Question about Dell Inspiron 6400 Notebook
How do you take the back off the Dell Laptop Inspiron computer?
I have removed all the screws and it is still attached
  • Anonymous Apr 20, 2009
    Fan making alot of noise. Trying to remove back to inspect. Have removed all the visible screws andf still seems to be attached
  • 242 Answers
The Dell website has a very good documentation page on how to remove the various parts of your Inspiron 6400.
Look here
Think you will find everything there...
Posted on Mar 25, 2008
    Genius:
  • 3,587 Answers
You have to also do a few under the keyboard to remove that panel..it's held from both sides.
Posted on Mar 23, 2008
2 Suggested Answers
peeface
  • 180 Answers
SOURCE: Dell Inspiron 1000 Disassembly
i took apart a few laptops recently to swap a few things and there was some double sided tape holding the motherboard to the bottom casing. maybe thats it
Posted on May 20, 2009
My laptop shuts down in 5-10 mins.
Instructions
Purchase a new fan for the Sony Vaio model you have by checking the owner's manual of your computer or consult the Sony website for the correct part number.
Remove the power cord from your computer and then remove the battery. Unlock the battery and slide it from the bottom of the laptop. Allow it to sit for 5-10 minutes after removing the battery.
Turn the computer with the left side facing toward you and locate the only screw found on the left side and remove it. Remove the panel by sliding it toward you and set it aside.
Slide the panel covering the power buttons to the left and detach the ribbon cable connecting it to the motherboard and then remove the panel gently.
5
Remove the keyboard by unscrewing the small screw directly above the keyboard. Once the screw is removed, gently lift the keyboard and detach the small cord connecting it to the motherboard. Set the keyboard aside.
6
Remove the plate under the keyboard by unscrewing the three screws and lift the plate out.
7
Disconnect the cooler fan from the motherboard by pressing the connectors in and removing them from the sockets. Once the connections have been removed, lift the cooling fan up out of the computer.
8
Replace the old fan with the new one you purchased and attach the two connectors. Reinstall the metal plate back on top of the fan and attach the screws.
Jan 10, 2013 | Dell Inspiron 1545 Notebook
Tip
How do replace keyboard on a dell 15 ?
It’s easy to break the flimsy keys on most laptops. Sometimes it’s cheaper to find a laptop keyboardfor your model laptop elsewhere than going through the manufacture. Ifyou find yourself in this situation, you can use these steps to replacethe keyboard. take “Dell Inspiron E1505 Keyboard” for example:
Dell Inspiron E1505 Keyboard US
Removing the Damaged Keyboard…
Enusre the laptop is fully powered off, unplugged from the wall, and the laptop battery taken out.
Turn the laptop over. On some models icons indicating which screwsare attached to the keyboard are displayed. If not, you may have to“eyeball” it if you can’t find a breakdown for your model (such as dell pa 12 or pa 10)online.
Remove those screws with a T-8 or Phillips screwdriver.
Turn the laptop back over and open it up. Check and see if thekeyboard is tucked under any plastic pieces. If so, find if thoseplastic pieces are screwed into anything, and unfasten them as well. Ifnot, it probably uses clamps that can easily be removed.
Remove the plastic pieces carefully with a toothpick or plastic pick if there is any in the way.
Unscrew any screws at the top (if necessary) and remove the keyboarditself from top to bottom. You’ll notice that the keyboard is connectedwith a thin, but wide, data cable to the system board at the bottom.
Take that same pick and lift the plastic connectors that hold in this data cable in place.
carefully remove the data cable. Now the whole keyboard should be free.
Replacing the keyboard.
Take the new laptop replacement keyboardout of the plastic, and slip the data cable back in between the plasticconnectors on the system board. Make sure it’s all the way in.
Use the pick to push the plastic connectors back into place, and make sure it’s holding the data cable in.
Slip the keyboard itself into place, from bottom to top. Make sure the screw holes or clamps line up at the top.
Refasten the keyboard in place at the top.
If you had to remove any plastic pieces, carefully snap them back in and replace any screws you had to remove.
Turn the laptop over and replace all of the keyboard screws.
Finally, put the battery back in and power on the laptop. If all hasgone well, the keyboard should be functioning like brand new.
on Jan 19, 2010 | Computers & Internet
Dell inspiron 1520 won't turn on.
Remove the battery from its compartment on the side of your Dell Inspiron laptop computer.
Remove the power adapter from its plug on the side of the Dell Inspiron (if your laptop is currently plugged into a wall outlet).
Press down and hold the "Power" button on the laptop for one to two minutes. This will dispel the excess electrical current that is built up inside the laptop.
Put the battery back inside the compartment of your Dell Inspiron.
Plug your power adapter back into the side of the Dell Inspiron. Press "Power." Your laptop computer will now turn on.
hope this helps
Oct 08, 2012 | Dell Inspiron 1420 1501 1520 1521 1525...
HOW TO INSTALL A CD DRIVE IN A DELL 511 LAPTOP
Turn off power, remove battery pack, remove all screws on the laptop casing, then pull apart.
Slowly pull cd rom cable attachments straight out. Make sure you do not bend the pins. Then insert new rom drive, then put pc back together, boot and install cd rom drivers.
Oct 22, 2009 | Dell Inspiron 5100 Notebook
Broken Inspiron 1525 Lid
hello
To fix your laptop follow the steps given below.
  • First of all as your hinges are broken you have to buy a pair of hinges for your laptop model.
  • This hinge includes the whole assembly made up of metal with a part which attaches your screen to the laptop.
  • Now you have to open up your laptop from the backside and disassemble the upper side.
  • This will make you see the part which detaches tour screen from the laptop.Just remove the screws and your screen will be completely detached.
  • now you can replace the damaged hinges with the new one.
  • you have to remove four screws for one hinge.Two screws supporting the screen and two attaches the screen with the laptop.
  • so remove these screws and replace the hinges and pack the laptop again.
And the lines are basically due to the movement of loose connector. So while fixing please fix the connector also.
Thank you
Aug 21, 2009 | Dell Inspiron 1525 Notebook
May 19, 2009 | Dell Inspiron 1000 Notebook
1 Solution for "dell inspiron 8600 laptop how
The hard drive is behind the cover where the mic and earphone are located. Turn the laptop over and there is a single screw that secures this cover. Remove the screw then slide the cover and hard drive out. The cover and cradle are attached to the hard drive.
May 08, 2009 | Dell Computers & Internet
How do you replace the screen or lid of the dell 9100
The laptop screen is secured to the laptop with screws at the hinges.
There are usually two screws per hinge on the back edge of he laptop. Remove the plastic panel next to the hinges, this panel is secured with a screw near the corners of the laptop. The LCD screen has one ribbon cable and possibly a power connector for the back lighting attached to the motherboard under the plastic panel near the hinges. Disconnect these before you lift the LCD off the base.
Feb 27, 2009 | Dell Inspiron 9100 Notebook
Inspiron 1501 BIOS Password
contact Dell technical support, they can generate a master password
Jul 27, 2008 | Dell Inspiron 1501 Notebook
The teardown information from rbrown67 was very accurate and easy to follow. It helped tremendously in tearing down my machine to replace the AC plug.
Mar 14, 2008 | Dell Inspiron 1000 Notebook
Dell Inspiron 6400 Notebook Logo
2,240 people viewed this question
Alun Cox
