterwards i touched the eject button and it worked well. but this time the dvd really stuck in there. although it was a computer made non-copyrighted disc, it's not one of a kind so i really don't understand why this "stuck" problem occured, unreasonable
1) Turn it upside down.
2) Turn it on
3) Press eject button & use screwdriver with special slot
Similar example
http://www.ryan.com.br/prod_dvp642_ejection.htm
Posted on Oct 16, 2009
You'll need a security screwdriver to undo the silly screws that keep the chassis cover on. (Not a phillips screwdriver, ironically!) You've unplugged it from the mains, of course.
Use the same screwdriver to unscrew and remove the DVD disk unit. (The tray has a decorative blac strip clipped to it which you'll need to remove in order to comletely get the unit and tray out opf the chassis.
Now carefully prize off the top unit and look for the little motor and drive belt that operates the disk tray opening ghears. You'll probably find this has broken. I think when I replaced mine it was a 25mm drive belt with a square cross-section that I needed. It cost me about 50p on ebay to get the right one and fix the tray.
Hope this helps
Posted on Oct 13, 2012
    Problem Solver:
  • 5 Answers
I had same problem with my Philips Dvd3460h, the only way i could get disk out was to take the top off the unit, and on the front left hand side (on the actual disk draw) there is a white disk, i gently lifted that white disk and kept it raised while pressing open/close button again, to eject disk and draw opened allowing me to take the out...
This has happened a few times now, the odd disk wont play or eject and each time have had to do the same thing to get the disk out..
hope this helps
Posted on Oct 15, 2009
My dvd player is stuck on one dvd and wont let me eject, change disc, or even stop the current dvd. display reads "locked" whenever i press any buttons. can only turn on and off the device.
Hi, For some reason the disk will not play. You push the eject button over and over again, but the disk slot will not open. Here's one solution...
* 1 Turn off the DVD player. Wait a few minutes, turn the DVD player back on, and
then press the "eject" button. If this does not work, turn it off and unplug
the DVD player...while you keep pushing EJECT button plug the DVD and turn it on (your hand still on the eject..) is should come out..
* 2 ..if it does not eject , unplug the DVD player again, Remove the screws off DVD on the sides and take off the DVD casing.
* 3 Look for the DVD holder inside the DVD player. This device holds the DVD in
place while the DVD player reads the disk.
* 4 Push the stuck DVD disk toward the front of the DVD player until the DVD
ejects. Remember the DVD player is not on and some force ( gentle ! ) must be applied.
* 5 While it is open,plug it on and place a DVD disc just to see if mechanism works properly..
* 6 Replace the casing and the screws. Plug the player in and turn it on. Put
another DVD in to test whether the player is finally working ..
Hope this helps!..
Take care and please
Remember to rate/vote and give us 4 Thumbs Up
to continue f
or Helping out the Community :)
Jul 09, 2011 | Televison & Video
Philips DVD recorder, (250gb) DVDR3460H. can not remove disk .........
your gonna have to open the machine up the there is a whits tab that lifts the disc up to spin you will have to use your fingers to slde it of that make sure its unplugged and then the white thing will realese
Sep 19, 2008 | Televison & Video
Tip
DVD player in my home theater system won't eject the disk inside.
When a disk is stuck inside the player , try following the procedure below:
Unplug power cord.
Plug back power.
Turn on the unit and press repeatedly the eject button at the same time. If you successeed in ejecting the disk before the player starts reading TOC(disk initial track), then the disk will eject.
If that does not work, then there is an internal fault, in that case the unit must be disassembled to remove the disk.
on May 04, 2009 | Philips HTS3450 System
DVD stuck in my Panasonic DMR-E30
Hi Rock.
I had the same problem like this on my machine. The best way to fix it is to turn the machine off completely and hold on the eject button then turn the power on. You want the first thing the player does is to eject the disk without trying to read it first.
I hope it works let me know if it doesn't and i'll try and recreate the problem on my player and see what i can do to get the disk out.
The last resort is to manually take the disk out but lets cross that bridge if my suggestion above doesn't work.
Thanks
smeags.
Feb 18, 2008 | Panasonic DMR-E30 DVD Recorder
CD STUCK IN CD PLAYER
The case needs unscrewing to reveal more of the internals. Go carefully and peer inside wherever you can to fiddle the CD back into place or out of the box. It's in there somewhere, removing panels will get there.
Sep 07, 2009 | 2007 Chevrolet Avalanche LTZ
Hts 3450 home theatre system- dvd in player- but won't come out
Unplug power cord.
Plug back power.
If that does not work, then there is an internal fault, in that case the unit must be taken apart to remove the disk.
Dec 10, 2008 | Philips HTS3450 System
DVD tray will not open
Unplug power cord.
Plug back power.
Feb 25, 2008 | Dual Presidian DVD Recorder
Cd is stuck
put the same disk in , play it for a while then eject it properly.
Nov 13, 2007 | Pioneer AVH-P6500 Car Video Player
DVD RW stucked - stall the whole system.
Hi, I found this site today cos I had a similar problem. To cut a long story short I found a slot on the bottom of the machine, below the disc tray, that has a white lever in it. After removing the power source I moved the lever to the side and the tray opened manually so I could remove the disc. It seems It was a duff DVDR as other discs now work fine. Good luck !
Oct 15, 2007 | Philips DVDR3440H DVD Recorder/HDD...
Philips DVDR3450H DVD Recorder/HDD Recorder Logo
1,988 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
